[Swift-devel] Intrepid
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Wed Apr 10 19:09:51 CDT 2013
Can you try using /intrepid-fs0 ?
On 04/10/2013 06:47 PM, Ketan Maheshwari wrote:
> Hi All,
> Trying to run Swift on Intrepid but jobs are failing. I am using
> coasters with local:cobalt provider.
> The last error message I am getting is:
> Job failed with an exit code of 30
> Apart from this, the std.err also shows this error message:
> Failed to open log file
> (/home/ketan/lab/catsnsleep/worker-0410-2811160-000000-69be4b00.log):
> Read-only file system at /home/ketan/.globus/coasters/cscript6918.pl
> <http://cscript6918.pl> line 416
> Line 416 on that perl is:
> open(LOG, ">>$LOG") or die "Failed to open log file ($LOG): $!";
> The logs, sources, configs are here:
> http://www.mcs.anl.gov/~ketan/intrepidlogs.tgz
> <http://www.mcs.anl.gov/%7Eketan/intrepidlogs.tgz>
> The sites file is yanked from Jon Monette's homedir on Intrepid since
> the dir showed signs of working version. It was with Swift 0.93 and my
> current test is with 0.94 RC though.
> Thanks much for any help on this.
> Regards,
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130410/51c39161/attachment.html>
