[Swift-devel] Swift arrays
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Apr  3 22:02:47 CDT 2013
No problem not fixing it in 0.94.  We should document the state of case-sensitivity though.
And I hope you can merge the faster branch into trunk as soon as it passes a reasonable test battery.
And I'm in favor of "normal" case sensitivity ala C and Java. So if faster-branch is already correctly case-sensitive, I'd say there is nothing to fix here.
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Wednesday, April 3, 2013 9:57:39 PM
> Subject: Re: [Swift-devel] Swift arrays
> Seems that you are correct (despite the error message printing the
> correct type for B): if I say foreach c,..., it finishes fine.
> I'm wary of fixing this in 0.94, so that leaves trunk. But then if we
> merge the faster branch to trunk, that problem won't be there any
> more
> since things are case-sensitive there.
> Let me know what you think.
> Mihael
> On Wed, 2013-04-03 at 18:04 -0500, Michael Wilde wrote:
> > Ketan will explain more, but the problem here seems to be one of
> > case-insensitive names.
> > In:
> >   foreach b,i in B{
> > b and B seem to be referring to the same variable, hence the
> > Invalid Path message.
> > I vaguely recall an older discussion about variable name case
> > sensitivity.  What was the latest implementation decision on that?
> > For example, if I declare a and A as variables, I get an "already
> > defined" error, but in the case of the implicit variable
> > declaration of the foreach loop vars, this seems to work
> > differently.
> > - Mike
> > > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > > Sent: Wednesday, April 3, 2013 4:20:33 PM
> > > Subject: [Swift-devel] Swift arrays
> > > Trying to get some arithmetic done over arrays. I was testing a
> > > simple Swift script as follows:
> > > int A[] = [1,1,1];
> > > int B[] = [2,2,2];
> > > foreach b,i in B{
> > > tracef("A[%i] is %i.\n",i, A[i]);
> > > tracef("B[%i] is %i.\n",i, B[i]);
> > > Progress: time: Wed, 03 Apr 2013 17:18:13 -0400
> > > A[2] is 1.
> > > A[0] is 1.
> > > A[1] is 1.
> > > Execution failed:
> > > org.griphyn.vdl.mapping.InvalidPathException: Invalid path ([1])
> > > for
> > > B[1]:int = 2 - Closed
> > > swiftscript:tracef, test.swift, line 6
> > > Wondering if this should fail and why.
> > > Thanks,
> > > Ketan
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
