[Swift-devel] coaster error on Midway
    David Kelly
    davidk at ci.uchicago.edu
    Fri Oct 19 17:59:56 CDT 2012
I remember something like this happening in one of the versions of trunk - I believe it has been fixed in the latest version.
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>, "Mihael Hategan" <hategan at mcs.anl.gov>
> Cc: "swift-devel" <swift-devel at ci.uchicago.edu>
> Sent: Friday, October 19, 2012 3:10:01 PM
> Subject: coaster error on Midway
> Im getting the error below on Midway (running the swift from module
> load swift)
> Is this a know issue, with a known fix?
> I'll try latest trunk next.
> This happened both without and with provider staging.
> I will post bug with log files if it recurs with latest trunk.
> - Mike
> Swift trunk swift-r5939 cog-r3472
> RunID: 20121019-2005-yptzr8l6
> Progress: time: Fri, 19 Oct 2012 20:05:54 +0000
> Progress: time: Fri, 19 Oct 2012 20:05:56 +0000 Stage in:1
> Submitted:99
> Progress: time: Fri, 19 Oct 2012 20:05:57 +0000 Stage in:33
> Submitted:67
> Progress: time: Fri, 19 Oct 2012 20:05:58 +0000 Stage in:56
> Submitted:36 Active:8
> Progress: time: Fri, 19 Oct 2012 20:05:59 +0000 Stage in:65
> Submitted:3 Active:32
> Progress: time: Fri, 19 Oct 2012 20:06:00 +0000 Stage in:51 Active:49
> Progress: time: Fri, 19 Oct 2012 20:06:08 +0000 Active:99 Stage out:1
> Progress: time: Fri, 19 Oct 2012 20:06:24 +0000 Active:96 Finished
> successfully:4
> Progress: time: Fri, 19 Oct 2012 20:06:28 +0000 Active:95 Stage out:1
> Finished successfully:4
> Progress: time: Fri, 19 Oct 2012 20:06:29 +0000 Active:74 Stage out:12
> Finished successfully:14
> Progress: time: Fri, 19 Oct 2012 20:06:30 +0000 Active:52 Stage out:3
> Finished successfully:45
> Progress: time: Fri, 19 Oct 2012 20:06:31 +0000 Active:25 Stage out:24
> Finished successfully:51
> Exception caught while processing reply
> java.lang.IllegalArgumentException: Wrong data size: 4. Data was @].z
> at
> org.globus.cog.karajan.workflow.service.RequestReply.unpackLong(RequestReply.java:237)
> at
> org.globus.cog.karajan.workflow.service.RequestReply.getInDataAsLong(RequestReply.java:232)
> at
> org.globus.cog.karajan.workflow.service.commands.HeartBeatCommand.replyReceived(HeartBeatCommand.java:40)
> at
> org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleReply(AbstractKarajanChannel.java:401)
> at
> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.stepNIO(AbstractStreamKarajanChannel.java:234)
> at
> org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
> at
> org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Progress: time: Fri, 19 Oct 2012 20:06:33 +0000 Stage out:10 Finished
> successfully:90
> Final status: Fri, 19 Oct 2012 20:06:33 +0000 Finished
> successfully:100
> mid$
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
