[Swift-devel] coaster error on Midway
Michael Wilde wilde at mcs.anl.gov
Fri Oct 19 15:10:01 CDT 2012
Im getting the error below on Midway (running the swift from module load swift)
Is this a know issue, with a known fix?
I'll try latest trunk next.
This happened both without and with provider staging.
I will post bug with log files if it recurs with latest trunk.
- Mike
Swift trunk swift-r5939 cog-r3472
RunID: 20121019-2005-yptzr8l6
Progress:  time: Fri, 19 Oct 2012 20:05:54 +0000
Progress:  time: Fri, 19 Oct 2012 20:05:56 +0000  Stage in:1  Submitted:99
Progress:  time: Fri, 19 Oct 2012 20:05:57 +0000  Stage in:33  Submitted:67
Progress:  time: Fri, 19 Oct 2012 20:05:58 +0000  Stage in:56  Submitted:36  Active:8
Progress:  time: Fri, 19 Oct 2012 20:05:59 +0000  Stage in:65  Submitted:3  Active:32
Progress:  time: Fri, 19 Oct 2012 20:06:00 +0000  Stage in:51  Active:49
Progress:  time: Fri, 19 Oct 2012 20:06:08 +0000  Active:99  Stage out:1
Progress:  time: Fri, 19 Oct 2012 20:06:24 +0000  Active:96  Finished successfully:4
Progress:  time: Fri, 19 Oct 2012 20:06:28 +0000  Active:95  Stage out:1  Finished successfully:4
Progress:  time: Fri, 19 Oct 2012 20:06:29 +0000  Active:74  Stage out:12  Finished successfully:14
Progress:  time: Fri, 19 Oct 2012 20:06:30 +0000  Active:52  Stage out:3  Finished successfully:45
Progress:  time: Fri, 19 Oct 2012 20:06:31 +0000  Active:25  Stage out:24  Finished successfully:51
Exception caught while processing reply
java.lang.IllegalArgumentException: Wrong data size: 4. Data was @].z
	at org.globus.cog.karajan.workflow.service.RequestReply.unpackLong(RequestReply.java:237)
	at org.globus.cog.karajan.workflow.service.RequestReply.getInDataAsLong(RequestReply.java:232)
	at org.globus.cog.karajan.workflow.service.commands.HeartBeatCommand.replyReceived(HeartBeatCommand.java:40)
	at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleReply(AbstractKarajanChannel.java:401)
	at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.stepNIO(AbstractStreamKarajanChannel.java:234)
	at org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
	at org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
Progress:  time: Fri, 19 Oct 2012 20:06:33 +0000  Stage out:10  Finished successfully:90
Final status: Fri, 19 Oct 2012 20:06:33 +0000  Finished successfully:100
mid$
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
