[Swift-devel] coaster service runtime info table
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun May 20 21:23:17 CDT 2012
On Sun, 2012-05-20 at 21:04 -0500, Jonathan Monette wrote:
> Is this an option we specify when starting a coaster service?
Yes (-stats)
>  If so does that screen take over the terminal and we need to run swift in a separate terminal or does that replace the swift stdout/stderr output?
Yes. So if you want the old behavior just don't add that option to the
service command line. In other words you don't have to do anything if
you don't want to change anything.
