[Swift-devel] Data-aware scheduling in Swift ?
Jonathan Monette jonmon at mcs.anl.gov
Thu Mar 29 11:08:22 CDT 2012
I believe that Swift will schedule true work on any node that becomes available for work. It does not give preference to a node for to take advantage of data locality.
As far as I know there is no way to configure Swift to use data aware scheduling. This is Swift's default behavior.
On Mar 29, 2012, at 10:59, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
> Hi All,
> I have a question about how swift schedules computations.
> Suppose there are two computation stages namely Stage-A and Stage-B in an application. Stage-A produces the data and Stage-B consumes the data . Could you please tell me how swift schedules these computations? Does it schedules Stage-A and Stage-B on the same node or on multiple nodes?
> Is it possible to configure the swift to schedules these computations on the same node (or is this the default behavior of swift ) ?
> Thank you
> Emalayan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120329/426599de/attachment.html>
