[Swift-devel] Issues with Montage & Swift-CDM
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Mar 22 14:47:26 CDT 2012
So here is an old cdm file I used when running this on PADS
rule .*raw_dir/.* DIRECT /gpfs/pads/swift/jonmon/Swift/SwiftMontage/big
rule .*proj_dir/.* DIRECT /gpfs/pads/swift/jonmon/Swift/SwiftMontage/big/run.0012
rule .*diff_dir/.* DIRECT /gpfs/pads/swift/jonmon/Swift/SwiftMontage/big/run.0012
rule .*stat_dir/.* DIRECT /gpfs/pads/swift/jonmon/Swift/SwiftMontage/big/run.0012
rule .*rect_dir/.* DIRECT /gpfs/pads/swift/jonmon/Swift/SwiftMontage/big/run.0012
The on Emalayan is using is
rule .*raw_dir.* DIRECT /home/emalayan/App/montage-swift/SwiftMontage/scripts
rule .*final.* DIRECT /home/emalayan/App/montage-swift/SwiftMontage/scripts
rule .*.* DIRECT /tmp/mosa
I explicitly used DIRECT on the different intermediate directories(proj_dir, diff_dir, stat_dir, and rect_dir).  In your however you match anything that is not raw_dir and final and put it into mosa. I would say try to do something like mine where you explicitly map those intermediate directories to /tmp/mosa
On Mar 22, 2012, at 2:35 PM, Emalayan Vairavanathan wrote:
> Hi Justin,
> Please use ./run_local.sh to run the montage without cdm locally on the headnode.
> The rest of the scripts (run-workers.sh, run.sh, run-swift.sh, main.sh) are written to run experiments in our cluster and wont work in Surveyor.
> Please let me know if you have questions.
> Thank you
> Emalayan
> From: Justin M Wozniak <wozniak at mcs.anl.gov>
> To: Emalayan Vairavanathan <svemalayan at yahoo.com>
> Cc: "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>; matei <matei at ece.ubc.ca>
> Sent: Thursday, 22 March 2012 11:54 AM
> Subject: Re: [Swift-devel] Issues with Montage & Swift-CDM
> On Wed, 21 Mar 2012, Emalayan Vairavanathan wrote:
> >     But I just setup everything on Surveyor and it works locally on the head node. You can find the setup here.
> >   /home/emalayan/app/montage-swift-cdm/SwiftMontage/scripts
> What is the entry point?
> Are we missing common.sh?
> -- Justin M Wozniak
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120322/9c64270f/attachment.html>
