[Swift-devel] Issues with Montage & Swift-CDM
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Wed Mar 21 15:56:32 CDT 2012
Hi Emalayan
 	I just took a look at this log.  Does the montage-swift workflow
work for you without CDM?
 	Is there a machine on which we can all try to run this locally?
(PADS login node?)
 	Justin
On Mon, 19 Mar 2012, Emalayan Vairavanathan wrote:
> Hi Jon and All,
> I tried to run the montage-swift workflow on my local machine with CDM
> rules enabled. The workflow is failing (only first stage was completed
> successfully). For me it seems that some stages of the workflow expect
> the input to be located in a specific location.
> I am using swift-0.93. I have attached the log files, site files,
> configuration files and swift stderr/out with this mail. It would be
> great if you can look at this issue and help me.
> (Note: Due to similar issue ModFTDock-swift workflow also fails on my local machine when CDM rules enabled)
> Thank you
> Emalayan
Justin M Wozniak
