[Swift-devel] Worker node ip address
Jonathan Monette jonmon at mcs.anl.gov
Thu Mar 15 16:06:17 CDT 2012
Ok.  Thanks Emalayan.
On Mar 15, 2012, at 3:32 PM, Emalayan Vairavanathan wrote:
> Hi Jon,
> MosaStore can calculate the list of IPs in a partition (if partition is the multiple of pset) from the information available to ZeptoOS.
> So Coaster's does not need to provide this information and I am not blocked by this issue.
> Thank you
> Emalayan
> From: Jonathan Monette <jonmon at mcs.anl.gov>
> To: "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>
> Cc: Michael Wilde <wilde at mcs.anl.gov>; emalayan at ece.ubc.ca; Justin Wozniak <wozniak at mcs.anl.gov>; MosaStore <mosastore at googlegroups.com>
> Sent: Wednesday, 14 March 2012 12:47 PM
> Subject: Worker node ip address
> Our current coaster hosts scripts rely on the worker logs and to report the ip addresses.  In the case of the kernel profile for mosa, hostname does not report the ip addresses so the workers do not know them.  In a previous email thread( [Swift-devel] [ZeptoOS] hostname  returns none in Surveyor) we discussed about how to get the worker node ip addresses using personality.sh and some netmasking(attributed to Zhao, thanks!).  Emalayan you specified that for now you can use the approach of using the torus rank 0 for the mosa manager and the mosa workers will just connect back to torus rank 0.  In a previous email to me you specified that this approach will work for the experiments you are planning for SC but you would need a better way for other mosa deployments.
> So i guess the question is is the coaster hosts issue a blocker for you Emalayan but want to see if you are waiting for this or not?
> Could also verify that you are using the method of using the torus rank 0.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120315/b87950ed/attachment.html>
