[Swift-devel] Need CDM Direct documentation - Re: Configuring Swift to access MosaStore
Justin M Wozniak
wozniak at mcs.anl.gov
Mon Mar 5 19:20:53 CST 2012
I think Ketan's case had to do with absolute path names. That is covered
in the user guide:
http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_specific_use_cases
I will take a look at Emalayan's case...
Justin
On Mon, 5 Mar 2012, Ketan Maheshwari wrote:
> Not really following this thread; here is my input:
> I know that we (Justin and me) had to add a couple lines in the ~cdmlib.sh
> in order to make it work correctly for the SCEC workflow. I have the
> patched version somewhere in my dir, will dig it up.
> In addition, I also observed that when the "* default " line is present in
> the cdm files, it somehow did not work for me, so I had to remove it.
> I did do some tests on combinations of absolute, relative, path in swift
> script and the same in the cdm directory but do not recall results (nothing
> unexpected happen).
> I wrote some documentation on the CDM section, will dig up and get back.
> On Mon, Mar 5, 2012 at 6:43 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Hi Ketan, Justin, or anyone else who has tried this recently:
>> Could you point us to the documentation that you wrote on how to use CDM
>> direct to obtain simple access to literal, untranslated, full path names?
>> As I recall there were some subtleties on how to specify the name
>> patterns, including matching both swiftwrap-observed names and file://
>> names in vdl-int.k.
>> Or is it simper then I recall?
>> I have checked out the CDM "absolute" test that Emalayan mentioned below.
>> Does that do a complete test of references to absolute names? And for only
>> names below say /tmp/mosa?
>> - Mike
>> ----- Original Message -----
>>> From: "Emalayan Vairavanathan" <svemalayan at yahoo.com>
>>> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
>>> Cc: "Michael Wilde" <wilde at mcs.anl.gov>, emalayan at ece.ubc.ca,
>> matei at ece.ubc.ca, swift-devel at ci.uchicago.edu, "Jonathan
>>> Monette" <jon.monette at gmail.com>, "MosaStore" <
>> mosastore at googlegroups.com>
>>> Sent: Monday, March 5, 2012 5:25:05 PM
>>> Subject: Re: [Swift-devel] Configuring Swift to access MosaStore
>>> Please find the attached setup.
>>> Thank you
>>> Emalayan
>>> From: Jonathan Monette <jonmon at mcs.anl.gov>
>>> To: Emalayan Vairavanathan <svemalayan at yahoo.com>
>>> Cc: Michael Wilde <wilde at mcs.anl.gov>; "emalayan at ece.ubc.ca"
>>> <emalayan at ece.ubc.ca>; "matei at ece.ubc.ca" <matei at ece.ubc.ca>;
>>> "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>;
>>> "mosastore at googlegroups.com" <mosastore at googlegroups.com>; Jonathan
>>> Monette <jon.monette at gmail.com>
>>> Sent: Monday, 5 March 2012 3:07 PM
>>> If you could provide the set up you were using that would be great. I
>>> can fill in anything missing an do my tests to verify.
>>> On Mar 5, 2012, at 13:34, Emalayan Vairavanathan <
>>> svemalayan at yahoo.com > wrote:
>>> Thank you Jon.
>>> Yesterday I successfully run Mosa (on our cluster) with cdm-direct
>>> mode with the help of swift-user manual and the scripts available in
>>> /cog/modules/swift/tests/cdm/absolute .
>>> It would be useful if you can develop a simple test case. I can double
>>> check with my test case.
>>> Thank you
>>> Emalayan
>>> From: Jonathan Monette < jonmon at mcs.anl.gov >
>>> To: Michael Wilde < wilde at mcs.anl.gov >
>>> Cc: " emalayan at ece.ubc.ca " < emalayan at ece.ubc.ca >; "
>>> matei at ece.ubc.ca " < matei at ece.ubc.ca >; " swift-devel at ci.uchicago.edu
>>> " < swift-devel at ci.uchicago.edu >; " mosastore at googlegroups.com " <
>>> mosastore at googlegroups.com >; Jonathan Monette < jon.monette at gmail.com
>>> Sent: Monday, 5 March 2012 7:14 AM
>>> Yea. I will get demo scripts together for the mosa tests.
>>> On Mar 5, 2012, at 8:17, Michael Wilde < wilde at mcs.anl.gov > wrote:
>>>> was: Re: [Swift-devel] coasters-hosts.pl script
>>>> Jon, can you create a demo script that shows how to configure a
>>>> Swift run to use MosaStore. The following approach may work:
>>>> - Assume MosaStore will be mounted as /mosa to all workers
>>>> - Simulate this with a localhost run, using /tmp/mosa, then do same
>>>> with *1* worker, N jobs per node (eg 4 on BG/P, 8 on PADS, 2 on
>>>> Beagle).
>>>> - Set CDM direct mode for all paths starting with [/tmp]/mosa. You
>>>> might need to work through some of the issues with CDM direct where
>>>> accesses need to match both /tmp/mosa and file:///tmp/mosa (I
>>>> *think*)
>>>> - Map some temporary output-to-input files to /tmp/mosa; create a
>>>> multi-level "catsncats"-like workflow to exercise it; the recent
>>>> ParameterSweep example, perhaps extended to do N levels of
>>>> fan-in/fan-out and pass-N might be a good test.
>>>> - see if you can get _concurrent to get placed on /tmp/mosa
>>>> I think some of these tests would be a great test case for
>>>> Swift/Turbine as well.
>>>> You can do this is stages; the simple test of mapping CDM-direct
>>>> files to /tmp/mosa should give Emalayan an initial test case to run
>>>> once Mosa is ready on the BG/P.
>>>> - Mike
>>>>> From: "Matei Ripeanu" < matei.ripeanu at gmail.com >
>>>>> To: mosastore at googlegroups.com , "Jonathan Monette" <
>>>>> jonmon at mcs.anl.gov >, "Justin M Wozniak" < wozniak at mcs.anl.gov >
>>>>> Cc: swift-devel at ci.uchicago.edu , emalayan at ece.ubc.ca
>>>>> Sent: Friday, March 2, 2012 6:29:17 PM
>>>>> Subject: Re: [Swift-devel] coasters-hosts.pl script
>>>>> Indeed this is good news! Thank you.
>>>>> Our next task, I think, will be to figure out how to configure
>>>>> Swift
>>>>> so that the headnode (where Swift runs) will not require any access
>>>>> to
>>>>> intermediate storage (MosaStore). Only the worker nodes will have
>>>>> access to intermediate storage. This is to go around the one way
>>>>> headnode-worker node connectivity issue.
>>>>> Any guidance on how to get this configuration would be much
>>>>> appreciated.
>>>>> Thank you again,
>>>>> -Matei
>>>>> From: mosastore at googlegroups.com [mailto:
>>>>> mosastore at googlegroups.com ]
>>>>> On Behalf Of Emalayan Vairavanathan
>>>>> Sent: March-02-12 2:32 PM
>>>>> To: Jonathan Monette; Justin M Wozniak
>>>>> Cc: swift-devel at ci.uchicago.edu Devel; emalayan at ece.ubc.cais ;
>>>>> MosaStore
>>>>> Thank you Jon and Justin.
>>>>> This is a great news. I will get back to you if I have questions.
>>>>> Regards
>>>>> Emalayan
>>>>> To: Justin M Wozniak < wozniak at mcs.anl.gov >
>>>>> Cc: " swift-devel at ci.uchicago.edu Devel " <
>>>>> swift-devel at ci.uchicago.edu >; emalayan at ece.ubc.ca
>>>>> Sent: Friday, 2 March 2012 2:21 PM
>>>>> Emalayan,
>>>>> We believe we have fixed the issue. You can copy the new
>>>>> coasters-hosts.pl script from
>>>>> ~jonmon/surveyor/worker-init-test/coasters-hosts.pl
>>>>> This script reads the worker logs located in the logs directory.
>>>>> The
>>>>> steps to run are as follows:
>>>>> start-coaster-service
>>>>> <wait for workers to start>
>>>>> ./coasters-hosts.pl logs/worker-*.log > worker-hosts.txt
>>>>> You MUST clean out the worker logs after you before you start a new
>>>>> coaster service to make sure the script searches the right worker
>>>>> log
>>>>> files. This may not be ideal at the moment but this will help get
>>>>> you
>>>>> started. If you have any other questions feel free to ask. We will
>>>>> need to update the mosaswift site with the new information, we will
>>>>> do
>>>>> this soon.
>>>>> On Mar 2, 2012, at 11:26 AM, Jonathan Monette wrote:
>>>>>> Can we match this line: 2012/03/02 17:16:04.712 INFO - Running on
>>>>>> node 172.18.1.83 from the worker log,
>>>>>> instead of this line: 2012-03-02 17:21:25,214+0000 DEBUG Cpu
>>>>>> worker
>>>>>> started: block=2012.0302.171344.704 host=172.18.1.83 id=0 from the
>>>>>> cps log?
>>>>>> They both provide the same ip addresses. And the worker log always
>>>>>> has that ip address before the cps log does.
>>>>>> On Mar 2, 2012, at 11:15 AM, Jonathan Monette wrote:
>>>>>>> That fix still did not work. I had moved it to the same spot. It
>>>>>>> is
>>>>>>> still waiting for the worker-init.pl script to finish before the
>>>>>>> ip
>>>>>>> addresses are printed to the cps log. Those ip addresses are what
>>>>>>> is needed by the coaster-hosts.pl script to finish. If I create
>>>>>>> an
>>>>>>> empty file for the coaster-host.pl script to read, then the work
>>>>>>> continues and the ip addresses show up in the cps log.
>>>>>>> Why is log4j waiting to add those lines to the cps log after the
>>>>>>> worker-init.pl script is finished?
>>>>>>> On Mar 2, 2012, at 11:05 AM, Jonathan Monette wrote:
>>>>>>>> Thanks, in my copy I thought I had moved the reconnect to before
>>>>>>>> the init-cmd and it still wasn't working. I will test with your
>>>>>>>> change. I just verified that it was indeed waiting for the
>>>>>>>> worker-init.pl script to finish. I created an empty file for the
>>>>>>>> script to read and it finished connecting and the ip addresses I
>>>>>>>> needed were added to the cps log. I will also be testing your
>>>>>>>> fix.
>>>>>>>> On Mar 2, 2012, at 11:01 AM, Justin M Wozniak wrote:
>>>>>>>>> Yes- I must have tested this with a different log file. I just
>>>>>>>>> checked in and installed in ~wozniak/Public a fix for this that
>>>>>>>>> launches WORKER_INIT_CMD after the reconnect(). I am a little
>>>>>>>>> worried about time outs but it works so far. I will continue
>>>>>>>>> testing...
>>>>>>>>> Justin
>>>>>>>>> On Thu, 1 Mar 2012, Jonathan Monette wrote:
>>>>>>>>>> Justin,
>>>>>>>>>> So I have been trying to help Emalayan get the host list file
>>>>>>>>>> for the worker-init.pl script. It seems the cps log file is
>>>>>>>>>> not
>>>>>>>>>> providing the ip addresses for the coasters-hosts.pl script. I
>>>>>>>>>> thought this was maybe because we did not have the correct
>>>>>>>>>> log4j
>>>>>>>>>> setting set but we have the Coaster service Cpu set to DEBUG.
>>>>>>>>>> So
>>>>>>>>>> for some reason the workers are not connecting to the service.
>>>>>>>>>> When I comment out the export WORKER_ENVIRONEMTN="…" line in
>>>>>>>>>> the
>>>>>>>>>> coaster-service.conf file I see the workers connect and the
>>>>>>>>>> cps
>>>>>>>>>> log file shows there ip addresses. However when setting this
>>>>>>>>>> line it seems they are not connecting.
>>>>>>>>>> Emalayan thought there might be some sort of circular
>>>>>>>>>> dependency
>>>>>>>>>> going with the host-list file and the worker. The worker
>>>>>>>>>> requires the host-list file so that it can run the
>>>>>>>>>> worker-init.pl script and then connect but the host-list file
>>>>>>>>>> cannot be generated because the workers cannot connect. I
>>>>>>>>>> noticed in your swift-test directory the cps files did have
>>>>>>>>>> the
>>>>>>>>>> ip addresses set and coasters-hosts.pl found the ip addresses
>>>>>>>>>> and reported them. Did you try that test with setting the
>>>>>>>>>> WORKER_ENVIRONMENT variable in the coaster-service.conf file?
>>>>>>>>>> Any idea what may be happening? The job is running when
>>>>>>>>>> looking
>>>>>>>>>> under cqstat.
>>>>>>>>>> A side note: At the mosaswift site, your example talks about
>>>>>>>>>> running the coasters-hosts.pl on the cps log but the example
>>>>>>>>>> you
>>>>>>>>>> provide runs it on logs/coasters.log. This may need to be
>>>>>>>>>> changed. Also, should provide the log4j setting that is
>>>>>>>>>> required
>>>>>>>>>> to generate the Cpu line with the worker ip address just to
>>>>>>>>>> clarify that this line should be set for this script to work.
>>>>>>>>>> For reference, this line:
>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Cpu=DEBUG
>>>>>>>>> Justin M Wozniak
>>>>>>>> _______________________________________________
>>>>>>>> Swift-devel mailing list
>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>>> You received this message because you are subscribed to the Google
>>>>> Groups "MosaStore" group.
>>>>> To post to this group, send email to mosastore at googlegroups.com .
>>>>> To unsubscribe from this group, send email to
>>>>> mosastore+ unsubscribe at googlegroups.com .
>>>>> For more options, visit this group at
>>>>> http://groups.google.com/group/mosastore?hl=en .
>>>> Michael Wilde
>>>> Computation Institute, University of Chicago
>>>> Mathematics and Computer Science Division
>>>> Argonne National Laboratory
>>> To post to this group, send email to mosastore at googlegroups.com.
>>> mosastore+unsubscribe at googlegroups.com.
>>> http://groups.google.com/group/mosastore?hl=en.
>> Michael Wilde
Justin M Wozniak
