[Swift-devel] Need CDM Direct documentation - Re: Configuring Swift to access MosaStore
Ketan Maheshwari ketancmaheshwari at gmail.com
Mon Mar 5 18:52:47 CST 2012
Not really following this thread; here is my input:
I know that we (Justin and me) had to add a couple lines in the ~cdmlib.sh
in order to make it work correctly for the SCEC workflow. I have the
patched version somewhere in my dir, will dig it up.
In addition, I also observed that when the "* default " line is present in
the cdm files, it somehow did not work for me, so I had to remove it.
I did do some tests on combinations of absolute, relative, path in swift
script and the same in the cdm directory but do not recall results (nothing
unexpected happen).
I wrote some documentation on the CDM section, will dig up and get back.
On Mon, Mar 5, 2012 at 6:43 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Hi Ketan, Justin, or anyone else who has tried this recently:
> Could you point us to the documentation that you wrote on how to use CDM
> direct to obtain simple access to literal, untranslated, full path names?
> As I recall there were some subtleties on how to specify the name
> patterns, including matching both swiftwrap-observed names and file://
> names in vdl-int.k.
> Or is it simper then I recall?
> I have checked out the CDM "absolute" test that Emalayan mentioned below.
> Does that do a complete test of references to absolute names? And for only
> names below say /tmp/mosa?
> - Mike
> > From: "Emalayan Vairavanathan" <svemalayan at yahoo.com>
> > To: "Jonathan Monette" <jonmon at mcs.anl.gov>
> > Cc: "Michael Wilde" <wilde at mcs.anl.gov>, emalayan at ece.ubc.ca,
> matei at ece.ubc.ca, swift-devel at ci.uchicago.edu, "Jonathan
> > Monette" <jon.monette at gmail.com>, "MosaStore" <
> mosastore at googlegroups.com>
> > Sent: Monday, March 5, 2012 5:25:05 PM
> > Subject: Re: [Swift-devel] Configuring Swift to access MosaStore
> > Please find the attached setup.
> > Thank you
> > Emalayan
> > From: Jonathan Monette <jonmon at mcs.anl.gov>
> > To: Emalayan Vairavanathan <svemalayan at yahoo.com>
> > Cc: Michael Wilde <wilde at mcs.anl.gov>; "emalayan at ece.ubc.ca"
> > <emalayan at ece.ubc.ca>; "matei at ece.ubc.ca" <matei at ece.ubc.ca>;
> > "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>;
> > "mosastore at googlegroups.com" <mosastore at googlegroups.com>; Jonathan
> > Monette <jon.monette at gmail.com>
> > Sent: Monday, 5 March 2012 3:07 PM
> > If you could provide the set up you were using that would be great. I
> > can fill in anything missing an do my tests to verify.
> > On Mar 5, 2012, at 13:34, Emalayan Vairavanathan <
> > svemalayan at yahoo.com > wrote:
> > Thank you Jon.
> > Yesterday I successfully run Mosa (on our cluster) with cdm-direct
> > mode with the help of swift-user manual and the scripts available in
> > /cog/modules/swift/tests/cdm/absolute .
> > It would be useful if you can develop a simple test case. I can double
> > check with my test case.
> > Thank you
> > Emalayan
> > From: Jonathan Monette < jonmon at mcs.anl.gov >
> > To: Michael Wilde < wilde at mcs.anl.gov >
> > Cc: " emalayan at ece.ubc.ca " < emalayan at ece.ubc.ca >; "
> > matei at ece.ubc.ca " < matei at ece.ubc.ca >; " swift-devel at ci.uchicago.edu
> > " < swift-devel at ci.uchicago.edu >; " mosastore at googlegroups.com " <
> > mosastore at googlegroups.com >; Jonathan Monette < jon.monette at gmail.com
> > Sent: Monday, 5 March 2012 7:14 AM
> > Yea. I will get demo scripts together for the mosa tests.
> > On Mar 5, 2012, at 8:17, Michael Wilde < wilde at mcs.anl.gov > wrote:
> > > was: Re: [Swift-devel] coasters-hosts.pl script
> > > Jon, can you create a demo script that shows how to configure a
> > > Swift run to use MosaStore. The following approach may work:
> > > - Assume MosaStore will be mounted as /mosa to all workers
> > > - Simulate this with a localhost run, using /tmp/mosa, then do same
> > > with *1* worker, N jobs per node (eg 4 on BG/P, 8 on PADS, 2 on
> > > Beagle).
> > > - Set CDM direct mode for all paths starting with [/tmp]/mosa. You
> > > might need to work through some of the issues with CDM direct where
> > > accesses need to match both /tmp/mosa and file:///tmp/mosa (I
> > > *think*)
> > > - Map some temporary output-to-input files to /tmp/mosa; create a
> > > multi-level "catsncats"-like workflow to exercise it; the recent
> > > ParameterSweep example, perhaps extended to do N levels of
> > > fan-in/fan-out and pass-N might be a good test.
> > > - see if you can get _concurrent to get placed on /tmp/mosa
> > > I think some of these tests would be a great test case for
> > > Swift/Turbine as well.
> > > You can do this is stages; the simple test of mapping CDM-direct
> > > files to /tmp/mosa should give Emalayan an initial test case to run
> > > once Mosa is ready on the BG/P.
> > > - Mike
> > >> From: "Matei Ripeanu" < matei.ripeanu at gmail.com >
> > >> To: mosastore at googlegroups.com , "Jonathan Monette" <
> > >> jonmon at mcs.anl.gov >, "Justin M Wozniak" < wozniak at mcs.anl.gov >
> > >> Cc: swift-devel at ci.uchicago.edu , emalayan at ece.ubc.ca
> > >> Sent: Friday, March 2, 2012 6:29:17 PM
> > >> Subject: Re: [Swift-devel] coasters-hosts.pl script
> > >> Indeed this is good news! Thank you.
> > >> Our next task, I think, will be to figure out how to configure
> > >> Swift
> > >> so that the headnode (where Swift runs) will not require any access
> > >> to
> > >> intermediate storage (MosaStore). Only the worker nodes will have
> > >> access to intermediate storage. This is to go around the one way
> > >> headnode-worker node connectivity issue.
> > >> Any guidance on how to get this configuration would be much
> > >> appreciated.
> > >> Thank you again,
> > >> -Matei
> > >> From: mosastore at googlegroups.com [mailto:
> > >> mosastore at googlegroups.com ]
> > >> On Behalf Of Emalayan Vairavanathan
> > >> Sent: March-02-12 2:32 PM
> > >> To: Jonathan Monette; Justin M Wozniak
> > >> Cc: swift-devel at ci.uchicago.edu Devel; emalayan at ece.ubc.cais ;
> > >> MosaStore
> > >> Thank you Jon and Justin.
> > >> This is a great news. I will get back to you if I have questions.
> > >> Regards
> > >> Emalayan
> > >> To: Justin M Wozniak < wozniak at mcs.anl.gov >
> > >> Cc: " swift-devel at ci.uchicago.edu Devel " <
> > >> swift-devel at ci.uchicago.edu >; emalayan at ece.ubc.ca
> > >> Sent: Friday, 2 March 2012 2:21 PM
> > >> Emalayan,
> > >> We believe we have fixed the issue. You can copy the new
> > >> coasters-hosts.pl script from
> > >> ~jonmon/surveyor/worker-init-test/coasters-hosts.pl
> > >> This script reads the worker logs located in the logs directory.
> > >> The
> > >> steps to run are as follows:
> > >> start-coaster-service
> > >> <wait for workers to start>
> > >> ./coasters-hosts.pl logs/worker-*.log > worker-hosts.txt
> > >> You MUST clean out the worker logs after you before you start a new
> > >> coaster service to make sure the script searches the right worker
> > >> log
> > >> files. This may not be ideal at the moment but this will help get
> > >> you
> > >> started. If you have any other questions feel free to ask. We will
> > >> need to update the mosaswift site with the new information, we will
> > >> do
> > >> this soon.
> > >> On Mar 2, 2012, at 11:26 AM, Jonathan Monette wrote:
> > >>> Can we match this line: 2012/03/02 17:16:04.712 INFO - Running on
> > >>> node 172.18.1.83 from the worker log,
> > >>> instead of this line: 2012-03-02 17:21:25,214+0000 DEBUG Cpu
> > >>> worker
> > >>> started: block=2012.0302.171344.704 host=172.18.1.83 id=0 from the
> > >>> cps log?
> > >>> They both provide the same ip addresses. And the worker log always
> > >>> has that ip address before the cps log does.
> > >>> On Mar 2, 2012, at 11:15 AM, Jonathan Monette wrote:
> > >>>> That fix still did not work. I had moved it to the same spot. It
> > >>>> is
> > >>>> still waiting for the worker-init.pl script to finish before the
> > >>>> ip
> > >>>> addresses are printed to the cps log. Those ip addresses are what
> > >>>> is needed by the coaster-hosts.pl script to finish. If I create
> > >>>> an
> > >>>> empty file for the coaster-host.pl script to read, then the work
> > >>>> continues and the ip addresses show up in the cps log.
> > >>>> Why is log4j waiting to add those lines to the cps log after the
> > >>>> worker-init.pl script is finished?
> > >>>> On Mar 2, 2012, at 11:05 AM, Jonathan Monette wrote:
> > >>>>> Thanks, in my copy I thought I had moved the reconnect to before
> > >>>>> the init-cmd and it still wasn't working. I will test with your
> > >>>>> change. I just verified that it was indeed waiting for the
> > >>>>> worker-init.pl script to finish. I created an empty file for the
> > >>>>> script to read and it finished connecting and the ip addresses I
> > >>>>> needed were added to the cps log. I will also be testing your
> > >>>>> fix.
> > >>>>> On Mar 2, 2012, at 11:01 AM, Justin M Wozniak wrote:
> > >>>>>> Yes- I must have tested this with a different log file. I just
> > >>>>>> checked in and installed in ~wozniak/Public a fix for this that
> > >>>>>> launches WORKER_INIT_CMD after the reconnect(). I am a little
> > >>>>>> worried about time outs but it works so far. I will continue
> > >>>>>> testing...
> > >>>>>> Justin
> > >>>>>> On Thu, 1 Mar 2012, Jonathan Monette wrote:
> > >>>>>>> Justin,
> > >>>>>>> So I have been trying to help Emalayan get the host list file
> > >>>>>>> for the worker-init.pl script. It seems the cps log file is
> > >>>>>>> not
> > >>>>>>> providing the ip addresses for the coasters-hosts.pl script. I
> > >>>>>>> thought this was maybe because we did not have the correct
> > >>>>>>> log4j
> > >>>>>>> setting set but we have the Coaster service Cpu set to DEBUG.
> > >>>>>>> So
> > >>>>>>> for some reason the workers are not connecting to the service.
> > >>>>>>> When I comment out the export WORKER_ENVIRONEMTN="…" line in
> > >>>>>>> the
> > >>>>>>> coaster-service.conf file I see the workers connect and the
> > >>>>>>> cps
> > >>>>>>> log file shows there ip addresses. However when setting this
> > >>>>>>> line it seems they are not connecting.
> > >>>>>>> Emalayan thought there might be some sort of circular
> > >>>>>>> dependency
> > >>>>>>> going with the host-list file and the worker. The worker
> > >>>>>>> requires the host-list file so that it can run the
> > >>>>>>> worker-init.pl script and then connect but the host-list file
> > >>>>>>> cannot be generated because the workers cannot connect. I
> > >>>>>>> noticed in your swift-test directory the cps files did have
> > >>>>>>> the
> > >>>>>>> ip addresses set and coasters-hosts.pl found the ip addresses
> > >>>>>>> and reported them. Did you try that test with setting the
> > >>>>>>> WORKER_ENVIRONMENT variable in the coaster-service.conf file?
> > >>>>>>> Any idea what may be happening? The job is running when
> > >>>>>>> looking
> > >>>>>>> under cqstat.
> > >>>>>>> A side note: At the mosaswift site, your example talks about
> > >>>>>>> running the coasters-hosts.pl on the cps log but the example
> > >>>>>>> you
> > >>>>>>> provide runs it on logs/coasters.log. This may need to be
> > >>>>>>> changed. Also, should provide the log4j setting that is
> > >>>>>>> required
> > >>>>>>> to generate the Cpu line with the worker ip address just to
> > >>>>>>> clarify that this line should be set for this script to work.
> > >>>>>>> For reference, this line:
> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Cpu=DEBUG
> > >>>>>> Justin M Wozniak
> > >>>>> _______________________________________________
> > >>>>> Swift-devel mailing list
> > >>>>> Swift-devel at ci.uchicago.edu
> > >>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > >> You received this message because you are subscribed to the Google
> > >> Groups "MosaStore" group.
> > >> To post to this group, send email to mosastore at googlegroups.com .
> > >> To unsubscribe from this group, send email to
> > >> mosastore+ unsubscribe at googlegroups.com .
> > >> For more options, visit this group at
> > >> http://groups.google.com/group/mosastore?hl=en .
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> > To post to this group, send email to mosastore at googlegroups.com.
> > mosastore+unsubscribe at googlegroups.com.
> > http://groups.google.com/group/mosastore?hl=en.
> Michael Wilde
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120305/44c6a15f/attachment.html>
