[Swift-devel] [ZeptoOS] hostname  returns none in Surveyor
    Emalayan Vairavanathan
    svemalayan at yahoo.com
    Sun Mar  4 18:54:25 CST 2012
Zhao, Thank you, I think this is not going to work with allocations with fraction of PSET. Please see below (I have pasted personality.sh with 2 node )
May be we need to get it from other sources. Or may be swift can pass this information to workers once the connection has been established.
Regards
Emalayan
BG_UCI=68021700
BG_LOCATION=R00-M0-N08-J23
BG_MAC=12:01:13:80:00:00
BG_IP=172.18.1.19
BG_NETMASK=255.240.0.0
BG_BROADCAST=172.32.255.255
BG_GATEWAY=172.16.3.5
BG_MTU=9000
BG_FS=172.17.3.1
BG_EXPORTDIR="/bgsys"
BG_SIMULATION=0
BG_PSETNUM=0
BG_NUMPSETS=1
BG_NODESINPSET=64
BG_XSIZE=4
BG_YSIZE=4
BG_ZSIZE=4
BG_VERBOSE=0
BG_PSETSIZE="4 4 4"
BG_PSETORG="0 0 0"
BG_CLOCKHZ=850
BG_GLINTS=1
BG_ISTORUS="XYZ"
BG_BLOCKID="ANL-R00-M0-N08-64"
BG_SN=172.17.3.1
BG_IS_IO_NODE=0
BG_RANK_IN_PSET=64
BG_RANK=0
BG_IP_OVER_COL=0
BG_IP_OVER_TOR=0
BG_IP_OVER_COL_VC=0
BG_CIO_MODE=FULL
BG_BGSYS_FS_TYPE=NFSv3
BG_HTC_MODE=0
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: Michael Wilde <wilde at mcs.anl.gov>; Justin M Wozniak <wozniak at mcs.anl.gov>; "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>
Sent: Sunday, 4 March 2012 4:28 PM
Subject: Re: [Swift-devel] [ZeptoOS] hostname  returns none in Surveyor
I am attaching one personality.sh file of a 4096 CN allocation. From
    that you can see, there are couple of ways to calculate the
allocation size:
1) BG_BLOCKID="ANL-R10-R13-4096"
2) Multiplication of BG_XSIZE, BG_YSIZE, BG_ZSIZE
I am not quite sure how it will work on allocation that is smaller
    than 64, you could simply give it a check.
best
zhao
BG_UCI=68801700
BG_LOCATION=R10-M0-N00-J23
BG_MAC=00:00:00:00:00:00
BG_IP=0.0.0.0
BG_NETMASK=255.255.255.112
BG_BROADCAST=0.0.0.0
BG_GATEWAY=0.0.0.0
BG_MTU=1536
BG_FS=0.0.0.0
BG_EXPORTDIR=""
BG_SIMULATION=0
BG_PSETNUM=0
BG_NUMPSETS=64
BG_NODESINPSET=64
BG_XSIZE=8
BG_YSIZE=16
BG_ZSIZE=32
BG_VERBOSE=0
BG_PSETSIZE="4 4 4"
BG_PSETORG="0 0 0"
BG_CLOCKHZ=850
BG_GLINTS=1
BG_ISTORUS=""
BG_SN=0.0.0.0
BG_IS_IO_NODE=0
BG_RANK_IN_PSET=64
BG_RANK=0
BG_IP_OVER_COL=0
BG_IP_OVER_TOR=0
BG_IP_OVER_COL_VC=0
BG_CIO_MODE=FULL
BG_HTC_MODE=0
On 3/4/2012 6:23 PM, Emalayan Vairavanathan wrote:
Zhao, Thank you very much for the answers.
>One more question: :)
>Do you know how I can calculate this ? Does this method works regardless of the number of nodes allocated (even with any fraction of pset ) ?
>Thank you
>Emalayan
>________________________________
> From: ZHAO ZHANG <zhaozhang at uchicago.edu>
>Sent: Sunday, 4 March 2012 4:06 PM
>Hi, Emalayan
>On 3/4/2012 6:00 PM, Emalayan Vairavanathan wrote:
>Mike, that sounds like a good idea.
>>Zhao, In addition to Mike's questions I have two more questions.
>>1) Is it possible to get/ calculate the MAX_RANK / number of nodes in an allocation from persoanlity.h or some other data structure  ?
Yes, you could calculate the MAX_RANK from personality.sh.
>>2) Which interface should be configured to have Tours ? (Does this matter at all ?)
>>    In your scripts you are configuring eth1. But in  http://wiki.mcs.anl.gov/zeptoos/index.php/Other_Packages tun1 is configured.
To use the torus network, there are two ways. One is to use the 12.x.y.z+1 interface, which we have to configure ourselves.
>The other way is to use the "ipfwd.sh", aka the 10.128
                interface. The drawback of the second interface is it
                takes up one core
>for polling, and there is some scalability issue beyond
                2K compute nodes as far as I remember. Mosa could use
                either of them.
>best
>zhao
>>Thank you
>>Emalayan
>> From: Michael Wilde <wilde at mcs.anl.gov>
>>To: ZHAO ZHANG <zhaozhang at uchicago.edu>; Justin M Wozniak <wozniak at mcs.anl.gov>
>>Cc: Emalayan Vairavanathan <svemalayan at yahoo.com>; swift-devel at ci.uchicago.edu
>>Sent: Sunday, 4 March 2012 2:33 PM
>>Zhao, with this procedure do you get consecutive
                        host IP addresses starting from 0.0 through
                        640*64 in the two low order octets?
>>In other words, does your  just do what this
                        page describes under "IP over Torus":
>>Is the "ipfwd.sh" script mentioned there still
                        needed, or does that now happen automatically?
>>If so, perhaps we can greatly simplify the Mosa
                        startup: we need only pass the max rank of the
                        running job, and Mosa will know that it can use
                        12.128.0.0 for example.  Then we dont need any
                        manual intervention, nor complicated/brittle
                        file-waiting logic.
>>Zhao, I dont understand why your example is
                        using the 12.0.0.0 network vs the example on the
                        page above which uses 10.128.0.0. Can you help
                        me understand what is going on here? Is the "IP
                        Over Torus" info on the ZeptoOS wiki outdated?
                        Or does it describe a different technique?
>>Justin, have you also mastered similar
                        techniques for JETS?  Do we need help form the
                        ZeptoOS team on this?
>>Thanks,
>>- Mike
>>----- Original Message -----
>>> From: "ZHAO ZHANG" <zhaozhang at uchicago.edu>
>>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>>> Cc: "Emalayan Vairavanathan" <svemalayan at yahoo.com>, swift-devel at ci.uchicago.edu
>>> Sent: Sunday, March 4, 2012 1:17:18 PM
>>> Yes, each compute node needs to run this
                        script to bring up the
>>> network
>>> interface.
>>> zhao
>>> On 3/4/2012 12:53 PM, Michael Wilde wrote:
>>> > Thanks, Zhao. Does this need to run on
                        each node at startup?
>>> > If so should this logic be integrated
                        into the worker startup
>>> > script, Jon, Justin, Emalayan?
>>> > Ive not looked at the current scripts
                        much; I would think that all
>>> > the BG/P specific logic of enabling
                        the torus network and finding
>>> > each node's IP address on the torus
                        should be done in the init
>>> > script rather than in the worker.
>>> > - Mike
>>> >> From: "ZHAO ZHANG"<zhaozhang at uchicago.edu>
>>> >> To: "Michael Wilde"<wilde at mcs.anl.gov>
>>> >> Cc: "Emalayan Vairavanathan"<svemalayan at yahoo.com>,
                        12:18:28 PM
>>> >> Surveyor
>>> >> Hi, Mike
>>> >> With 192.168.1.*, we could only
                        access the tree network. In order
>>> >> to
>>> >> use
>>> >> the torus network, we need to use
                        the 12.x.y.z+1 ip address. (x, y,
>>> >> z
>>> >> here is the coordinates of the
                        compute nodes).
>>> >> The code below could bring the
                        torus ip address up.
>>> >> IP=""
>>> >> set_torus_ip()
>>> >> x=$1
>>> >> y=$2
>>> >> z=$3
>>> >> z=`expr $3 + 1`
>>> >> ifconfig eth1 12.$x.$y.$z netmask
                        255.0.0.0 mtu 8996 -arp
>>> >> IP=12.$x.$y.$z
>>> >> BG_PSETORG=`cat
                        /proc/personality.sh | grep BG_PSETORG | cut -d
>>> >> -f
>>> >> 2`
>>> >> echo ${BG_PSETORG}>>
                        /dev/shm/localip
>>> >> set_torus_ip $BG_PSETORG
>>> >> best
>>> >> zhao
>>> >> On 3/4/2012 10:24 AM, Michael
                        Wilde wrote:
>>> >>> Zhao,
>>> >>> Can you tell us if the nodes
                        on the torus network are accessed
>>> >>> over
>>> >>> the 192.168 network? I just
                        realized they cant all be on the
>>> >>> 192.168.1 subnet, so I hope I
                        suggested the right network here.
>>> >>> Thanks,
>>> >>> - Mike
>>> >>>> From: "Emalayan
>>> >>>> To: swift-devel at ci.uchicago.edu
                        2012 1:40:53 AM
>>> >>>> Surveyor
>>> >>>> Thank you very much Mike.
                        I agree with you suggestion. I can do
>>> >>>> that
>>> >>>> in worker.pl.
>>> >>>> Thank you
>>> >>>> Emalayan
>>> >>>> From: Michael Wilde<wilde at mcs.anl.gov>
>>> >>>> To: emalayan at ece.ubc.ca
>>> >>>> Cc: swift-devel<swift-devel at ci.uchicago.edu>
>>> >>>> Sent: Saturday, 3 March
                        2012 7:39 PM
>>> >>>> Surveyor
>>> >>>> Emalayan,
>>> >>>> I wasnt paying much
                        attention to the actual IP address returned
>>> >>>> by
>>> >>>> hostname in the zeptoos
                        profile.
>>> >>>> Since these are the
                        addresses that Mosa will communicate over, I
>>> >>>> think
>>> >>>> you *do* want them to be
                        the 192.168.1.* addresses of the nodes
>>> >>>> on
>>> >>>> the
>>> >>>> torus network (in other
                        words tun0).
>>> >>>> So, since both profiles
                        return 192.168.1.64 for the tun0 IP, I
>>> >>>> think
>>> >>>> thats what you should use.
                        So try replacing `hostname` in
>>> >>>> worker.pl
>>> >>>> with something like:
>>> >>>> `ifconfig | grep 192.168 |
                        sed -e 's/^inet addr://' -e 's/ .*//'`
>>> >>>> You may have to adapt this
                        a bit to meet your needs. Im assuming
>>> >>>> that
>>> >>>> the only code that will
                        uses these IPs is MosaStore.
>>> >>>> - Mike
>>> >>>>> From: "Kazutomo
                        Yoshii"< kazutomo at mcs.anl.gov>
>>> >>>>> To: zeptoos at lists.mcs.anl.gov
>>> >>>>> Sent: Saturday, March
                        3, 2012 8:52:00 PM
>>> >>>>> Subject: Re: [ZeptoOS]
>>> >>>>> Hi Emalayan,
>>> >>>>> The zeptoos profile
                        returns the IP address of associated I/O
>>> >>>>> node,
>>> >>>>> which is kind of wrong
                        in my opinion (influence of IBM CNK).
>>> >>>>> ifconfig on compute
                        nodes returns CN's IP address, which is
>>> >>>>> correct.
>>> >>>>> e.g. tun0 192.168.1.64
>>> >>>>> If you want to find
                        associated ION's IP address from CNs,
>>> >>>>> do something like
                        this.
>>> >>>>> $ grep BG_IP=
>>> >>>>> - kaz
>>> >>>>> On 03/03/2012 08:25
>>> >>>>>> Hi All,
>>> >>>>>> I am trying to run
                        some experiments in Surveyor. The software I
>>> >>>>>> am
>>> >>>>>> using
>>> >>>>>> gets the
                        IP-address of compute-nodes using hostname
                        command.
>>> >>>>>> With
                        zepto-vn-eval/mosatest profile hostname command
                        returns
>>> >>>>>> none.
>>> >>>>>> But with zeptoos
                        profile hostname returns the correct IP
>>> >>>>>> address.
>>> >>>>>> Is this due to
                        some configuration issues in
>>> >>>>>> profile?As a
                        workaround I tired to use ifconfig with both
>>> >>>>>> profiles,
>>> >>>>>> but
>>> >>>>>> it seems ifconfig
                        is not returning the correct IP address.
>>> >>>>>> Is there any
                        command / files which I can used to retrieve the
>>> >>>>>> hostname
>>> >>>>>> on compute nodes?
                        I have pasted the console output with both
>>> >>>>>> profiles
>>> >>>>>> below. Please let
                        me know if you need more details.
>>> >>>>>> Thank you
>>> >>>>>> Emalayan
                        =======================With zeptoos profile
>>> >>>>>> / # hostname
>>> >>>>>> 172.18.3.19
>>> >>>>>> / # cat
                        /proc/sys/kernel/hostname
>>> >>>>>> 172.18.3.19
>>> >>>>>> / # ifconfig -a
>>> >>>>>> lo Link
                        encap:Local Loopback
>>> >>>>>> inet
                        addr:127.0.0.1 Mask:255.0.0.0
>>> >>>>>> UP LOOPBACK
                        RUNNING MTU:16436 Metric:1
>>> >>>>>> RX packets:0
                        errors:0 dropped:0 overruns:0 frame:0
>>> >>>>>> TX packets:0
                        errors:0 dropped:0 overruns:0 carrier:0
>>> >>>>>> collisions:0
                        txqueuelen:0
>>> >>>>>> RX bytes:0 (0.0 B)
                        TX bytes:0 (0.0 B)
>>> >>>>>> tun0 Link
                        encap:UNSPEC HWaddr
                        00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
>>> >>>>>> inet
                        addr:192.168.1.64 P-t-P:192.168.1.254
                        Mask:255.255.255.255
>>> >>>>>> UP POINTOPOINT
                        RUNNING NOARP MULTICAST MTU:65535 Metric:1
>>> >>>>>> RX packets:2662
>>> >>>>>> TX packets:1772
>>> >>>>>> collisions:0
                        txqueuelen:500
>>> >>>>>> RX bytes:140206
                        (136.9 KiB) TX bytes:125412 (122.4 KiB)
>>> >>>>>> /etc # hostname
>>> >>>>>> (none)
>>> >>>>>> /etc #
>>> >>>>>> /etc # cat
>>> >>>>>> (none)
>>> >>>>>> /etc #
>>> >>>>>> /etc # ifconfig -a
>>> >>>>>> eth0 Link
                        encap:Ethernet HWaddr 00:80:46:00:00:00
>>> >>>>>> BROADCAST
                        MULTICAST MTU:1500 Metric:1
>>> >>>>>> RX packets:0
>>> >>>>>> TX packets:0
>>> >>>>>> collisions:0
                        txqueuelen:1000
>>> >>>>>> RX bytes:0 (0.0 B)
                        TX bytes:0 (0.0 B)
>>> >>>>>> eth1 Link
                        encap:Ethernet HWaddr 00:80:47:00:00:00
>>> >>>>>> BROADCAST
>>> >>>>>> RX packets:0
>>> >>>>>> TX packets:0
>>> >>>>>> collisions:0
                        txqueuelen:1000
>>> >>>>>> RX bytes:0 (0.0 B)
                        TX bytes:0 (0.0 B)
>>> >>>>>> lo Link
>>> >>>>>> inet
>>> >>>>>> inet6 addr:
                        ::1/128 Scope:Host
>>> >>>>>> UP LOOPBACK
>>> >>>>>> RX packets:0
>>> >>>>>> TX packets:0
>>> >>>>>> collisions:0
                        txqueuelen:0
>>> >>>>>> RX bytes:0 (0.0 B)
                        TX bytes:0 (0.0 B)
>>> >>>>>> sit0 Link
                        encap:IPv6-in-IPv4
>>> >>>>>> NOARP MTU:1480
                        Metric:1
>>> >>>>>> RX packets:0
>>> >>>>>> TX packets:0
>>> >>>>>> collisions:0
                        txqueuelen:0
>>> >>>>>> RX bytes:0 (0.0 B)
                        TX bytes:0 (0.0 B)
>>> >>>>>> tun0 Link
                        encap:UNSPEC HWaddr
>>> >>>>>> inet
>>> >>>>>> UP POINTOPOINT
>>> >>>>>> RX packets:965
>>> >>>>>> TX packets:627
>>> >>>>>> collisions:0
                        txqueuelen:500
>>> >>>>>> RX bytes:50984
                        (49.7 KiB) TX bytes:50530 (49.3 KiB)
>>> >>>> Michael Wilde
>>> >>>> Computation Institute,
                        University of Chicago
>>> >>>> Mathematics and Computer
                        Science Division
>>> >>>> Argonne National
                        Laboratory
>>> >>>> Swift-devel mailing list
>>> >>>> Swift-devel at ci.uchicago.edu
>>> >>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>Michael Wilde
>>Computation Institute, University of Chicago
>>Mathematics and Computer Science Division
>>Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120304/9ce2c069/attachment.html>
