[Swift-devel] [ZeptoOS] hostname returns none in Surveyor
ZHAO ZHANG zhaozhang at uchicago.edu
Sun Mar 4 18:28:08 CST 2012
I am attaching one personality.sh file of a 4096 CN allocation. From
that you can see, there are couple of ways to calculate the
allocation size:
1) BG_BLOCKID="ANL-R10-R13-4096"
2) Multiplication of BG_XSIZE, BG_YSIZE, BG_ZSIZE
I am not quite sure how it will work on allocation that is smaller than
64, you could simply give it a check.
best
zhao
BG_UCI=68801700
BG_LOCATION=R10-M0-N00-J23
BG_MAC=00:00:00:00:00:00
BG_IP=0.0.0.0
BG_NETMASK=255.255.255.112
BG_BROADCAST=0.0.0.0
BG_GATEWAY=0.0.0.0
BG_MTU=1536
BG_FS=0.0.0.0
BG_EXPORTDIR=""
BG_SIMULATION=0
BG_PSETNUM=0
BG_NUMPSETS=64
BG_NODESINPSET=64
BG_XSIZE=8
BG_YSIZE=16
BG_ZSIZE=32
BG_VERBOSE=0
BG_PSETSIZE="4 4 4"
BG_PSETORG="0 0 0"
BG_CLOCKHZ=850
BG_GLINTS=1
BG_ISTORUS=""
BG_SN=0.0.0.0
BG_IS_IO_NODE=0
BG_RANK_IN_PSET=64
BG_RANK=0
BG_IP_OVER_COL=0
BG_IP_OVER_TOR=0
BG_IP_OVER_COL_VC=0
BG_CIO_MODE=FULL
BG_BGSYS_FS_TYPE=NFSv3
BG_HTC_MODE=0
On 3/4/2012 6:23 PM, Emalayan Vairavanathan wrote:
> Zhao, Thank you very much for the answers.
> One more question: :)
> Do you know how I can calculate this ? Does this method works
> regardless of the number of nodes allocated (even with any fraction of
> pset ) ?
> Thank you
> Emalayan
> *From:* ZHAO ZHANG <zhaozhang at uchicago.edu>
> *To:* Emalayan Vairavanathan <svemalayan at yahoo.com>
> *Cc:* Michael Wilde <wilde at mcs.anl.gov>; Justin M Wozniak
> <wozniak at mcs.anl.gov>; "swift-devel at ci.uchicago.edu"
> <swift-devel at ci.uchicago.edu>
> *Sent:* Sunday, 4 March 2012 4:06 PM
> *Subject:* Re: [Swift-devel] [ZeptoOS] hostname returns none in Surveyor
> Hi, Emalayan
> On 3/4/2012 6:00 PM, Emalayan Vairavanathan wrote:
>> Mike, that sounds like a good idea.
>> Zhao, In addition to Mike's questions I have two more questions.
>> 1) Is it possible to get/ calculate the MAX_RANK / number of nodes in
>> an allocation from persoanlity.h or some other data structure  ?
> Yes, you could calculate the MAX_RANK from personality.sh.
>> 2) Which interface should be configured to have Tours ? (Does this
>> matter at all ?)
>>     In your scripts you are configuring eth1. But in
>> http://wiki.mcs.anl.gov/zeptoos/index.php/Other_Packages tun1 is
>> configured.
> To use the torus network, there are two ways. One is to use the
> 12.x.y.z+1 interface, which we have to configure ourselves.
> The other way is to use the "ipfwd.sh", aka the 10.128 interface. The
> drawback of the second interface is it takes up one core
> for polling, and there is some scalability issue beyond 2K compute
> nodes as far as I remember. Mosa could use either of them.
> best
> zhao
>> Thank you
>> Emalayan
>> *From:* Michael Wilde <wilde at mcs.anl.gov> <mailto:wilde at mcs.anl.gov>
>> *To:* ZHAO ZHANG <zhaozhang at uchicago.edu>
>> <mailto:zhaozhang at uchicago.edu>; Justin M Wozniak
>> <wozniak at mcs.anl.gov> <mailto:wozniak at mcs.anl.gov>
>> *Cc:* Emalayan Vairavanathan <svemalayan at yahoo.com>
>> <mailto:svemalayan at yahoo.com>; swift-devel at ci.uchicago.edu
>> <mailto:swift-devel at ci.uchicago.edu>
>> *Sent:* Sunday, 4 March 2012 2:33 PM
>> Zhao, with this procedure do you get consecutive host IP addresses
>> starting from 0.0 through 640*64 in the two low order octets?
>> In other words, does your  just do what this page describes under "IP
>> over Torus":
>> Is the "ipfwd.sh" script mentioned there still needed, or does that
>> now happen automatically?
>> If so, perhaps we can greatly simplify the Mosa startup: we need only
>> pass the max rank of the running job, and Mosa will know that it can
>> use 12.128.0.0 for example.  Then we dont need any manual
>> intervention, nor complicated/brittle file-waiting logic.
>> Zhao, I dont understand why your example is using the 12.0.0.0
>> network vs the example on the page above which uses 10.128.0.0. Can
>> you help me understand what is going on here? Is the "IP Over Torus"
>> info on the ZeptoOS wiki outdated? Or does it describe a different
>> technique?
>> Justin, have you also mastered similar techniques for JETS?  Do we
>> need help form the ZeptoOS team on this?
>> Thanks,
>> - Mike
>> ----- Original Message -----
>> > From: "ZHAO ZHANG" <zhaozhang at uchicago.edu
>> <mailto:zhaozhang at uchicago.edu>>
>> > To: "Michael Wilde" <wilde at mcs.anl.gov <mailto:wilde at mcs.anl.gov>>
>> > Cc: "Emalayan Vairavanathan" <svemalayan at yahoo.com
>> <mailto:svemalayan at yahoo.com>>, swift-devel at ci.uchicago.edu
>> > Sent: Sunday, March 4, 2012 1:17:18 PM
>> > Subject: Re: [Swift-devel] [ZeptoOS] hostname returns none in Surveyor
>> > Yes, each compute node needs to run this script to bring up the
>> > network
>> > interface.
>> > zhao
>> > On 3/4/2012 12:53 PM, Michael Wilde wrote:
>> > > Thanks, Zhao. Does this need to run on each node at startup?
>> > > If so should this logic be integrated into the worker startup
>> > > script, Jon, Justin, Emalayan?
>> > > Ive not looked at the current scripts much; I would think that all
>> > > the BG/P specific logic of enabling the torus network and finding
>> > > each node's IP address on the torus should be done in the init
>> > > script rather than in the worker.
>> > > - Mike
>> > >> From: "ZHAO ZHANG"<zhaozhang at uchicago.edu
>> > >> To: "Michael Wilde"<wilde at mcs.anl.gov <mailto:wilde at mcs.anl.gov>>
>> > >> Cc: "Emalayan Vairavanathan"<svemalayan at yahoo.com
>> > >> swift-devel at ci.uchicago.edu <mailto:swift-devel at ci.uchicago.edu>
>> > >> Sent: Sunday, March 4, 2012 12:18:28 PM
>> > >> Surveyor
>> > >> Hi, Mike
>> > >> With 192.168.1.*, we could only access the tree network. In order
>> > >> to
>> > >> use
>> > >> the torus network, we need to use the 12.x.y.z+1 ip address. (x, y,
>> > >> z
>> > >> here is the coordinates of the compute nodes).
>> > >> The code below could bring the torus ip address up.
>> > >> IP=""
>> > >> set_torus_ip()
>> > >> x=$1
>> > >> y=$2
>> > >> z=$3
>> > >> z=`expr $3 + 1`
>> > >> ifconfig eth1 12.$x.$y.$z netmask 255.0.0.0 mtu 8996 -arp
>> > >> IP=12.$x.$y.$z
>> > >> BG_PSETORG=`cat /proc/personality.sh | grep BG_PSETORG | cut -d '"'
>> > >> -f
>> > >> 2`
>> > >> echo ${BG_PSETORG}>> /dev/shm/localip
>> > >> set_torus_ip $BG_PSETORG
>> > >> best
>> > >> zhao
>> > >> On 3/4/2012 10:24 AM, Michael Wilde wrote:
>> > >>> Zhao,
>> > >>> Can you tell us if the nodes on the torus network are accessed
>> > >>> over
>> > >>> the 192.168 network? I just realized they cant all be on the
>> > >>> 192.168.1 subnet, so I hope I suggested the right network here.
>> > >>> Thanks,
>> > >>> - Mike
>> > >>>> From: "Emalayan Vairavanathan"<svemalayan at yahoo.com
>> > >>>> To: swift-devel at ci.uchicago.edu
>> > >>>> Sent: Sunday, March 4, 2012 1:40:53 AM
>> > >>>> Surveyor
>> > >>>> Thank you very much Mike. I agree with you suggestion. I can do
>> > >>>> that
>> > >>>> in worker.pl.
>> > >>>> Thank you
>> > >>>> Emalayan
>> > >>>> From: Michael Wilde<wilde at mcs.anl.gov <mailto:wilde at mcs.anl.gov>>
>> > >>>> To: emalayan at ece.ubc.ca <mailto:emalayan at ece.ubc.ca>
>> > >>>> Cc: swift-devel<swift-devel at ci.uchicago.edu
>> <mailto:swift-devel at ci.uchicago.edu>>
>> > >>>> Sent: Saturday, 3 March 2012 7:39 PM
>> > >>>> Surveyor
>> > >>>> Emalayan,
>> > >>>> I wasnt paying much attention to the actual IP address returned
>> > >>>> by
>> > >>>> hostname in the zeptoos profile.
>> > >>>> Since these are the addresses that Mosa will communicate over, I
>> > >>>> think
>> > >>>> you *do* want them to be the 192.168.1.* addresses of the nodes
>> > >>>> on
>> > >>>> the
>> > >>>> torus network (in other words tun0).
>> > >>>> So, since both profiles return 192.168.1.64 for the tun0 IP, I
>> > >>>> think
>> > >>>> thats what you should use. So try replacing `hostname` in
>> > >>>> worker.pl
>> > >>>> with something like:
>> > >>>> `ifconfig | grep 192.168 | sed -e 's/^inet addr://' -e 's/ .*//'`
>> > >>>> You may have to adapt this a bit to meet your needs. Im assuming
>> > >>>> that
>> > >>>> the only code that will uses these IPs is MosaStore.
>> > >>>> - Mike
>> > >>>>> From: "Kazutomo Yoshii"< kazutomo at mcs.anl.gov
>> <mailto:kazutomo at mcs.anl.gov>>
>> > >>>>> To: zeptoos at lists.mcs.anl.gov <mailto:zeptoos at lists.mcs.anl.gov>
>> > >>>>> Sent: Saturday, March 3, 2012 8:52:00 PM
>> > >>>>> Subject: Re: [ZeptoOS] hostname returns none in Surveyor
>> > >>>>> Hi Emalayan,
>> > >>>>> The zeptoos profile returns the IP address of associated I/O
>> > >>>>> node,
>> > >>>>> which is kind of wrong in my opinion (influence of IBM CNK).
>> > >>>>> ifconfig on compute nodes returns CN's IP address, which is
>> > >>>>> correct.
>> > >>>>> e.g. tun0 192.168.1.64
>> > >>>>> If you want to find associated ION's IP address from CNs,
>> > >>>>> do something like this.
>> > >>>>> $ grep BG_IP= /proc/personality.sh
>> > >>>>> - kaz
>> > >>>>> On 03/03/2012 08:25 PM, Emalayan Vairavanathan wrote:
>> > >>>>>> Hi All,
>> > >>>>>> I am trying to run some experiments in Surveyor. The software I
>> > >>>>>> am
>> > >>>>>> using
>> > >>>>>> gets the IP-address of compute-nodes using hostname command.
>> > >>>>>> With zepto-vn-eval/mosatest profile hostname command returns
>> > >>>>>> none.
>> > >>>>>> But with zeptoos profile hostname returns the correct IP
>> > >>>>>> address.
>> > >>>>>> Is this due to some configuration issues in
>> > >>>>>> profile?As a workaround I tired to use ifconfig with both
>> > >>>>>> profiles,
>> > >>>>>> but
>> > >>>>>> it seems ifconfig is not returning the correct IP address.
>> > >>>>>> Is there any command / files which I can used to retrieve the
>> > >>>>>> hostname
>> > >>>>>> on compute nodes? I have pasted the console output with both
>> > >>>>>> profiles
>> > >>>>>> below. Please let me know if you need more details.
>> > >>>>>> Thank you
>> > >>>>>> Emalayan
>> > >>>>>> =======================With zeptoos profile
>> > >>>>>> / # hostname
>> > >>>>>> 172.18.3.19
>> > >>>>>> / # cat /proc/sys/kernel/hostname
>> > >>>>>> 172.18.3.19
>> > >>>>>> / # ifconfig -a
>> > >>>>>> lo Link encap:Local Loopback
>> > >>>>>> inet addr:127.0.0.1 Mask:255.0.0.0
>> > >>>>>> UP LOOPBACK RUNNING MTU:16436 Metric:1
>> > >>>>>> RX packets:0 errors:0 dropped:0 overruns:0 frame:0
>> > >>>>>> TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
>> > >>>>>> collisions:0 txqueuelen:0
>> > >>>>>> RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
>> > >>>>>> tun0 Link encap:UNSPEC HWaddr
>> > >>>>>> 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
>> > >>>>>> inet addr:192.168.1.64 P-t-P:192.168.1.254 Mask:255.255.255.255
>> > >>>>>> UP POINTOPOINT RUNNING NOARP MULTICAST MTU:65535 Metric:1
>> > >>>>>> RX packets:2662 errors:0 dropped:0 overruns:0 frame:0
>> > >>>>>> TX packets:1772 errors:0 dropped:0 overruns:0 carrier:0
>> > >>>>>> collisions:0 txqueuelen:500
>> > >>>>>> RX bytes:140206 (136.9 KiB) TX bytes:125412 (122.4 KiB)
>> > >>>>>> =======================With zepto-vn-eval/mosatest profile
>> > >>>>>> /etc # hostname
>> > >>>>>> (none)
>> > >>>>>> /etc #
>> > >>>>>> /etc # cat /proc/sys/kernel/hostname
>> > >>>>>> (none)
>> > >>>>>> /etc #
>> > >>>>>> /etc # ifconfig -a
>> > >>>>>> eth0 Link encap:Ethernet HWaddr 00:80:46:00:00:00
>> > >>>>>> BROADCAST MULTICAST MTU:1500 Metric:1
>> > >>>>>> collisions:0 txqueuelen:1000
>> > >>>>>> eth1 Link encap:Ethernet HWaddr 00:80:47:00:00:00
>> > >>>>>> inet6 addr: ::1/128 Scope:Host
>> > >>>>>> sit0 Link encap:IPv6-in-IPv4
>> > >>>>>> NOARP MTU:1480 Metric:1
>> > >>>>>> RX packets:965 errors:0 dropped:0 overruns:0 frame:0
>> > >>>>>> TX packets:627 errors:0 dropped:0 overruns:0 carrier:0
>> > >>>>>> RX bytes:50984 (49.7 KiB) TX bytes:50530 (49.3 KiB)
>> > >>>> Michael Wilde
>> > >>>> Computation Institute, University of Chicago
>> > >>>> Mathematics and Computer Science Division
>> > >>>> Argonne National Laboratory
>> > >>>> _______________________________________________
>> > >>>> Swift-devel mailing list
>> > >>>> Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>> > >>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120304/54ee703b/attachment.html>
