[Swift-devel] Urgent Friday evening problem ; -) :: vanilla R on Beagle
Lorenzo Pesce
lpesce at uchicago.edu
Mon Jul 30 19:09:20 CDT 2012
We did not get to use R yet, the user is getting all the rest in shape.
First thing I was going to use your version, then experiment with building R. While I was waiting, I tried with building and found that unusual way of killing a computer....
I will try with switches for the various exception handling to see if I can make it work without too many side effects.
---- Original message ----
>Date: Mon, 30 Jul 2012 16:20:14 -0500 (CDT)
>From: Michael Wilde <wilde at mcs.anl.gov>
>Subject: Re: [Swift-devel] Urgent Friday evening problem ; -) :: vanilla R on Beagle
>To: Lorenzo Pesce <lpesce at uchicago.edu>
>Cc: swift-devel Devel <swift-devel at ci.uchicago.edu>
>Lorenzo, maybe you should try to use the R 2.13 that I already built? Or did that fail to work for you for some reason?
>- Mike
>----- Original Message -----
>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>> Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Monday, July 30, 2012 1:27:06 PM
>> The good news is that for python worked as you said for the version
>> they provide us with.
>> We could both run multiple instances at the same time, but the
>> environmental variables were not corrupted anymore.
>> Next step we'll test building a version and see if it does what we
>> want.
>> R-2.15.1 instead of building brings down the login nodes. Literally.
>> This morning I tried to build R-2.15.1 and
>> while running ./configure the login poofed.
>> Correlation is not causality, but I killed another node trying again,
>> so I am pretty sure it is.
>> This is the last line before evaporating:
>> checking whether integer division by zero raises SIGFPE...
>> under investigation.
>> temporary directory was set to /lustre/beagle/`whoami`'''' , but it
>> doesn't seem to matter whether it is /tmp or lustre
>> On Jul 27, 2012, at 5:11 PM, Michael Wilde wrote:
>> > Lorenzo, I think the R in /home/wilde/R/beagle/R-2.13.1 ws indeed
>> > built with module gcc, and thus should run with "node packing" (ie
>> > multiple parallel copies per node).
>> > Build notes are in /home/wilde/R/README
>> > The build script used was: /home/wilde/R/releases/build.beagle
>> > which does:
>> > mod unload $(mod list | grep -i prg)
>> > mod load gcc
>> > echo Using compiler: $(mod list | grep gcc)
>> > echo 'Checking that PrgEnv has been unloaded (should be blank!):'
>> > rm -rf $MYRBUILD/beagle/$REL
>> > #mkdir -p $MYRBUILD/beagle/$REL
>> > cd $MYRBUILD/beagle
>> > tar zxf $MYRBUILD/$REL.tar.gz
>> > cd $REL
>> > # make clean
>> > ./configure --prefix=$MYRINSTALL/beagle/$REL # --enable-R-shlib
>> > make
>> > make install
>> > - Mike
>> >> From: "Michael Wilde" <wilde at mcs.anl.gov>
>> >> To: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> >> Sent: Friday, July 27, 2012 5:02:31 PM
>> >> vanilla R on Beagle
>> >> Hi Lorenzo, sorry, just saw your message. Try this R:
>> >> login1$ pwd
>> >> login1$ ls
>> >> COPYING INSTALL Makefile.fw NEWS ONEWS README VERSION config.site
>> >> configure.ac etc/ m4/ share/ tests/
>> >> ChangeLog Makeconf.in Makefile.in NEWS.pdf OONEWS SVN-REVISION bin/
>> >> configure* doc/ lib64/ po/ src/ tools/
>> >> login1$ bin/R
>> >> R version 2.13.1 (2011-07-08)
>> >> Copyright (C) 2011 The R Foundation for Statistical Computing
>> >> - Mike
>> >>> Sent: Friday, July 27, 2012 2:24:38 PM
>> >>> Subject: Urgent Friday evening problem ;-) :: vanilla R on Beagle
>> >>> Has any one a version of R that works on the compute nodes and can
>> >>> be
>> >>> packed?
>> >>> If not, I will build one.
>> >>> I just convinced a user of beagle to move all her urgent analysis
>> >>> to
>> >>> swift. Please :-)
>> >>> Lorenzo
>> >> Michael Wilde
>> >> Computation Institute, University of Chicago
>> >> Mathematics and Computer Science Division
>> >> Argonne National Laboratory
>> >> _______________________________________________
>> >> Swift-devel mailing list
>> >> Swift-devel at ci.uchicago.edu
>> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> > Michael Wilde
>Michael Wilde
