[Swift-devel] Vanilla python
    Ti Leggett
    leggett at ci.uchicago.edu
    Wed Jul 25 09:08:00 CDT 2012
How's that different than the python already built in /soft/python? I don't recall doing anything out of the ordinary to build that.
On Jul 25, 2012, at 9:01 AM, Lorenzo Pesce wrote:
> Dear all,
> I am going to build a version of python to be used in a test pipeline, which will eventually become a swift pipeline for genomics research (you will receive a lot of messages about it in the next few weeks).
> Python doesn't seem to be capable of running on the compute notes with more than one instance on a Cray XE6 (Beagle), as Mike told me multiple times ;-)
> My understanding is that what I need is a vanilla version which has to be build with the gcc compiler only, without using the scripts. I plan to strip it of multithreading too if necessary, but right now I don't see why it should be.
> I will first try as:
> -install it under vanilla_python (any better name? I would like to use the same name for all the similarly build environments, from perl to R)
> -using gcc directly
> -I will reinstall all relevant packages under its won tree and built in the same way
> Any other suggestions? Am I missing something?
> Lorenzo
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120725/f68f323b/attachment.pgp>
