[Swift-devel] Swift Licensing
Michael Wilde wilde at mcs.anl.gov
Wed Jan 18 17:57:19 CST 2012
> From: "Ben Clifford" <benc at hawaga.org.uk>
> Sent: Wednesday, January 18, 2012 5:04:39 PM
> At least anything that I contributed under a personal basis and
> outside of my employment with the university of chicago is neither
> copyright the university of chicago, nor licensed under the apache
> license.
> I have no idea if there is any such code in the tree at the moment
> (nor indeed if there ever has been) but previously Argonne seemed very
> excited about the idea that there might be and that I should license
> it to them (not under the apache license).
We'll check the svn logs to see if any such code was committed.
> Also, I think Milena had personal copyright to her contributions
> (though I don't know if those are still in the tree) sometime around
> 2008-ish.
Presumably Milena's code was committed (by Ben) just prior to this message:
----- Forwarded Message -----
To: swift-devel at ci.uchicago.edu
Sent: Tuesday, July 29, 2008 4:12:02 AM
Subject: [Swift-devel] more compile time type checking
I just committed Milena's work on compile-time type checking.
> All of the above mentioned copyrights started earlier than 2011.
GSoC's rules from 2008 regarding code copyright are here:
  http://code.google.com/opensource/gsoc/2008/faqs.html#0.1_owns_code
Did Milena's code have any copyright declarations in it when you integrated it?
We may need to follow with Milena, as I suspect that nothing was explicitly done in this regard when her code was added in 2008.
- Mike
