[Swift-devel] command line ssh provider...
Ben Clifford
benc at hawaga.org.uk
Fri Jan 13 08:26:59 CST 2012
SSH_AUTH_SOCK is the variable I intended to refer to. But if that's working for you, then my suggestion probably isn't the problem...
On Jan 13, 2012, at 12:47 PM, Michael Wilde wrote:
> I ssh to communicado from my mac using the following command:
> ssh -A -t login.ci.uchicago.edu ssh -A -t communicado.ci.uchicago.edu
> then I get the following ssh env vars, and the basic ssh-cl provider seems to work:
> com$ env | grep -i ssh
> SSH_CLIENT=128.135.125.155 47429 22
> SSH_TTY=/dev/pts/0
> SSH_AUTH_SOCK=/tmp/ssh-iGZFq22173/agent.22173
> SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
> CVS_RSH=cvs-ssh
> SSH_CONNECTION=128.135.125.155 47429 128.135.125.17 22
> com$ export | grep -i ssh
> declare -x CVS_RSH="cvs-ssh"
> declare -x SSH_ASKPASS="/usr/libexec/openssh/gnome-ssh-askpass"
> declare -x SSH_AUTH_SOCK="/tmp/ssh-iGZFq22173/agent.22173"
> declare -x SSH_CLIENT="128.135.125.155 47429 22"
> declare -x SSH_CONNECTION="128.135.125.155 47429 128.135.125.17 22"
> declare -x SSH_TTY="/dev/pts/0"
> com$
> (I still have problems, unrelated I think, with getting coasters to work with ssh-cl).
> - Mike
>> From: "Ben Clifford" <benc at hawaga.org.uk>
>> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> Cc: "Michael Wilde" <wilde at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Friday, January 13, 2012 3:00:07 AM
>> Subject: Re: [Swift-devel] command line ssh provider...
>> one guess, based only on reading this thread, is that the SSH_AGENT
>> environment variable from your login session (which tells the 'ssh'
>> commandline program how to get back to the agent that it should use)
>> is not getting passed all the way through swift and ssh-ci to the ssh
>> command executed in there. I didn't look at the code, though, or try
>> to determine the truth of this in any way.
>> On Jan 13, 2012, at 3:24 AM, Jonathan Monette wrote:
>>> I am getting a different problem. The provider does not seem to be
>>> using an agent.
>>> Starting from my macbook I can ssh -A jonmon at login.ci.uchicago.edu
>>> and then do ssh -A jonmon at communicado.ci.uchicago.edu and then ssh
>>> -A jonmon at bridled.ci.uchicago.edu in the terminal and none of them
>>> require a password.
>>> However if I ssh -A jonmon at login.ci.uchicago.edu and then ssh -A
>>> jonmon at communicado.ci.uchicago.edu, then start a Swift run that does
>>> a simple hostname call on bridled.ci.uchicago.edu I am prompted for
>>> my ci password every time.
>>> I am more than certain that this is a configuration issue so I ask
>>> for suggestions. My next step is to completely undo all my ssh keys
>>> in the authorized key files and start fresh with new keys and
>>> passphrases that are not in my macbook keychain. I do not really
>>> want to basically revert back to nothing regarding ssh configuration
>>> but this seems to be my only alternative. Any suggestions?
>>> On Jan 12, 2012, at 9:19 PM, Michael Wilde wrote:
>>>> The boostrap log shows this:
>>>> com$ cat ~/coaster-bootstrap-1460623968.log
>>>> using plain mode
>>>> BS: http://communicado.ci.uchicago.edu:45621
>>>> Failed to download bootstrap jar from
>>>> com$
>>>> - Mike
>>>>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
>>>>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>>>>> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "Swift Devel"
>>>>> Sent: Thursday, January 12, 2012 8:34:36 PM
>>>>> Can't test it right now because UCDavis decided to firewall stuff,
>>>>> but
>>>>> I
>>>>> do get the bootstrap script to start and it gets to the wget part.
>>>>> So the question is, do you get a bootstrap log?
>>>>> On Thu, 2012-01-12 at 13:45 -0600, Michael Wilde wrote:
>>>>>> ssh-cl worked for me going from communicado to both login.ci and
>>>>>> bridled.
>>>>>> I *assumed* it used my agent because I did not get a password
>>>>>> prompt
>>>>>> from the swift run. And I dont get a password prompt when running
>>>>>> the ssh command line.
>>>>>> It failed when I tried to use coasters with either provider
>>>>>> staging
>>>>>> (to login.mcs) or localhost/shared workdir (to login.ci).
>>>>>> The command line and stdout/err for the coaster/local-workdir
>>>>>> case
>>>>>> is below. The logs are on ci net under ~wilde/swift/lab. Config
>>>>>> and
>>>>>> sites file was:
>>>>>> com$ cat cf
>>>>>> wrapperlog.always.transfer=true
>>>>>> sitedir.keep=true
>>>>>> execution.retries=0
>>>>>> lazy.errors=false
>>>>>> status.mode=provider
>>>>>> use.provider.staging=false
>>>>>> provider.staging.pin.swiftfiles=false
>>>>>> com$ cat sshcl.xml
>>>>>> <config>
>>>>>> <pool handle="localhost">
>>>>>> <execution provider="ssh-cl" url="login.ci.uchicago.edu"/>
>>>>>> <filesystem provider="local"/>
>>>>>> <workdirectory>/home/wilde/swiftwork</workdirectory>
>>>>>> </pool>
>>>>>> </config>
>>>>>> com$
>>>>>> com$ cat sshclcoast.xml
>>>>>> <config>
>>>>>> <execution provider="coaster" url="login.ci.uchicago.edu"
>>>>>> jobmanager="ssh-cl:local"/>
>>>>>> <profile namespace="globus" key="jobsPerNode">8</profile>
>>>>>> <profile namespace="globus" key="slots">1</profile>
>>>>>> <profile namespace="globus" key="nodeGranularity">1</profile>
>>>>>> <profile namespace="globus" key="maxNodes">1</profile>
>>>>>> <profile namespace="karajan" key="jobThrottle">.01</profile>
>>>>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>>>>> </pool>
>>>>>> </config>
>>>>>> com$
>>>>>> - Mike
>>>>>> com$ which swift
>>>>>> ~/swift/src/trunk/cog/modules/swift/dist/swift-svn/bin/swift
>>>>>> com$ pwd
>>>>>> /home/wilde/swift/lab
>>>>>> com$ swift -tc.file tc -sites.file sshcl.xml -config cf
>>>>>> catsn.swift
>>>>>> -n=1
>>>>>> Swift trunk swift-r5498 cog-r3347
>>>>>> RunID: 20120112-1343-a7mk2zyc
>>>>>> Progress: time: Thu, 12 Jan 2012 13:43:04 -0600
>>>>>> Final status: Thu, 12 Jan 2012 13:43:04 -0600 Finished
>>>>>> successfully:1
>>>>>> com$ swift -tc.file tc -sites.file sshclcoast.xml -config cf
>>>>>> catsn.swift -n=1
>>>>>> RunID: 20120112-1343-ql7sn3f7
>>>>>> Progress: time: Thu, 12 Jan 2012 13:43:20 -0600
>>>>>> Failed to transfer wrapper log for job cat-ihhm6jlk
>>>>>> EXCEPTION Exception in cat:
>>>>>> Arguments: [data.txt]
>>>>>> Host: localhost
>>>>>> Directory: catsn-20120112-1343-ql7sn3f7/jobs/i/cat-ihhm6jlk
>>>>>> stderr.txt:
>>>>>> stdout.txt:
>>>>>> Caused by: null
>>>>>> Caused by:
>>>>>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>>>>>> Could not submit job
>>>>>> Caused by:
>>>>>> Could not start coaster service
>>>>>> Caused by:
>>>>>> Task ended before registration was received.
>>>>>> STDOUT: Failed to download bootstrap jar from
>>>>>> STDERR: This machine accepts SSH public key and One Time Password
>>>>>> (OTP) logins only.
>>>>>> If you do not have a public key set up, you will be prompted for
>>>>>> a
>>>>>> password.
>>>>>> This is *not* your CI password, but the One Time Password
>>>>>> generated
>>>>>> from your
>>>>>> OTP token. Do not type your CI password, it will not work. If you
>>>>>> do
>>>>>> not
>>>>>> have a token or public key, you will not be able to login.
>>>>>> See http://www.ci.uchicago.edu/faq for more information.
>>>>>> Caused by:
>>>>>> org.globus.cog.abstraction.impl.common.execution.JobException:
>>>>>> Job
>>>>>> failed with an exit code of 1
>>>>>> Execution failed:
>>>>>> Job failed with an exit code of 1
>>>>>> com$
>>>>>>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
>>>>>>> To: "Mihael Hategan" <hategan at mcs.anl.gov>
>>>>>>> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde"
>>>>>>> Sent: Thursday, January 12, 2012 1:29:10 PM
>>>>>>> Mike,
>>>>>>> You mentioned that you were able to use ssh command line
>>>>>>> provider
>>>>>>> using catsn this morning. Was it using agents? Mihael did you
>>>>>>> test
>>>>>>> using an agent? How do I specify for it to use an agent if
>>>>>>> available?
>>>>>>> I can do a simple hostname test from communicado to bridled but
>>>>>>> it
>>>>>>> asks for my password instead of using the agent I have set up.
>>>>>>> On Jan 12, 2012, at 12:21 AM, Mihael Hategan wrote:
>>>>>>>> ... is in trunk (cog r3347). I was able to start coasters with
>>>>>>>> it.
>>>>>>>> The
>>>>>>>> provider is called "ssh-cl". It is ssh, so ~/.ssh/config and
>>>>>>>> agents
>>>>>>>> will
>>>>>>>> apply. Please test.
>>>>>>>> Mihael
>>>>>>>> _______________________________________________
>>>>>>>> Swift-devel mailing list
>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>> Michael Wilde
>>>> Computation Institute, University of Chicago
>>>> Mathematics and Computer Science Division
>>>> Argonne National Laboratory
> Michael Wilde
