[Swift-devel] command line ssh provider...
Michael Wilde wilde at mcs.anl.gov
Fri Jan 13 06:47:08 CST 2012
I ssh to communicado from my mac using the following command:
    ssh -A -t login.ci.uchicago.edu ssh -A -t communicado.ci.uchicago.edu
then I get the following ssh env vars, and the basic ssh-cl provider seems to work:
com$ env | grep -i ssh
SSH_CLIENT=128.135.125.155 47429 22
SSH_TTY=/dev/pts/0
SSH_AUTH_SOCK=/tmp/ssh-iGZFq22173/agent.22173
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
CVS_RSH=cvs-ssh
SSH_CONNECTION=128.135.125.155 47429 128.135.125.17 22
com$ export | grep -i ssh
declare -x CVS_RSH="cvs-ssh"
declare -x SSH_ASKPASS="/usr/libexec/openssh/gnome-ssh-askpass"
declare -x SSH_AUTH_SOCK="/tmp/ssh-iGZFq22173/agent.22173"
declare -x SSH_CLIENT="128.135.125.155 47429 22"
declare -x SSH_CONNECTION="128.135.125.155 47429 128.135.125.17 22"
declare -x SSH_TTY="/dev/pts/0"
com$
(I still have problems, unrelated I think, with getting coasters to work with ssh-cl).
- Mike
----- Original Message -----
> From: "Ben Clifford" <benc at hawaga.org.uk>
> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
> Cc: "Michael Wilde" <wilde at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Friday, January 13, 2012 3:00:07 AM
> Subject: Re: [Swift-devel] command line ssh provider...
> one guess, based only on reading this thread, is that the SSH_AGENT
> environment variable from your login session (which tells the 'ssh'
> commandline program how to get back to the agent that it should use)
> is not getting passed all the way through swift and ssh-ci to the ssh
> command executed in there. I didn't look at the code, though, or try
> to determine the truth of this in any way.
> On Jan 13, 2012, at 3:24 AM, Jonathan Monette wrote:
> > I am getting a different problem. The provider does not seem to be
> > using an agent.
> > Starting from my macbook I can ssh -A jonmon at login.ci.uchicago.edu
> > and then do ssh -A jonmon at communicado.ci.uchicago.edu and then ssh
> > -A jonmon at bridled.ci.uchicago.edu in the terminal and none of them
> > require a password.
> > However if I ssh -A jonmon at login.ci.uchicago.edu and then ssh -A
> > jonmon at communicado.ci.uchicago.edu, then start a Swift run that does
> > a simple hostname call on bridled.ci.uchicago.edu I am prompted for
> > my ci password every time.
> > I am more than certain that this is a configuration issue so I ask
> > for suggestions. My next step is to completely undo all my ssh keys
> > in the authorized key files and start fresh with new keys and
> > passphrases that are not in my macbook keychain. I do not really
> > want to basically revert back to nothing regarding ssh configuration
> > but this seems to be my only alternative. Any suggestions?
> > On Jan 12, 2012, at 9:19 PM, Michael Wilde wrote:
> >> The boostrap log shows this:
> >> com$ cat ~/coaster-bootstrap-1460623968.log
> >> using plain mode
> >> BS: http://communicado.ci.uchicago.edu:45621
> >> Failed to download bootstrap jar from
> >> com$
> >> - Mike
> >>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> >>> To: "Michael Wilde" <wilde at mcs.anl.gov>
> >>> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "Swift Devel"
> >>> Sent: Thursday, January 12, 2012 8:34:36 PM
> >>> Can't test it right now because UCDavis decided to firewall stuff,
> >>> but
> >>> I
> >>> do get the bootstrap script to start and it gets to the wget part.
> >>> So the question is, do you get a bootstrap log?
> >>> On Thu, 2012-01-12 at 13:45 -0600, Michael Wilde wrote:
> >>>> ssh-cl worked for me going from communicado to both login.ci and
> >>>> bridled.
> >>>> I *assumed* it used my agent because I did not get a password
> >>>> prompt
> >>>> from the swift run. And I dont get a password prompt when running
> >>>> the ssh command line.
> >>>> It failed when I tried to use coasters with either provider
> >>>> staging
> >>>> (to login.mcs) or localhost/shared workdir (to login.ci).
> >>>> The command line and stdout/err for the coaster/local-workdir
> >>>> case
> >>>> is below. The logs are on ci net under ~wilde/swift/lab. Config
> >>>> and
> >>>> sites file was:
> >>>> com$ cat cf
> >>>> wrapperlog.always.transfer=true
> >>>> sitedir.keep=true
> >>>> execution.retries=0
> >>>> lazy.errors=false
> >>>> status.mode=provider
> >>>> use.provider.staging=false
> >>>> provider.staging.pin.swiftfiles=false
> >>>> com$ cat sshcl.xml
> >>>> <config>
> >>>> <pool handle="localhost">
> >>>>   <execution provider="ssh-cl" url="login.ci.uchicago.edu"/>
> >>>>   <filesystem provider="local"/>
> >>>>   <workdirectory>/home/wilde/swiftwork</workdirectory>
> >>>> </pool>
> >>>> </config>
> >>>> com$
> >>>> com$ cat sshclcoast.xml
> >>>> <config>
> >>>>   <execution provider="coaster" url="login.ci.uchicago.edu"
> >>>>   jobmanager="ssh-cl:local"/>
> >>>>   <profile namespace="globus" key="jobsPerNode">8</profile>
> >>>>   <profile namespace="globus" key="slots">1</profile>
> >>>>   <profile namespace="globus" key="nodeGranularity">1</profile>
> >>>>   <profile namespace="globus" key="maxNodes">1</profile>
> >>>>   <profile namespace="karajan" key="jobThrottle">.01</profile>
> >>>>   <profile namespace="karajan" key="initialScore">10000</profile>
> >>>> </pool>
> >>>> </config>
> >>>> com$
> >>>> - Mike
> >>>> com$ which swift
> >>>> ~/swift/src/trunk/cog/modules/swift/dist/swift-svn/bin/swift
> >>>> com$ pwd
> >>>> /home/wilde/swift/lab
> >>>> com$ swift -tc.file tc -sites.file sshcl.xml -config cf
> >>>> catsn.swift
> >>>> -n=1
> >>>> Swift trunk swift-r5498 cog-r3347
> >>>> RunID: 20120112-1343-a7mk2zyc
> >>>> Progress: time: Thu, 12 Jan 2012 13:43:04 -0600
> >>>> Final status: Thu, 12 Jan 2012 13:43:04 -0600 Finished
> >>>> successfully:1
> >>>> com$ swift -tc.file tc -sites.file sshclcoast.xml -config cf
> >>>> catsn.swift -n=1
> >>>> RunID: 20120112-1343-ql7sn3f7
> >>>> Progress: time: Thu, 12 Jan 2012 13:43:20 -0600
> >>>> Failed to transfer wrapper log for job cat-ihhm6jlk
> >>>> EXCEPTION Exception in cat:
> >>>> Arguments: [data.txt]
> >>>> Host: localhost
> >>>> Directory: catsn-20120112-1343-ql7sn3f7/jobs/i/cat-ihhm6jlk
> >>>> stderr.txt:
> >>>> stdout.txt:
> >>>> Caused by: null
> >>>> Caused by:
> >>>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> >>>> Could not submit job
> >>>> Caused by:
> >>>> Could not start coaster service
> >>>> Caused by:
> >>>> Task ended before registration was received.
> >>>> STDOUT: Failed to download bootstrap jar from
> >>>> STDERR: This machine accepts SSH public key and One Time Password
> >>>> (OTP) logins only.
> >>>> If you do not have a public key set up, you will be prompted for
> >>>> a
> >>>> password.
> >>>> This is *not* your CI password, but the One Time Password
> >>>> generated
> >>>> from your
> >>>> OTP token. Do not type your CI password, it will not work. If you
> >>>> do
> >>>> not
> >>>> have a token or public key, you will not be able to login.
> >>>> See http://www.ci.uchicago.edu/faq for more information.
> >>>> Caused by:
> >>>> org.globus.cog.abstraction.impl.common.execution.JobException:
> >>>> Job
> >>>> failed with an exit code of 1
> >>>> Execution failed:
> >>>> 	Job failed with an exit code of 1
> >>>> com$
> >>>>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> >>>>> To: "Mihael Hategan" <hategan at mcs.anl.gov>
> >>>>> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde"
> >>>>> Sent: Thursday, January 12, 2012 1:29:10 PM
> >>>>> Mike,
> >>>>> You mentioned that you were able to use ssh command line
> >>>>> provider
> >>>>> using catsn this morning. Was it using agents? Mihael did you
> >>>>> test
> >>>>> using an agent? How do I specify for it to use an agent if
> >>>>> available?
> >>>>> I can do a simple hostname test from communicado to bridled but
> >>>>> it
> >>>>> asks for my password instead of using the agent I have set up.
> >>>>> On Jan 12, 2012, at 12:21 AM, Mihael Hategan wrote:
> >>>>>> ... is in trunk (cog r3347). I was able to start coasters with
> >>>>>> it.
> >>>>>> The
> >>>>>> provider is called "ssh-cl". It is ssh, so ~/.ssh/config and
> >>>>>> agents
> >>>>>> will
> >>>>>> apply. Please test.
> >>>>>> Mihael
> >>>>>> _______________________________________________
> >>>>>> Swift-devel mailing list
> >>>>>> Swift-devel at ci.uchicago.edu
> >>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >> Michael Wilde
> >> Computation Institute, University of Chicago
> >> Mathematics and Computer Science Division
> >> Argonne National Laboratory
Michael Wilde
