[Swift-devel] tc and sites file debugging
    Jonathan Monette
    jonmon at mcs.anl.gov
    Fri Feb 10 16:08:10 CST 2012
So this turned out to be a sites file xml formatting issue.  Filed as bug 732.
On Feb 10, 2012, at 3:41 PM, Justin M Wozniak wrote:
> Using branches/release-0.93, I find that the sites and tc files are included in the log.  If you use the default location you just get the path name.
> On Fri, 10 Feb 2012, Jonathan Monette wrote:
>> 0.93
>> On Feb 10, 2012, at 3:19 PM, Justin M Wozniak wrote:
>>> There should be a message for that case as well.  Which branch are you using?
>>>> It is set.  So, if not sites file or tc file shows up in the logs, that is a pretty good indication that they defaulted to the ones provided by Swift correct?
>>>> On Feb 10, 2012, at 3:14 PM, Justin M Wozniak wrote:
>>>>> Just set:
>>>>> log4j.logger.swift.textfiles=DEBUG
>>>>>> What log4j properties do I have to turn on to see what the path is to the tc and sites file I am using in a Swift run?  I keep getting an error saying that the application is not in my tc file for any of the site pool entries.  I just want to see if Swift is grabbing the write files.
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>>> Justin M Wozniak
>>> Justin M Wozniak
> Justin M Wozniak
