[Swift-devel] tc and sites file debugging
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Fri Feb 10 15:41:45 CST 2012
Using branches/release-0.93, I find that the sites and tc files are
included in the log.  If you use the default location you just get the
path name.
On Fri, 10 Feb 2012, Jonathan Monette wrote:
> 0.93
> On Feb 10, 2012, at 3:19 PM, Justin M Wozniak wrote:
>> There should be a message for that case as well.  Which branch are you using?
>>> It is set.  So, if not sites file or tc file shows up in the logs, that is a pretty good indication that they defaulted to the ones provided by Swift correct?
>>> On Feb 10, 2012, at 3:14 PM, Justin M Wozniak wrote:
>>>> Just set:
>>>> log4j.logger.swift.textfiles=DEBUG
>>>>> What log4j properties do I have to turn on to see what the path is to the tc and sites file I am using in a Swift run?  I keep getting an error saying that the application is not in my tc file for any of the site pool entries.  I just want to see if Swift is grabbing the write files.
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>> Justin M Wozniak
>> Justin M Wozniak
Justin M Wozniak
