[Swift-devel] Failed to start channel GSSCChannel (trunk,	coasters, ssh-cl:pbs)
    Thomas Uram
    turam at mcs.anl.gov
    Mon Feb  6 17:38:13 CST 2012
Okay, with this version, my job succeeded:
http://www.mcs.anl.gov/~turam/20120206-1731/hostname-20120206-1603-am03uzbb.log
This requires that GLOBUS_TCP_PORT_RANGE be set properly so the bootstrap service is started where it can be reached.
I do get the original error message a number of times:
Caused by: org.globus.cog.karajan.workflow.service.channels.ChannelException: Failed to start channel GSSCChannel-https://206.12.24.2:34724(2)[1625488363: {}]
Caused by: java.net.NoRouteToHostException: No route to host
It seems to start and stop the coaster service on a variety of ports, one of which eventually succeeds. I don't have documentation to tell me the open port range on the target cluster (I'll get it), but in the meantime, I've discovered some ports that work. Can I specify the port range to be used for the coaster service? I've seen some discussion on the mailing lists about doing so in the context of "coaster-service". At the moment, I'm just running Swift with the configuration you see in the log above. Can I specify the port in my case, or should I use the "coaster-service" script instead?
Thanks!
Tom
On Feb 4, 2012, at 8:16 PM, Mihael Hategan wrote:
> Yep, it didn't. Fixed in latest trunk. Let me know if the problem
> persists.
> On Fri, 2012-02-03 at 12:29 -0800, Mihael Hategan wrote:
>> Ok, so maybe the ssh-cl provider doesn't properly forward environment
>> variables. I'll double check that.
>> On Fri, 2012-02-03 at 14:02 -0600, Thomas Uram wrote:
>>> I have done this without success:
>>> GLOBUS_HOSTNAME=fl.ci.uchicago.edu
>>> GLOBUS_TCP_PORT_RANGE=50000,50100
>>> swiftt -sites.file sites.coasters.xml -tc.file tc.data hostname.swift
>>> Swift trunk swift-r5501 (swift modified locally) cog-r3350 (cog modified locally)
