[Swift-devel] Failed to start channel GSSCChannel (trunk, coasters, ssh-cl:pbs)
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Feb  4 20:16:37 CST 2012
Yep, it didn't. Fixed in latest trunk. Let me know if the problem
persists.
On Fri, 2012-02-03 at 12:29 -0800, Mihael Hategan wrote:
> Ok, so maybe the ssh-cl provider doesn't properly forward environment
> variables. I'll double check that.
> On Fri, 2012-02-03 at 14:02 -0600, Thomas Uram wrote:
> > I have done this without success:
> > GLOBUS_HOSTNAME=fl.ci.uchicago.edu
> > GLOBUS_TCP_PORT_RANGE=50000,50100
> > swiftt -sites.file sites.coasters.xml -tc.file tc.data hostname.swift
> > Swift trunk swift-r5501 (swift modified locally) cog-r3350 (cog modified locally)
