[Swift-devel] Failed to start channel GSSCChannel (trunk,	coasters, ssh-cl:pbs)
    Thomas Uram
    turam at mcs.anl.gov
    Fri Feb  3 14:02:53 CST 2012
I have done this without success:
GLOBUS_HOSTNAME=fl.ci.uchicago.edu
GLOBUS_TCP_PORT_RANGE=50000,50100
swiftt -sites.file sites.coasters.xml -tc.file tc.data hostname.swift
Swift trunk swift-r5501 (swift modified locally) cog-r3350 (cog modified locally)
RunID: 20120203-1357-8tekc3f7
Progress:  time: Fri, 03 Feb 2012 13:57:24 -0600
Progress:  time: Fri, 03 Feb 2012 13:57:31 -0600  Selecting site:4  Initializing site shared directory:1  Stage in:1
ssh not set, setting to 'gsissh'
ssh=gsissh
Find: https://206.12.24.2:38675
Find:  keepalive(120), reconnect - https://206.12.24.2:38675
Progress:  time: Fri, 03 Feb 2012 13:57:35 -0600  Selecting site:4  Submitting:1  Submitted:1
Failed to transfer wrapper log for job hostname-1jnudkmk
Progress:  time: Fri, 03 Feb 2012 13:57:38 -0600  Selecting site:3  Stage in:1 Failed but can retry:2
Failed to transfer wrapper log for job hostname-2jnudkmk
Failed to transfer wrapper log for job hostname-4jnudkmk
Progress:  time: Fri, 03 Feb 2012 13:57:54 -0600  Selecting site:3 Failed but can retry:3
Progress:  time: Fri, 03 Feb 2012 13:57:57 -0600  Selecting site:2  Stage in:1 Failed but can retry:3
Failed to transfer wrapper log for job hostname-7jnudkmk
No events in 10s.
Registered futures:
Waiting threads:
No events in 10s.
Registered futures:
Waiting threads:
** Ctrl-C here **
Progress:  time: Fri, 03 Feb 2012 13:58:24 -0600  Selecting site:2 Failed but can retry:4
Failed to shut down service https://206.12.24.2:38675
org.globus.cog.karajan.workflow.service.channels.ChannelException: Failed to start channel GSSCChannel-https://206.12.24.2:38675(6)[69518356: {}]
	at org.globus.cog.karajan.workflow.service.channels.GSSChannel.reconnect(GSSChannel.java:103)
	at org.globus.cog.karajan.workflow.service.channels.GSSChannel.start(GSSChannel.java:62)
	at org.globus.cog.karajan.workflow.service.ChannelFactory.newChannel(ChannelFactory.java:55)
	at org.globus.cog.karajan.workflow.service.Client.connect(Client.java:116)
	at org.globus.cog.karajan.workflow.service.Client.newClient(Client.java:72)
	at org.globus.cog.karajan.workflow.service.channels.ChannelManager.connect(ChannelManager.java:236)
	at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:256)
	at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:217)
	at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager$ServiceReaper.run(ServiceManager.java:430)
Caused by: java.net.NoRouteToHostException: No route to host
	at java.net.PlainSocketImpl.socketConnect(Native Method)
	at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351)
	at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213)
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
	at java.net.Socket.connect(Socket.java:529)
	at java.net.Socket.connect(Socket.java:478)
	at java.net.Socket.<init>(Socket.java:375)
	at java.net.Socket.<init>(Socket.java:276)
	at org.globus.net.SocketFactory.createSocket(SocketFactory.java:74)
	at org.globus.net.SocketFactory.createSocket(SocketFactory.java:53)
	at org.globus.gsi.gssapi.net.GssSocket.<init>(GssSocket.java:56)
	at org.globus.gsi.gssapi.net.impl.GSIGssSocket.<init>(GSIGssSocket.java:29)
	at org.globus.gsi.gssapi.net.impl.GSIGssSocketFactory.createSocket(GSIGssSocketFactory.java:38)
	at org.globus.cog.karajan.workflow.service.channels.GSSChannel.reconnect(GSSChannel.java:89)
	... 8 more
Full log here:
http://www.mcs.anl.gov/~turam/20120203-1401/hostname-20120203-1357-8tekc3f7.log
On Feb 3, 2012, at 1:54 PM, Mihael Hategan wrote:
> On Fri, 2012-02-03 at 13:44 -0600, Thomas Uram wrote:
>> No I didn't set GLOBUS_HOSTNAME. The address it complains about
>> (206.12.24.2) is publicly reachable. So is the hostname of the machine
>> on which I'm running Swift (fl.ci.uchicago.edu).
> They should be the same! (i.e. the coaster service tries to connect back
> to the machine you're running Swift on).
> Can you try setting GLOBUS_HOSTNAME and see what happens?
>> I was wondering about the jumble that follows the hostname:port in
>> that URL:
>>>> GSSCChannel-https://206.12.24.2:35836(2)[1544213635: {}]
> (2) is the channel ID
> [15...] is the channel context
> They are not part of the IP address, but part of GSSChannel.toString().
