[Swift-devel] Failed to start channel GSSCChannel (trunk, coasters, ssh-cl:pbs)
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Feb  3 13:54:03 CST 2012
On Fri, 2012-02-03 at 13:44 -0600, Thomas Uram wrote:
> No I didn't set GLOBUS_HOSTNAME. The address it complains about
> (206.12.24.2) is publicly reachable. So is the hostname of the machine
> on which I'm running Swift (fl.ci.uchicago.edu).
They should be the same! (i.e. the coaster service tries to connect back
to the machine you're running Swift on).
Can you try setting GLOBUS_HOSTNAME and see what happens?
> I was wondering about the jumble that follows the hostname:port in
> that URL:
> > > GSSCChannel-https://206.12.24.2:35836(2)[1544213635: {}]
(2) is the channel ID
[15...] is the channel context
They are not part of the IP address, but part of GSSChannel.toString().
