[Swift-devel] Provider staging problem (690) persists with	single-core workers
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Apr 25 12:31:35 CDT 2012
I saw that. It's new code, so some problems need to be ironed out.
I'm working on that and the large memory consumption issue.
On Wed, 2012-04-25 at 08:22 -0500, Michael Wilde wrote:
> Mihael, I just want to confirm that you've seen David's latest update on bug 690:
> Comment #47 From David Kelly 2012-04-24 10:13:03 (-) [reply]
> Yesterday, I tried a larger set of data on OSG using 1 worker per node and saw
> timeouts. I'll try again later to get a better set of worker logs (need to give
> them all a unique filename so they don't get overwritten when condor sends them
> back). The file below has the coaster service log, swift log, and 1 worker log.
> http://www.ci.uchicago.edu/~davidk/logs/logs-2012-04-23.tar.gz
> I.e., the problem still occurs with workersPerNode=1, on OSG. Does the log above provide what you need to debug this?
> - Mike
