[Swift-devel] Plotting
Jonathan Monette jonmon at mcs.anl.gov
Fri Apr 13 11:58:04 CDT 2012
That is similar to my current approach so I will use the window size.  And the worker load plot is the plot I generated.  I also have generating this plot scripted so I will update the instructions on how to plot with more information.
On Apr 13, 2012, at 11:53 AM, Justin M Wozniak wrote:
> On Fri, 13 Apr 2012, Jonathan Monette wrote:
>> I have thought about going through the large data set file and averaging together points that are very close together(within some epsilon).  Is this a solid approach?  Is there any way of telling the plot routine(gnu plot or the plotter Justin made with JFreeChart) to do this for me? What other techniques could I try to shorten the amount of data that is being plotted?
> The plotter does not currently support this.
> I think this would be a nice, short, reusable script.  I would take the two-column XY file and a window size.  In each window, average X and Y. This should be fine for worker load plots and things like that.
> Justin M Wozniak
