[Swift-devel] Join function?
Mihael Hategan
hategan at mcs.anl.gov
Tue Apr 3 14:44:33 CDT 2012
Nice!
I think though, fundamentally, there is no way to write this without
either of:
1. length(array)
2. head/tail(array) (with the ability compare with [] - isEmpty(array)).
But there might be ways in which the above could be accomplished.
Mihael
On Tue, 2012-04-03 at 15:09 -0400, Glen Hocky wrote:
> This seemed like an interesting challenge. The following works
> assuming swift knows how many elements you have. However, there are
> many simpler things I would /think/ should work that do not. There
> seem to possibly be some bugs (i.e. things that don't seem
> intentional) about declaring a variable before an iterate statement
> and then writing to it on each iterate statement. Hence the use of
> lists below. I will also put a second version after which I would
> think should work but does not
> Working:
> $ swift test.swift
> Swift svn swift-r3826 cog-r2988
> RunID: 20120403-1509-3xnsrx10
> Progress:
> SwiftScript trace: this:is:a:test
> Final status:
> (string j[]) join(string s[], string c, int n){
> j[0]="";
> iterate i {
> if(i<n-1){
> j[i+1]=@strcat( j[i], s[i]+c );
> else{
> j[i+1]=@strcat( j[i], s[i] );
> } until(i==n-1);
> string a[];
> a[0] = "this";
> a[1] = "is";
> a[2] = "a";
> a[3] = "test";
> int nelements=4;
> string j[];
> j = join( a, ":", nelements );
> trace(j[nelements]);
> Not working (error, jlist has multiple writers):
> (string j) join(string s[], string c, int n){
> string jlist[];
> jlist[0] = "";
> iterate i {
> if(i<n-1){
> jlist[i+1]=@strcat( jlist[i], s[i]+c );
> else{
> jlist[i+1]=@strcat( jlist[i], s[i] );
> } until(i==n-1);
> j = jlist[n];
> string a[];
> a[0] = "this";
> a[1] = "is";
> a[2] = "a";
> a[3] = "test";
> int nelements=4;
> string j;
> trace(j);
> On Tue, Apr 3, 2012 at 2:02 PM, David Kelly <davidk at ci.uchicago.edu>
> wrote:
> Hello,
> Is there a way to concatenate all elements of an array into a
> single string? I would also like to define a separator between
> elements. I was thinking of something similar to Perl's join
> function.
> If I have:
> string a[];
> a[0] = "this";
> a[1] = "is";
> a[2] = "a";
> a[3] = "test";
> How can I get it into "this is a test" or "this:is:a:test"?
> @strcat returns a reference. I can tracef with %q and get
> "[this,is,a,test]", but it doesn't give me any control over
> the formatting as far as I know.
> I could call a shell script to do this, just wondering if
> there was another way.
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
