[Swift-devel] hanging in trunk
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Apr  3 09:22:25 CDT 2012
David, Mihael,
Can you describe whats failing and what further debugging and/or 0.93-to-trunk integration that indicates is still needed?
Can we also work from the SVN side from a list of what was not integrated, or what failed to auto-integrate?
- Mike
----- Original Message -----
> From: "David Kelly" <davidk at ci.uchicago.edu>
> To: "Mihael Hategan" <hategan at mcs.anl.gov>
> Cc: "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde" <wilde at mcs.anl.gov>
> Sent: Monday, April 2, 2012 11:37:08 PM
> Subject: Re: [Swift-devel] hanging in trunk
> The test version I built fails some tests in test suite. I think this
> is because as you mentioned, there are some other modifications to
> these classes.
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "David Kelly" <davidk at ci.uchicago.edu>,
> > Sent: Monday, April 2, 2012 10:51:08 PM
> > On Mon, 2012-04-02 at 21:27 -0500, Michael Wilde wrote:
> > > David, Mihael,
> > > Wasnt that already (supposed to be) integrated into trunk?
> > Yes. Which was what I was going to double-check. Sometimes things
> > get
> > messed up if the same code is modified in both branches before the
> > merge. I suspect this is what happened here.
> > I remember this being a family of fixes that made similar
> > modifications
> > in relevant code. I will double-check all places I know of where
> > this
> > should be and commit as necessary.
> > Mihael
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
