[Swift-devel] hanging in trunk
    David Kelly
    davidk at ci.uchicago.edu
    Mon Apr  2 23:37:08 CDT 2012
The test version I built fails some tests in test suite. I think this is because as you mentioned, there are some other modifications to these classes.
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "David Kelly" <davidk at ci.uchicago.edu>, "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, April 2, 2012 10:51:08 PM
> Subject: Re: [Swift-devel] hanging in trunk
> On Mon, 2012-04-02 at 21:27 -0500, Michael Wilde wrote:
> > David, Mihael,
> > Wasnt that already (supposed to be) integrated into trunk?
> Yes. Which was what I was going to double-check. Sometimes things get
> messed up if the same code is modified in both branches before the
> merge. I suspect this is what happened here.
> I remember this being a family of fixes that made similar
> modifications
> in relevant code. I will double-check all places I know of where this
> should be and commit as necessary.
> Mihael
