[Swift-devel] swift 0.93 deadlock
    David Kelly
    davidk at ci.uchicago.edu
    Fri Sep 23 14:05:29 CDT 2011
I don't know if the workflow has ever run completely. Since the latest patches on Wednesday I've tried running it three times.
The first time it ran for 20 hours but ran into an issue with coaster workers timing out and eventually stopped processing work.
The second, started last night, was terminated early this morning when the mcs machine I was running on was rebooted.
The third I started this morning. It is currently running and I will email the status as soon as it either fails or finishes.
David
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Mihael Hategan" <hategan at mcs.anl.gov>, "Papia Rizwan" <papia.rizwan at gmail.com>, "David Kelly"
> <davidk at ci.uchicago.edu>
> Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> Sent: Friday, September 23, 2011 10:15:08 AM
> Subject: Re: [Swift-devel] swift 0.93 deadlock
> Mihael, is this 0.93 deadlock (related to mapping.RootArrayDataNode)
> resolved or still open?
> Papia, David, does the SWAT workflow now run?
> - Mike
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>, "Papia
> > Sent: Wednesday, September 21, 2011 1:09:02 PM
> > Not quite. But somewhat close.
> > On Wed, 2011-09-21 at 08:39 -0500, Michael Wilde wrote:
> > > Thanks, Mihael. Is this the same deadlock as the one I reported
> > > recently for 0.93?
> > >   Sent: Tuesday, September 20, 2011 5:34:50 PM
> > >   Subject: [Swift-devel] New 0.93 deadlock -
> > >   mapping.RootArrayDataNode?
> > > - Mike
> > > > To: "David Kelly" <davidk at ci.uchicago.edu>
> > > > Rizwan" <papia.rizwan at gmail.com>, "Michael Wilde"
> > > > Sent: Wednesday, September 21, 2011 2:08:58 AM
> > > > Fix in r5143. Please test.
> > > > On Mon, 2011-09-19 at 22:20 -0500, David Kelly wrote:
> > > > > I tried today with the 0.93 update. It ran for approximately 7
> > > > > hours
> > > > > before freezing. It looks to be happening in a different place
> > > > > this
> > > > > time.
> > > > > http://www.ci.uchicago.edu/~davidk/swat4/jstack.log
> > > > > http://www.ci.uchicago.edu/~davidk/swat4/cce_ua-20110919-1955-h7t8iui2.log
> > > > > David
> > > > > > Cc: "David Kelly" <davidk at ci.uchicago.edu>, "swift-devel
> > > > > > Devel"
> > > > > > <swift-devel at ci.uchicago.edu>, "Papia Rizwan"
> > > > > > Sent: Saturday, September 17, 2011 11:36:25 PM
> > > > > > I have a tentative fix in the branch and trunk. Revisions
> > > > > > 5123
> > > > > > and
> > > > > > 5124,
> > > > > > respectively. Please let me know how that works out.
> > > > > > Mihae
> > > > > > On Fri, 2011-09-16 at 11:50 -0500, Michael Wilde wrote:
> > > > > > > David and Papia, can you report to the list what the
> > > > > > > status
> > > > > > > is
> > > > > > > of
> > > > > > > running the SWAT app?
> > > > > > > - I understand that Mihael will work on the 0.93 deadlock
> > > > > > > fix
> > > > > > > this
> > > > > > > weekend, which is great.
> > > > > > > - I understand that its happening on trunk as well
> > > > > > > - Papia, can you try to "perturb" the Swift code in the
> > > > > > > hopes
> > > > > > > that
> > > > > > > some equivalent but different code doesnt trip into the
> > > > > > > same
> > > > > > > bug? Ie
> > > > > > > try a different mapper, different variable strategy (ie
> > > > > > > arrays
> > > > > > > vs
> > > > > > > scalars, structs vs separate vars) just to see if you can
> > > > > > > work
> > > > > > > around this? Or, put in some shell logic to catch the hang
> > > > > > > and
> > > > > > > kill
> > > > > > > and re-run (or resume) Swift? if you just kill a hung
> > > > > > > script
> > > > > > > and
> > > > > > > then resume it, will it work? We could maybe alter the
> > > > > > > hang
> > > > > > > checker
> > > > > > > to kill swift on its own, with a return code or message
> > > > > > > that
> > > > > > > you
> > > > > > > could use to trigger a resume.
> > > > > > > Mike
> > > > > > > > From: "David Kelly" <davidk at ci.uchicago.edu>
> > > > > > > > "Papia
> > > > > > > > Sent: Thursday, September 15, 2011 4:34:02 PM
> > > > > > > > I was able to get it running on PADS with trunk. I ran
> > > > > > > > into
> > > > > > > > the
> > > > > > > > same
> > > > > > > > issue.
> > > > > > > > http://www.ci.uchicago.edu/~davidk/swat3/jstack.log
> > > > > > > > http://www.ci.uchicago.edu/~davidk/swat3/cce_ua-20110915-1617-sd4svyo2.log
> > > > > > > > David
> > > > > > > > > "Papia
> > > > > > > > > Sent: Thursday, September 15, 2011 2:39:47 PM
> > > > > > > > > The sites.xml in /homes/papia/SwiftSCE2 seems to be
> > > > > > > > > using
> > > > > > > > > passive
> > > > > > > > > persistent coasters. Is there a way to use automatic
> > > > > > > > > coasters on
> > > > > > > > > the
> > > > > > > > > MCS workstations? I'll try copying this over to PADS
> > > > > > > > > and
> > > > > > > > > running
> > > > > > > > > there
> > > > > > > > > to see if I can reproduce it.
> > > > > > > > > David
> > > > > > > > > > "Papia
> > > > > > > > > > Rizwan" <papia.rizwan at gmail.com>, "Mihael Hategan"
> > > > > > > > > > Sent: Thursday, September 15, 2011 2:18:17 PM
> > > > > > > > > > Can you make SWAT run under trunk, as Papia is
> > > > > > > > > > testing
> > > > > > > > > > using
> > > > > > > > > > standard
> > > > > > > > > > auto coasters, and doesnt need any of the missing
> > > > > > > > > > coaster-service
> > > > > > > > > > options.
> > > > > > > > > > - Mike
> > > > > > > > > > > "Papia
> > > > > > > > > > > Sent: Thursday, September 15, 2011 2:15:36 PM
> > > > > > > > > > > I got past the compilation errors by renaming the
> > > > > > > > > > > all
> > > > > > > > > > > functions
> > > > > > > > > > > with
> > > > > > > > > > > capitalization, but ran into an issue with
> > > > > > > > > > > coaster-service.
> > > > > > > > > > > Last
> > > > > > > > > > > week
> > > > > > > > > > > I noticed coaster-service was missing options for
> > > > > > > > > > > dynamic
> > > > > > > > > > > ports.
> > > > > > > > > > > I
> > > > > > > > > > > found today that it is also missing -passive. I'll
> > > > > > > > > > > try
> > > > > > > > > > > to
> > > > > > > > > > > track
> > > > > > > > > > > down
> > > > > > > > > > > where this changed and restore the previous
> > > > > > > > > > > version.
> > > > > > > > > > > David
> > > > > > > > > > > > "Papia
> > > > > > > > > > > > Hategan"
> > > > > > > > > > > > Sent: Thursday, September 15, 2011 12:37:13 PM
> > > > > > > > > > > > Excellent, thanks - thats good. I also just
> > > > > > > > > > > > verified
> > > > > > > > > > > > that
> > > > > > > > > > > > Papia
> > > > > > > > > > > > is
> > > > > > > > > > > > not
> > > > > > > > > > > > using the overAllocation tags in the sites file,
> > > > > > > > > > > > so
> > > > > > > > > > > > this
> > > > > > > > > > > > problem
> > > > > > > > > > > > is
> > > > > > > > > > > > clearly a Java deadlock and has nothing to do
> > > > > > > > > > > > with
> > > > > > > > > > > > the
> > > > > > > > > > > > scheduling
> > > > > > > > > > > > problem that the (now fixed) overAllocation
> > > > > > > > > > > > problem
> > > > > > > > > > > > was
> > > > > > > > > > > > causing..
> > > > > > > > > > > > My understanding is that this SWAT script is
> > > > > > > > > > > > failing
> > > > > > > > > > > > under
> > > > > > > > > > > > trunk
> > > > > > > > > > > > because of the recent token case handling issue
> > > > > > > > > > > > (I
> > > > > > > > > > > > think
> > > > > > > > > > > > the
> > > > > > > > > > > > camel-case one). Can you work with Papia to see
> > > > > > > > > > > > if
> > > > > > > > > > > > either
> > > > > > > > > > > > that
> > > > > > > > > > > > issue
> > > > > > > > > > > > is now fixed, or if her script can be changed to
> > > > > > > > > > > > avoid
> > > > > > > > > > > > that,
> > > > > > > > > > > > so
> > > > > > > > > > > > that
> > > > > > > > > > > > you can both test the SWAT script with trunk, to
> > > > > > > > > > > > see
> > > > > > > > > > > > if
> > > > > > > > > > > > the
> > > > > > > > > > > > deadlock
> > > > > > > > > > > > still occurs?
> > > > > > > > > > > > Thanks,
> > > > > > > > > > > > - MIke
> > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > Hategan"
> > > > > > > > > > > > > Sent: Thursday, September 15, 2011 12:29:03 PM
> > > > > > > > > > > > > I narrowed down the problem a bit. Last night
> > > > > > > > > > > > > I
> > > > > > > > > > > > > ran
> > > > > > > > > > > > > jstack
> > > > > > > > > > > > > on
> > > > > > > > > > > > > the
> > > > > > > > > > > > > wrong java process which is why it didn't
> > > > > > > > > > > > > report
> > > > > > > > > > > > > a
> > > > > > > > > > > > > deadlock.
> > > > > > > > > > > > > Papia and I are seeing the same issue.
> > > > > > > > > > > > > My jstack:
> > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat2/jstack.log
> > > > > > > > > > > > > Papia's jstack:
> > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat2/papia-jstack.log
> > > > > > > > > > > > > It happens in the same place:
> > > > > > > > > > > > > org.griphyn.vdl.karajan.lib.cache.File.lock(File.java:100)
> > > > > > > > > > > > > org.griphyn.vdl.karajan.lib.cache.LRUFileCache.addAndLockEntry(LRUFileCache.java:24)
> > > > > > > > > > > > > Filed as bug #559
> > > > > > > > > > > > > David
> > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > Hategan"
> > > > > > > > > > > > > > Sent: Thursday, September 15, 2011 11:46:59
> > > > > > > > > > > > > > AM
> > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > David, it sounds like more analysis is
> > > > > > > > > > > > > > needed
> > > > > > > > > > > > > > here. If
> > > > > > > > > > > > > > the
> > > > > > > > > > > > > > SWAT
> > > > > > > > > > > > > > runs
> > > > > > > > > > > > > > are not showing a deadlock (but your runs
> > > > > > > > > > > > > > are)
> > > > > > > > > > > > > > then
> > > > > > > > > > > > > > likely
> > > > > > > > > > > > > > we
> > > > > > > > > > > > > > have
> > > > > > > > > > > > > > two
> > > > > > > > > > > > > > different problems here.
> > > > > > > > > > > > > > Another case we saw in 0.93 with scripts
> > > > > > > > > > > > > > failing
> > > > > > > > > > > > > > to
> > > > > > > > > > > > > > progress
> > > > > > > > > > > > > > is
> > > > > > > > > > > > > > due
> > > > > > > > > > > > > > to
> > > > > > > > > > > > > > the overAllocation parameter problem that
> > > > > > > > > > > > > > Mihael
> > > > > > > > > > > > > > fixed
> > > > > > > > > > > > > > yesterday.
> > > > > > > > > > > > > > The
> > > > > > > > > > > > > > symptom there is that Swift starts a coaster
> > > > > > > > > > > > > > with
> > > > > > > > > > > > > > a
> > > > > > > > > > > > > > time
> > > > > > > > > > > > > > slot
> > > > > > > > > > > > > > too
> > > > > > > > > > > > > > small for the apps in the script, and no
> > > > > > > > > > > > > > apps
> > > > > > > > > > > > > > wind
> > > > > > > > > > > > > > up
> > > > > > > > > > > > > > running.
> > > > > > > > > > > > > > I
> > > > > > > > > > > > > > think
> > > > > > > > > > > > > > that situation in general merits a separate
> > > > > > > > > > > > > > ticket,
> > > > > > > > > > > > > > and
> > > > > > > > > > > > > > may
> > > > > > > > > > > > > > have
> > > > > > > > > > > > > > been
> > > > > > > > > > > > > > discussed on swift-devel (but quite a while
> > > > > > > > > > > > > > ago).
> > > > > > > > > > > > > > Can you determine if indeed Papia's SWAT
> > > > > > > > > > > > > > runs
> > > > > > > > > > > > > > are
> > > > > > > > > > > > > > hanging
> > > > > > > > > > > > > > for
> > > > > > > > > > > > > > a
> > > > > > > > > > > > > > reason
> > > > > > > > > > > > > > other than a Java deadlock?
> > > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > > > From: "David Kelly"
> > > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > > Hategan"
> > > > > > > > > > > > > > > Sent: Thursday, September 15, 2011 8:03:09
> > > > > > > > > > > > > > > AM
> > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > The jstack log corresponds to the most
> > > > > > > > > > > > > > > recent
> > > > > > > > > > > > > > > log
> > > > > > > > > > > > > > > file -
> > > > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat/cce_ua-20110914-1934-frd3thja.log.
> > > > > > > > > > > > > > > jstack does not report any deadlocks, but
> > > > > > > > > > > > > > > I
> > > > > > > > > > > > > > > thought
> > > > > > > > > > > > > > > it
> > > > > > > > > > > > > > > might
> > > > > > > > > > > > > > > be
> > > > > > > > > > > > > > > useful
> > > > > > > > > > > > > > > so I included it. Swift was not making any
> > > > > > > > > > > > > > > progress
> > > > > > > > > > > > > > > for
> > > > > > > > > > > > > > > about
> > > > > > > > > > > > > > > 5
> > > > > > > > > > > > > > > hours
> > > > > > > > > > > > > > > before I sent the logs. I am running the
> > > > > > > > > > > > > > > latest
> > > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > > branch.
> > > > > > > > > > > > > > > I
> > > > > > > > > > > > > > > will
> > > > > > > > > > > > > > > try again today.
> > > > > > > > > > > > > > > David
> > > > > > > > > > > > > > > > To: "David Kelly"
> > > > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > > > "Mihael
> > > > > > > > > > > > > > > > Hategan"
> > > > > > > > > > > > > > > > 5:54:11
> > > > > > > > > > > > > > > > AM
> > > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > > David, which of the many Swift logs in
> > > > > > > > > > > > > > > > that
> > > > > > > > > > > > > > > > /swat
> > > > > > > > > > > > > > > > dir
> > > > > > > > > > > > > > > > does
> > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > jstack.log pertain to? How many of these
> > > > > > > > > > > > > > > > runs
> > > > > > > > > > > > > > > > deadlocked?
> > > > > > > > > > > > > > > > And, did you verify that you (and Papia)
> > > > > > > > > > > > > > > > are
> > > > > > > > > > > > > > > > running
> > > > > > > > > > > > > > > > on
> > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > latest
> > > > > > > > > > > > > > > > rev
> > > > > > > > > > > > > > > > of the 0.93 branch?
> > > > > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > > > > > From: "David Kelly"
> > > > > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > > > > "Michael
> > > > > > > > > > > > > > > > > Wilde"
> > > > > > > > > > > > > > > > > Sent: Wednesday, September 14, 2011
> > > > > > > > > > > > > > > > > 11:04:41
> > > > > > > > > > > > > > > > > PM
> > > > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > > > I was able to reproduce the problem
> > > > > > > > > > > > > > > > > with
> > > > > > > > > > > > > > > > > persistent
> > > > > > > > > > > > > > > > > coasters
> > > > > > > > > > > > > > > > > on
> > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > > MCS servers.
> > > > > > > > > > > > > > > > > The jstack output is at
> > > > > > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat/jstack.log
> > > > > > > > > > > > > > > > > The full collection of logs are at
> > > > > > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat.
> > > > > > > > > > > > > > > > > David
> > > > > > > > > > > > > > > > > > To: "Michael Wilde"
> > > > > > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > > > > > 10:30:48
> > > > > > > > > > > > > > > > > > PM
> > > > > > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > > > > Could you also forward the
> > > > > > > > > > > > > > > > > > please?
> > > > > > > > > > > > > > > > > > Mihael
> > > > > > > > > > > > > > > > > > On Wed, 2011-09-14 at 14:46 -0500,
> > > > > > > > > > > > > > > > > > Michael
> > > > > > > > > > > > > > > > > > Wilde
> > > > > > > > > > > > > > > > > > wrote:
> > > > > > > > > > > > > > > > > > > I think I am seeing a similar
> > > > > > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > > > > > on
> > > > > > > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > > > > > > in
> > > > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > > > > ParVis
> > > > > > > > > > > > > > > > > > > script,
> > > > > > > > > > > > > > > > > > > and am trying to get a clean log
> > > > > > > > > > > > > > > > > > > and
> > > > > > > > > > > > > > > > > > > jstack
> > > > > > > > > > > > > > > > > > > to
> > > > > > > > > > > > > > > > > > > confirm.
> > > > > > > > > > > > > > > > > > > As far as I can tell, Papia is
> > > > > > > > > > > > > > > > > > > running
> > > > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > > > > correct
> > > > > > > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > > > > > > code,
> > > > > > > > > > > > > > > > > > > but
> > > > > > > > > > > > > > > > > > > please verify.
> > > > > > > > > > > > > > > > > > > David will try to replicate this
> > > > > > > > > > > > > > > > > > > problem
> > > > > > > > > > > > > > > > > > > as
> > > > > > > > > > > > > > > > > > > well.
> > > > > > > > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > > > > > > > > From: "Papia Rizwan"
> > > > > > > > > > > > > > > > > > > > To: "swift-devel Devel"
> > > > > > > > > > > > > > > > > > > > "Michael
> > > > > > > > > > > > > > > > > > > > Wilde" <wilde at mcs.anl.gov>,
> > > > > > > > > > > > > > > > > > > > "Michael
> > > > > > > > > > > > > > > > > > > > P.
> > > > > > > > > > > > > > > > > > > > Shields"
> > > > > > > > > > > > > > > > > > > > <mpshields at anl.gov>
> > > > > > > > > > > > > > > > > > > > 2011
> > > > > > > > > > > > > > > > > > > > 1:56:13 PM
> > > > > > > > > > > > > > > > > > > > Subject: swift 0.93 deadlock
> > > > > > > > > > > > > > > > > > > > Attached are the jstack output
> > > > > > > > > > > > > > > > > > > > and
> > > > > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > > > > > log
> > > > > > > > > > > > > > > > > > > > file.
> > > > > > > > > > > > > > > > > > > > Papia Rizwan
> > > > > > > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > > > > > > Swift-devel mailing list
> > > > > > > > > > > > > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > > > > > > > > > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > > > > > > > > > > > > > > > Michael Wilde
> > > > > > > > > > > > > > > > Computation Institute, University of
> > > > > > > > > > > > > > > > Chicago
> > > > > > > > > > > > > > > > Mathematics and Computer Science
> > > > > > > > > > > > > > > > Division
> > > > > > > > > > > > > > > > Argonne National Laboratory
> > > > > > > > > > > > > > Michael Wilde
> > > > > > > > > > > > > > Computation Institute, University of Chicago
> > > > > > > > > > > > > > Mathematics and Computer Science Division
> > > > > > > > > > > > Michael Wilde
> > > > > > > > > > Michael Wilde
> Michael Wilde
