[Swift-devel] swift 0.93 deadlock
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Sep 23 12:44:53 CDT 2011
On Fri, 2011-09-23 at 10:56 -0500, Michael Wilde wrote:
> Ok, I just picked up 5143 in my 0.93 build on Fusion.  I'll keep an
> eye out to see if my not-infrequent deadlock goes away. I see that its
> in the same code region that I seem to be deadlocking in.
> When you said earlier in this thread "> Not quite. But somewhat
> close." - do you suspect yet another deadlock in the same code, or do
> you believe that your fix addresses the one I reported in addition to
> the ones that David and Papia were encountering?
r5143 is a fix specifically for this deadlock.
