[Swift-devel] persistent coasters and data staging
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Sep 22 13:57:05 CDT 2011
What I see in the log is the error about the invalid path, which, as I
mentioned before, is  an issue of var_str seemingly being empty (you may
want to trace its value though to confirm). I don't see anything about a
stagein/out issue.
Mihael
On Wed, 2011-09-21 at 16:24 -0500, Ketan Maheshwari wrote:
> Hi Mihael,
> I tested this fix. It seems that the timeout issue for large-ish data
> and throttle > ~30 persists. I am not sure if this is data staging
> timeout though.
> The setup that fails is as follows:
> persistent coasters, resource= workers running on OSG
> data size=8MB, 100 data items.
> foreach throttle=40=jobthrottle.
> The standard output seems intermittently showing some activity and
> then getting back to no activity without any progress on tasks.
> Please find the log and stdouterr
> here: http://www.ci.uchicago.edu/~ketan/coaster-lab/std.out.err,
>  http://www.ci.uchicago.edu/~ketan/coaster-lab/catsn-20110921-1535-v0t3gcg5.log
> When I tested with small data, 1MB, 2MB, 4MB, it did work. 4MB
> displayed a fat tail behavior though, ~94 tasks completing steadily
> and quickly while the last 5-6 tasks taking disproportionate times.
> The throttle in these cases was <= 30.
> Regards,
> Ketan
> On Mon, Sep 12, 2011 at 7:19 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         Try now please (cog r3262).
>         On Mon, 2011-09-12 at 15:56 -0500, Ketan Maheshwari wrote:
>         > Mihael,
>         > I tried with the new worker.pl, running a 100 task 10MB per
>         task run
>         > with throttle set at 100.
>         > However, it seems to have failed with the same symptoms of
>         timeout
>         > error 521:
>         > Caused by: null
>         > Caused by:
>         org.globus.cog.abstraction.impl.common.execution.JobException:
>         Job
>         > failed with an exit code of 521
>         > Progress:  time: Mon, 12 Sep 2011 15:45:31 -0500
>          Submitted:53
>         >  Active:1  Failed:46
>         > Progress:  time: Mon, 12 Sep 2011 15:45:34 -0500
>          Submitted:53
>         >  Active:1  Failed:46
>         > Exception in cat:
>         > Arguments: [gpfs/pads/swift/ketan/indir10/data0002.txt]
>         > Host: grid
>         > Directory: catsn-20110912-1521-8jh2gar4/jobs/u/cat-u18visfk
>         > Caused by: null
>         > Caused by:
>         Job
>         > Progress:  time: Mon, 12 Sep 2011 15:45:45 -0500
>          Submitted:52
>         >  Active:1  Failed:47
>         > Exception in cat:
>         > Arguments: [gpfs/pads/swift/ketan/indir10/data0014.txt]
>         > Host: grid
>         > Directory: catsn-20110912-1521-8jh2gar4/jobs/x/cat-x18visfk
>         > I had about 107 workers running at the time of these
>         failures.
>         > I started seeing the failure messages after about 20 minutes
>         into this
>         > run.
>         > The logs are in http://www.ci.uchicago.edu/~ketan/pack.tgz
>         > Regards,
>         > Ketan
>         > On Mon, Sep 12, 2011 at 1:56 PM, Mihael Hategan
>         > wrote:
>         >         On Mon, 2011-09-12 at 11:58 -0500, Ketan Maheshwari
>         wrote:
>         >         > After some discussion with Mike, Our conclusion
>         from these
>         >         runs was
>         >         > that the parallel data transfers are causing
>         timeouts from
>         >         the
>         >         > worker.pl, further, we were undecided if somehow
>         the timeout
>         >         threshold
>         >         > is set too agressive plus how are they determined
>         and
>         >         whether a change
>         >         > in that value could resolve the issue.
>         >         Something like that. Worker.pl would use the time
>         when a file
>         >         transfer
>         >         started to determine timeouts. This is undesirable.
>         The
>         >         purpose of
>         >         timeouts is to determine whether the other side has
>         stopped
>         >         from
>         >         properly following the flow of things. It follows
>         that any
>         >         kind of
>         >         activity should reset the timeout... timer.
>         >         I updated the worker code to deal with the issue in
>         a proper
>         >         way. But
>         >         now I need your help. This is perl code, and it
>         needs testing.
>         >         So can you re-run, first with some simple test that
>         uses
>         >         coaster staging
>         >         (just to make sure I didn't mess something up), and
>         then the
>         >         version of
>         >         your tests that was most likely to fail?
>         > Ketan
> Ketan
