[Swift-devel] persistent coasters and data staging
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Wed Sep 21 16:24:06 CDT 2011
Hi Mihael,
I tested this fix. It seems that the timeout issue for large-ish data and
throttle > ~30 persists. I am not sure if this is data staging timeout
though.
The setup that fails is as follows:
persistent coasters, resource= workers running on OSG
data size=8MB, 100 data items.
foreach throttle=40=jobthrottle.
The standard output seems intermittently showing some activity and then
getting back to no activity without any progress on tasks.
Please find the log and stdouterr here:
http://www.ci.uchicago.edu/~ketan/coaster-lab/std.out.err,
http://www.ci.uchicago.edu/~ketan/coaster-lab/catsn-20110921-1535-v0t3gcg5.log
When I tested with small data, 1MB, 2MB, 4MB, it did work. 4MB displayed a
fat tail behavior though, ~94 tasks completing steadily and quickly while
the last 5-6 tasks taking disproportionate times. The throttle in these
cases was <= 30.
Ketan
On Mon, Sep 12, 2011 at 7:19 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Try now please (cog r3262).
> On Mon, 2011-09-12 at 15:56 -0500, Ketan Maheshwari wrote:
> > Mihael,
> > I tried with the new worker.pl, running a 100 task 10MB per task run
> > with throttle set at 100.
> > However, it seems to have failed with the same symptoms of timeout
> > error 521:
> > Caused by: null
> > Caused by:
> > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > failed with an exit code of 521
> > Progress:  time: Mon, 12 Sep 2011 15:45:31 -0500  Submitted:53
> >  Active:1  Failed:46
> > Progress:  time: Mon, 12 Sep 2011 15:45:34 -0500  Submitted:53
> >  Active:1  Failed:46
> > Exception in cat:
> > Arguments: [gpfs/pads/swift/ketan/indir10/data0002.txt]
> > Host: grid
> > Directory: catsn-20110912-1521-8jh2gar4/jobs/u/cat-u18visfk
> > Caused by: null
> > Caused by:
> > Progress:  time: Mon, 12 Sep 2011 15:45:45 -0500  Submitted:52
> >  Active:1  Failed:47
> > Exception in cat:
> > Arguments: [gpfs/pads/swift/ketan/indir10/data0014.txt]
> > Host: grid
> > Directory: catsn-20110912-1521-8jh2gar4/jobs/x/cat-x18visfk
> > I had about 107 workers running at the time of these failures.
> > I started seeing the failure messages after about 20 minutes into this
> > run.
> > The logs are in http://www.ci.uchicago.edu/~ketan/pack.tgz
> > Regards,
> > Ketan
> > On Mon, Sep 12, 2011 at 1:56 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         On Mon, 2011-09-12 at 11:58 -0500, Ketan Maheshwari wrote:
> >         > After some discussion with Mike, Our conclusion from these
> >         runs was
> >         > that the parallel data transfers are causing timeouts from
> >         the
> >         > worker.pl, further, we were undecided if somehow the timeout
> >         threshold
> >         > is set too agressive plus how are they determined and
> >         whether a change
> >         > in that value could resolve the issue.
> >         Something like that. Worker.pl would use the time when a file
> >         transfer
> >         started to determine timeouts. This is undesirable. The
> >         purpose of
> >         timeouts is to determine whether the other side has stopped
> >         from
> >         properly following the flow of things. It follows that any
> >         kind of
> >         activity should reset the timeout... timer.
> >         I updated the worker code to deal with the issue in a proper
> >         way. But
> >         now I need your help. This is perl code, and it needs testing.
> >         So can you re-run, first with some simple test that uses
> >         coaster staging
> >         (just to make sure I didn't mess something up), and then the
> >         version of
> >         your tests that was most likely to fail?
> > Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110921/6e19500c/attachment.html>
