[Swift-devel] User guide version
    Thomas Uram
    turam at mcs.anl.gov
    Wed Sep 14 16:39:45 CDT 2011
When will the user guide be updated? We've been using import in 0.92 and discovered today that there are useful bits there that are incorrectly documented in the current user guide:
http://www.ci.uchicago.edu/swift/guides/userguide.php#imports
but correct in the "trunk" user guide:
http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_imports
Specifically, the new guide correctly states that the import argument should be quoted, and that imported scripts can occur anywhere on the path defined by the SWIFT_LIB environment variable. That last portion is a very useful addition for us.
Tom
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110914/ce3f08ec/attachment.html>
