[Swift-devel] queuedsize > 0 but no job dequeued
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Sep  1 13:43:47 CDT 2011
Is there any chance that some of your jobs run longer than their
requested walltime?
On Wed, 2011-08-31 at 09:04 -0500, Ketan Maheshwari wrote:
> Mihael,
> I did the run with the debug enabled on coasters. Please find the logs
> etc, for this run here:
> http://www.ci.uchicago.edu/~ketan/run25.tgz
> Note that the run went well and ran upto 20k jobs without issues.
> After that I did not get nodes so I stopped it and resumed it this
> morning. It ran for about 1000+ jobs and crashed with the same error
> message.
> Regards,
> Ketan
> On Tue, Aug 30, 2011 at 3:05 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         Any chance you can re-run this with debug enabled on coasters
>         (log4j.logger.org.globus.cog.abstraction.coaster=DEBUG)?
>         On Mon, 2011-08-29 at 20:55 -0700, Mihael Hategan wrote:
>         > My bad. The info is in the swift log.
>         > On Mon, 2011-08-29 at 20:59 -0500, Ketan Maheshwari wrote:
>         > > This is on Beagle. I am running local:pbs from /lustre.
>         > > On Mon, Aug 29, 2011 at 8:30 PM, Mihael Hategan
>         > > wrote:
>         > >         On Mon, 2011-08-29 at 19:52 -0500, Ketan
>         Maheshwari wrote:
>         > >         > Mihael,
>         > >         > This run was with automatic coasters. I do not
>         see any
>         > >         specific
>         > >         > coasters.log file written during this run
>         in .globus/coaster
>         > >         nor in
>         > >         > the run's work dir.
>         > >         It's on the remote site in .globus/coasters.
>         > >         > Ketan
>         > >         > On Mon, Aug 29, 2011 at 7:16 PM, Mihael Hategan
>         > >         > wrote:
>         > >         >         Can I have the coasters log please?
>         > >         >         On Sun, 2011-08-28 at 16:47 -0500, Ketan
>         Maheshwari
>         > >         wrote:
>         > >         >         > Hello,
>         > >         >         > I remember this error happened in the
>         past with
>         > >         Glen's and
>         > >         >         Sheri's
>         > >         >         > runs. I saw this today again on Beagle
>         with 0.93
>         > >         while
>         > >         >         running the
>         > >         >         > DSSAT run.
>         > >         >         > The run stops with the following
>         complete message:
>         > >         >         > queuedsize > 0 but no job dequeued.
>         Queued: {}
>         > >         >         > java.lang.Throwable
>         > >         >         >     at
>         org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:269)
>         > >         >         >     at
>         org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:539)
>         > >         >         >     at
>         org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:110)
>         Queued: {}
>         > >         >         > java.lang.Throwable
>         > >         >         >     at
>         > >         >         >     at
>         > >         >         >     at
>         > >         >         > Progress:  time: Sun, 28 Aug 2011
>         13:34:26 -0600
>         > >         >          Submitted:76
>         > >         >         >  Active:23  Checking status:1
>          Finished
>         > >         successfully:597
>         > >         >         > The logs, properties and sources for
>         this run are:
>         http://www.ci.uchicago.edu/~ketan/run23.tgz
>         > >         >         > Regards,
>         > >         >         > Ketan
>         _______________________________________________
>         > >         >         > Swift-devel mailing list
>         > >         >         > Swift-devel at ci.uchicago.edu
>         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>         > >         > Ketan
>         > > Ketan
> Ketan
