[Swift-devel] coasters won't start
Jonathan Monette jonmon at mcs.anl.gov
Fri Oct 21 14:36:20 CDT 2011
The same version is appearing in 0.92.  I know my scripts were working with 0.92 so maybe this is a firewall issue.  Does any one know if coasters uses the GLOBUS_*_PORT_RANGE for the open ports to try?  If they do I can try setting those appropriate values and try.
On Oct 21, 2011, at 2:29 PM, David Kelly wrote:
> You could also try with a known good version (0.92, or a previous version of 0.93 you have had success with). That should narrow down the problem a bit.
> David
>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> To: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
>> Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Friday, October 21, 2011 2:10:17 PM
>> Subject: Re: [Swift-devel] coasters won't start
>> Recently. This is with the compiled binaries of the 0.93RC3 release. I
>> jut downloaded the tar ball from the wwwdev site. And I am not sure
>> how to even probe the ports coasters is trying to use. When running my
>> scripts the service tries to start and fails, at least that is what
>> the log looks like.
>> On Oct 21, 2011, at 1:58 PM, Ketan Maheshwari wrote:
>> Jon,
>> There were some changes in the firewalls rules in terms of allowed
>> open ports on various ci machines. A long shot, but may be you want to
>> check on that.
>> Can you paste your sites.xml and I can take a look if I find
>> something.
>> Ketan
>> On Fri, Oct 21, 2011 at 1:50 PM, Jonathan Monette < jonmon at mcs.anl.gov
>>> wrote:
>> Anyone have a thought on this? Not sure what is wrong. I can't seem to
>> get coasters registered from PADS or Beagle. The log also specifies a
>> FileNotFoundException when trying to transfer back the wrapper log.
>> Does this have something to do with the problem? I have been assuming
>> that this error was being thrown due to the coaster service not
>> connecting.
>> On Oct 20, 2011, at 3:04 PM, Jonathan Monette wrote:
>> Here is a log saying that the coaster service isn't starting, at least
>> that is what the log is saying. This is with on PADS with automatic
>> coasters using 0.93RC3.
>> http://www.ci.uchicago.edu/~jonmon/logs/coasters_wont_start.log
>> And here is the coaster log in zipped form
>> http://www.ci.uchicago.edu/~jonmon/logs/coasters.tar.gz
>> All the files used for this run are located in
>> ~jonmon/PADS/Swift/SwiftMontage/m101_tutorial/run.0039 on the ci
>> network.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Ketan
