[Swift-devel] coasters won't start
David Kelly davidk at ci.uchicago.edu
Fri Oct 21 14:29:35 CDT 2011
You could also try with a known good version (0.92, or a previous version of 0.93 you have had success with). That should narrow down the problem a bit.
David
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> Sent: Friday, October 21, 2011 2:10:17 PM
> Subject: Re: [Swift-devel] coasters won't start
> Recently. This is with the compiled binaries of the 0.93RC3 release. I
> jut downloaded the tar ball from the wwwdev site. And I am not sure
> how to even probe the ports coasters is trying to use. When running my
> scripts the service tries to start and fails, at least that is what
> the log looks like.
> On Oct 21, 2011, at 1:58 PM, Ketan Maheshwari wrote:
> Jon,
> There were some changes in the firewalls rules in terms of allowed
> open ports on various ci machines. A long shot, but may be you want to
> check on that.
> Can you paste your sites.xml and I can take a look if I find
> something.
> Ketan
> On Fri, Oct 21, 2011 at 1:50 PM, Jonathan Monette < jonmon at mcs.anl.gov
> > wrote:
> Anyone have a thought on this? Not sure what is wrong. I can't seem to
> get coasters registered from PADS or Beagle. The log also specifies a
> FileNotFoundException when trying to transfer back the wrapper log.
> Does this have something to do with the problem? I have been assuming
> that this error was being thrown due to the coaster service not
> connecting.
> On Oct 20, 2011, at 3:04 PM, Jonathan Monette wrote:
> Here is a log saying that the coaster service isn't starting, at least
> that is what the log is saying. This is with on PADS with automatic
> coasters using 0.93RC3.
> http://www.ci.uchicago.edu/~jonmon/logs/coasters_wont_start.log
> And here is the coaster log in zipped form
> http://www.ci.uchicago.edu/~jonmon/logs/coasters.tar.gz
> All the files used for this run are located in
> ~jonmon/PADS/Swift/SwiftMontage/m101_tutorial/run.0039 on the ci
> network.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
