[Swift-devel] Swift gsiftp staging issues on OSG
Ketan Maheshwari ketancmaheshwari at gmail.com
Mon Oct 17 08:46:00 CDT 2011
Mihael,
I've been updating the wiki page with the test results you listed. So far I
tested for 7 OSG sites out of which 2 failed and 5 worked. I've uploaded
logs for each test that you can check from the link alongside each test.
I'll carry on with further tests.
Ketan
On Sun, Oct 16, 2011 at 3:06 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> There are craploads of errors in there of all kinds and sorts, but very
> few of them are actual transfer problems. It looks more like
> gridftp/filesystem configuration issues.
> I attached a sorted list of exception.
> However, this is irrelevant. It looks like so far we keep running this
> test that clearly doesn't work and hope that it will work. That's silly.
> We need to figure out each problem individually and fix things one by
> one.
> So here's my proposal. We list all the problems that can be seen in that
> log and try to fix them in order. And we do not re-run the whole thing
> unless we actually solved at least one problem. Also, we sync
> periodically on what was done (i.e. we keep a list that we update
> immediately after something was done about an item). Also, before doing
> an integration test after a problem is fixed, we do a test for that
> specific problem/on a specific site only. There is way too much noise in
> these big runs and that makes it very hard to see what is happening.
> So here's a first list:
> http://www.ci.uchicago.edu/wiki/bin/view/SWFT/OSGTesting
> On Sun, 2011-10-16 at 09:54 -0500, Ketan Maheshwari wrote:
> > Hello,
> > While running an Extenci workflow on OSG with persistent coasters
> > (multiple coasters services, 1 per OSG site) and gsiftp staging, I am
> > facing some gridftp related issues. Following are some details of the
> > run:
> > A set of 15 OSG sites were selected after testing them for being
> > responsive ('greensites'). I performed a separate guc test on these
> > sites which seemed to have succeeded for each site (200MB roundtrip
> > transfer in 7 mins for all sites).
> > However, while running my workflow from Swift, many of these transfers
> > fail showing a variety of errors, most pertaining to the data
> > transfers.
> > I noticed, that these transfers fail irrespective of data sizes (250K
> > - 150M) and also seems to fail intermittently for different sites.
> > The log for this run is
> > here:
> http://www.mcs.anl.gov/~ketan/postproc-gridftp-20111013-2324-5qzebq16.log
> > I am providing a 7G of Heap space at Swift commandline and the host
> > has 50G of total memory.
> > Any ideas?
> > Regards,
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111017/7aaf98a5/attachment.html>
