[Swift-devel] Where is latest doc on running Swift on Beagle? Covers OpenMP apps?
Michael Wilde
wilde at mcs.anl.gov
Sun Oct 16 11:15:35 CDT 2011
David, Ketan,
I need to run some things on Beagle, asap.
Ketan, where is the latest and best documentation for this? I see your edits below to the 0.93 Site Guide. But I dont see that online where I would expect it:
http://www.ci.uchicago.edu/swift/wwwdev/guides/release-0.93/siteguide/siteguide.html#_beagle
David, is it just that this document is not being correctly pushed to the wwwdev site on a nightly basis?
Ketan, is the latest info on running Swift on Beagle now all in the siteguide? Is the info you were putting in the cookbook (I see many commits there) now all consolidated into the Site Guide? And is there a difference in sites.xml settings between 0.93 and trunk? Lastly, which release works best?
Second question: I need to run a script that executes many 24-core OpenMP apps. Is the necessary support for this in 0.93? What if any declarations do I need other than to say jobsPerNode=1? Glen, are you running OpenMP on Beagle and if so what release and sites file are you using?
Im assuming Justin's latest changes to sites.xml are in trunk but not 0.93? If that is correct, is there a corresponding site site for Beagle for trunk?
- Mike
----- Forwarded Message -----
To: swift-commit at ci.uchicago.edu
Sent: Sunday, September 18, 2011 10:14:10 PM
Subject: [Swift-commit] r5126 - branches/release-0.93/docs/siteguide
Author: ketan
Date: 2011-09-18 22:14:10 -0500 (Sun, 18 Sep 2011)
New Revision: 5126
Modified:
branches/release-0.93/docs/siteguide/beagle
Log:
added content to beagle siteguide
Modified: branches/release-0.93/docs/siteguide/beagle
--- branches/release-0.93/docs/siteguide/beagle 2011-09-19 02:41:02 UTC (rev 5125)
+++ branches/release-0.93/docs/siteguide/beagle 2011-09-19 03:14:10 UTC (rev 5126)
@@ -52,9 +52,38 @@
A key factor in scaling up Swift runs on Beagle is to setup the sites.xml parameters.
The following sites.xml parameters must be set to scale that is intended for a large run:
- * walltime: The expected walltime for completion of your run. This parameter is accepted in seconds.
- * slots: Number of qsub jobs needs to be submitted by swift. This number will determine how many qsubs swift will submit for your run. Typical values range between 40 and 80 for large runs.
- * nodegranularity: Determines the number of nodes per job. Total nodes will thus be slots times nodegranularity. This may vary for advanced configurations though.
- * maxnodes: Determines the maximum number of nodes a job must pack into its qsub. This parameter determines the largest single job that your run will submit.
+ * *maxTime* : The expected walltime for completion of your run. This parameter is accepted in seconds.
+ * *slots* : Number of qsub jobs needs to be submitted by swift. This number will determine how many qsubs swift will submit for your run. Typical values range between 40 and 80 for large runs.
+ * *nodeGranularity* : Determines the number of nodes per job. Total nodes will thus be slots times nodegranularity. This may vary for advanced configurations though.
+ * *maxNodes* : Determines the maximum number of nodes a job must pack into its qsub. This parameter determines the largest single job that your run will submit.
+ * *jobThrottle* : A factor that determines the number of tasks dispatched simultaneously. The intended number of simultaneous tasks must match the number of cores targeted. The number of tasks is calculated from the jobThrottle factor is as follows:
+Number of Tasks = (JobThrottle x 100) + 1
+Following is an example sites.xml for a 50 slots run with each slot occupying 4 nodes (thus, a 200 node run):
+<config>
+ <pool handle="pbs">
+ <execution provider="coaster" jobmanager="local:pbs"/>
+ <profile namespace="globus" key="project">CI-CCR000013</profile>
+ <profile namespace="globus" key="ppn">24:cray:pack</profile>
+ <profile namespace="globus" key="jobsPerNode">24</profile>
+ <profile namespace="globus" key="maxTime">50000</profile>
+ <profile namespace="globus" key="slots">50</profile>
+ <profile namespace="globus" key="nodeGranularity">4</profile>
+ <profile namespace="globus" key="maxNodes">4</profile>
+ <profile namespace="karajan" key="jobThrottle">48.00</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local"/>
+ <workdirectory >/lustre/beagle/ketan/swift.workdir</workdirectory>
+ </pool>
+</config>
Swift-commit mailing list
Swift-commit at ci.uchicago.edu
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-commit
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
