[Swift-devel] 0.93 application not found error
Jonathan Monette jonmon at mcs.anl.gov
Mon Oct 10 18:10:00 CDT 2011
Oh…the log for this run is located at http://www.ci.uchicago.edu/~jonmon/logs/application_not_found.log
On Oct 10, 2011, at 6:08 PM, Jonathan Monette wrote:
> Hello,
>   I am receiving an application not found error in Swift.  I am using 0.93.
> Swift svn swift-r5216 (swift modified locally) cog-r3296
> RunID: 20111010-1758-0gkrrg31
> (input): found 10 files
> Progress:  time: Mon, 10 Oct 2011 17:59:01 -0500
> Progress:  time: Mon, 10 Oct 2011 17:59:03 -0500  Selecting site:8  Active:1 Failed but can retry:1
> Execution failed:
> 	Application /home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mProjectPP_wrap.py failed with an exit code of 127
> Here is the tc.data:
> localhost	mImgtbl			/home/jonmon/Library/Montage/bin/mImgtbl					INSTALLED	INTEL32::LINUX	null
> localhost	mAdd			/home/jonmon/Library/Montage/bin/mAdd						INSTALLED	INTEL32::LINUX	null
> localhost	mJPEG			/home/jonmon/Library/Montage/bin/mJPEG						INSTALLED	INTEL32::LINUX	null
> localhost	mOverlaps		/home/jonmon/Library/Montage/bin/mOverlaps					INSTALLED	INTEL32::LINUX	null
> localhost	mConcatFit		/home/jonmon/Library/Montage/bin/mConcatFit					INSTALLED	INTEL32::LINUX	null
> localhost	mBgModel		/home/jonmon/Library/Montage/bin/mBgModel					INSTALLED	INTEL32::LINUX	null
> localhost	mMakeHdr		/home/jonmon/Library/Montage/bin/mMakeHdr					INSTALLED	INTEL32::LINUX	null
> localhost	Background_list		/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/Background_list.py		INSTALLED	INTEL32::LINUX	null
> localhost	create_status_table	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/create_status_table.py	INSTALLED	INTEL32::LINUX	null
> localhost	mFitplane_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mFitplane_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
> localhost	mDiffFit_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mDiffFit_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
> localhost	mDiff_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mDiff_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
> localhost	mProjectPP_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mProjectPP_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
> localhost	mProject_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mProject_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
> localhost	mBackground_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mBackground_wrap.py	INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
> Here is the site file:
> <config>
> <pool handle="localhost">
>   <execution provider="local" />
>   <filesystem provider="local" />
>   <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/localhost</workdirectory>
>   <profile namespace="karajan" key="jobThrottle">.05</profile>
>   <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
> </pool>
> </config>
> and here is the config file:
> execution.retries=0
> sitedir.keep=true
> status.mode=provider
> wrapper.log.always.transfer=true
> foreach.maxthreads=1024
> wrapper.parameter.mode=files
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> The log reports the std error from python as "stderr.txt: /bin/sh: mProjectPP: command not found".  I have mProjectPP in my path.
> [jonmon at communicado: ~/PADS/Swift/SwiftMontage/m101_tutorial/run.0030]$ which mProjectPP
> mProjectPP is /home/jonmon/Library/Montage/bin/mProjectPP
> Does anyone know of a reason why this would happen?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111010/0eeca433/attachment.html>
