[Swift-devel] 0.93 application not found error
Jonathan Monette jonmon at mcs.anl.gov
Mon Oct 10 18:08:46 CDT 2011
Hello,
   I am receiving an application not found error in Swift.  I am using 0.93.
Swift svn swift-r5216 (swift modified locally) cog-r3296
RunID: 20111010-1758-0gkrrg31
 (input): found 10 files
Progress:  time: Mon, 10 Oct 2011 17:59:01 -0500
Progress:  time: Mon, 10 Oct 2011 17:59:03 -0500  Selecting site:8  Active:1 Failed but can retry:1
Execution failed:
	Application /home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mProjectPP_wrap.py failed with an exit code of 127
Here is the tc.data:
localhost	mImgtbl			/home/jonmon/Library/Montage/bin/mImgtbl					INSTALLED	INTEL32::LINUX	null
localhost	mAdd			/home/jonmon/Library/Montage/bin/mAdd						INSTALLED	INTEL32::LINUX	null
localhost	mJPEG			/home/jonmon/Library/Montage/bin/mJPEG						INSTALLED	INTEL32::LINUX	null
localhost	mOverlaps		/home/jonmon/Library/Montage/bin/mOverlaps					INSTALLED	INTEL32::LINUX	null
localhost	mConcatFit		/home/jonmon/Library/Montage/bin/mConcatFit					INSTALLED	INTEL32::LINUX	null
localhost	mBgModel		/home/jonmon/Library/Montage/bin/mBgModel					INSTALLED	INTEL32::LINUX	null
localhost	mMakeHdr		/home/jonmon/Library/Montage/bin/mMakeHdr					INSTALLED	INTEL32::LINUX	null
localhost	Background_list		/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/Background_list.py		INSTALLED	INTEL32::LINUX	null
localhost	create_status_table	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/create_status_table.py	INSTALLED	INTEL32::LINUX	null
localhost	mFitplane_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mFitplane_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
localhost	mDiffFit_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mDiffFit_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
localhost	mDiff_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mDiff_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
localhost	mProjectPP_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mProjectPP_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
localhost	mProject_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mProject_wrap.py		INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
localhost	mBackground_wrap	/home/jonmon/Library/Swift/apps/SwiftMontage/scripts/mBackground_wrap.py	INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:00:20"
Here is the site file:
<config>
<pool handle="localhost">
   <execution provider="local" />
   <filesystem provider="local" />
   <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/localhost</workdirectory>
   <profile namespace="karajan" key="jobThrottle">.05</profile>
   <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
 </pool>
</config>
and here is the config file:
execution.retries=0
sitedir.keep=true
status.mode=provider
wrapper.log.always.transfer=true
foreach.maxthreads=1024
wrapper.parameter.mode=files
use.provider.staging=false
provider.staging.pin.swiftfiles=false
The log reports the std error from python as "stderr.txt: /bin/sh: mProjectPP: command not found".  I have mProjectPP in my path.
[jonmon at communicado: ~/PADS/Swift/SwiftMontage/m101_tutorial/run.0030]$ which mProjectPP
mProjectPP is /home/jonmon/Library/Montage/bin/mProjectPP
Does anyone know of a reason why this would happen?
