[Swift-devel] Semantics of multidimensional arrays in Swift
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Fri Nov 18 09:24:08 CST 2011
Hi Ben,
  the way you describe it makes a lot more sense to me (I've spent the last
couple of months teaching Haskell to undergrads so have been in that
mindframe a lot).  I was trying to reverse engineer the semantics from the
actual behaviour of the implementation.  Am I correct then in thinking that
mixing array-wise and cell-wise assignment for the same element like below
is invalid (or at least not an intended use case for swift)?
int a[][];
a[0] = b;
a[0][1] = 2
In the 1d array case swift sometimes seems ok with mixing the two, but
sometimes is unhappy.
int a[];
a[2] = 1;
a = f();
(int r[]) f () {
    r[0] = 1;
    r[1] = 2;
"Compile error in procedure invocation at line 5: variable a has multiple
writers"
but the following compiles and runs fine:
int a[];
a = f();
a[2] = 1;
- Tim
On Fri, Nov 18, 2011 at 3:52 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> The below is based on my gut feeling for how things *should* work, at
> least assuming the existence of array assignment syntax, not how the
> implementation does work.
> Remember this is a declarative language. So then:
> > I initially assumed that 2d arrays were effectively arrays of references
> to arrays, so that the semantics would be as follows:
> > int a[][];
> > int b[];
> > a[0] = b; // Pointer to b in first slot of array a
> > a[0][1] = 2; // insert into b
> First you say  "the value of a[0] is fully described by b" and then
> secondly you say "the value of a[0] is partially described by the statement
> 'element [1] is 2'". Those are contradictory statements.
> Maybe it would be ok to say:
> a[0]=b
> b[1]=2
> If you're using verbs like "insert" it suggests you haven't smoked enough
> swift-crack and are still thinking too imperatively...
> > a[1][1] = 2; // invalid because no array inserted into a[1]
> One interpretation of this working is that declaring an array int a[][]
> means that you have a structure that is indexed by pairs of co-ordinates,
> rather than a structure indexed by one co-ordinate containing a bunch of
> other structures indexed by the other co-ordinate.
> So if you have tuple syntax (x,y) then you are really writing:
> a[(1,1)] = 2
> which is fine, just like a[(0,1)] = 2 is.
> But in that view, what does a[0] means?  something like a[(0,?)]  ? mostly
> I think it would mean "select the subset of values that have left
> co-ordinate 0": if you're using it for extracting a value, you get a 1d
> array out of it. If you're using it for setting values, then:
>  a[0] = b
> would be something like:
> foreach i in b { a[0][i] = b[i]; }
> Whether this is implemented by copying a pointer to b or by copying
> individual values shouldn't affect the end result, as long as its
> implemented properly, and as long as you don't write invalid programs which
> are awkward to detect.
> In my opinion, your program below is invalid, because you are making two
> contradictory declarations of the value of a[0] - on that its entire value
> is determined by b, and another that one of its values is 30.
> If the above model is how things should work, then really you should get a
> runtime error when trying to do this:
> > a[0][3] = 30;
> > a[0] = b;
> and non-deterministic outcome 2 below is incorrect.
> but that this:
> > a[1][0] = 123;
> should work just fine -  there is no concept of "declaring" a[1] to exist
> separate from using it.
> A slightly different way for this to work would be for a[0] = b to
> explicitly be a copy of b elements into a[0], which *would* allow you to
> assign other entries to other a[0][x] positions, as long as they did not
> conflict with elements that came from b. (the usual "can't assign an
> element twice" rule). But maybe that would be less efficient to implement.
> Sorry that the above sounds rather disconnected from implementation and
> abstract - but you are asking about abstract semantics ;)  Feel free to
> demand I explain my views more...
> Ben
> > But a[1][1] = 2 actually succeeds.  As far as I can work out, what
> actually happens is:
> >       • A[i][j] = x;
> >               • A[i] is uninitialised, a new array C is created, and x
> assigned to C[j]
> >               • A[i] is initialised with array C, x is assigned to C[j]
> >       • A[i] = B;
> >               • A[i] is uninitialised, A[i] is then a reference to B
> >               • A[i] is initialised and points to array C, all members
> of B are copied to the corresponding index in C
> > Is this the intended behaviour?  Am I understanding this correctly?
> > In the swift implementation I tested it on, this leads to some
> nondeterminism:
> > int a[][];
> > int b[] = [1,2,3];
> > a[0][3] = 30;
> > a[0] = b;
> > a[1][0] = 123;
> > trace(a[0][0]);
> > trace(a[0][3]);
> > trace(a[1][0]);
> > Nondetermistic outcome 1
> > SwiftScript trace: 1
> > SwiftScript trace: 123
> > Execution failed:
> >     Invalid path ([3]) for a.[0][]/3
> > Nondetermistic outcome 2
> > SwiftScript trace: 30
> > - Tim
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111118/db22a859/attachment.html>
