[Swift-devel] CDM Tests
Michael Wilde
wilde at mcs.anl.gov
Mon Nov 14 10:56:37 CST 2011
Thanks, Ketan - very nice tests and summary document.
I should point out for those that didn't open the doc: the 4 tests with absolute pathnames are failing.
Ketan, can you work with Justin to see if this is a bug, or if the CDM directive needs to be coded differently for absolute paths? Then please test a fix, and as we discussed adapt the tests with annotations to enhance the User Guide section on CDM.
- Mike
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, November 14, 2011 8:13:48 AM
> Subject: [Swift-devel] CDM Tests
> Hello,
> I had a discussion with Mike about testing the CDM behavior for the
> following cases:
> 1. full versus relative paths for input
> 2. full versus relative paths for output
> 3. relative versus absolute option in config property:
> wrapper.invocation.mode
> In this regard, I made 8 tests for all the above combinations. I used
> simple local provider in this first set of tests.
> From the tests it seems that when specifying the relative option on
> the config for wrapper.invocation.mode property the script works
> regardless of the paths of input/output.
> A detailed result with stdout, and paths to logs can be found here:
> https://docs.google.com/spreadsheet/ccc?key=0AmvYSwENKFY9dG44V2VjRXJlUmZLNG9saERFeWZDcUE
> The tests are in my CI dir: /home/ketan/cdm_tests
> Regards, --
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
