[Swift-devel] job fails with exit code 522 and connection to	worker lost
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Nov 10 16:11:29 CST 2011
Looking further into logs, I see java.net.SocketException: Broken pipe
about 12 times in there.
On Thu, Nov 10, 2011 at 4:04 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> Mihael,
> On my latest run of scec workflow after the worker fixes, I see the code
> 522 error message and connection to worker lost issues.
> The run is using OSG sites obtained from a gen_greensites test done this
> morning.
> Looking for error 522 on worker.pl I find this line:
> queueCmd((nullCB(), "JOBSTATUS", $jobid, FAILED, "522", "Could not write
> to file: $!"));
> The log for this run is:
> http://www.ci.uchicago.edu/~ketan/postproc-20111110-0935-kjqnp1d6.log
> Could it be that the recent mods on worker.pl has caused this?
> The OSG sites used are as follows:
> LIGO_UWM_NEMO__osg-nemo-ce.phys.uwm.edu
> OU_OSCER_ATLAS__grid1.oscer.ou.edu
> RENCI-Blueridge__brgw1.renci.org
> FNAL_FERMIGRID__fermigridosg1.fnal.gov
> Regards,
> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111110/b3beed10/attachment.html>
