[Swift-devel] recent error on beagle
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu May 26 15:41:37 CDT 2011
Given that this has now been reported a number of times, it may make
sense to backport the fix from trunk and make a patch release for 0.92.
Objections?
On Thu, 2011-05-26 at 14:59 -0500, Tim Armstrong wrote:
> Hi,
>   I've encountered this issue with SwiftR, running release 0.92 from
> the svn repository.  The issue occurs when
> GLOBUS::maxWallTime="03:55:00" in tc and maxTime is 4 hours in
> sites.xml.  After 5 minutes (or whatever the difference is between the
> two times), I get the exception copied below.  A tarball is attached
> with the logs, script, etc.  replicate.sh shows how to replicate the
> issue on PADS.
> Assuming that my problem is the same as the others, it would be good
> if the fix could be merged to release 0.92, as I'm trying to bundle
> stable swift releases with SwiftR.
> - Tim
> Swift svn swift-r4336 cog-r3096 (cog modified locally)
> RunID: 20110526-1317-2c8ybi10
> Progress:
> SwiftScript trace: top of loop: rserver waiting for input
> on, /tmp/nbest/SwiftR/swift.0827/requestpipe
> Progress:  Active:1
> Progress:  Finished successfully:1
> SwiftScript trace: rserver: got
> dir, /tmp/nbest/SwiftR/requests.P09626/R0000007
> Progress:  uninitialized:1  Finished successfully:1
> Progress:  Submitted:1  Finished successfully:1
> Progress:  Active:1  Finished successfully:1
> queuedsize > 0 but no job dequeued. Queued: {}
> java.lang.Throwable
>         at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>         at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>         at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
> java.lang.Throwable
>         at
>         at
>         at
> Progress:  Finished successfully:1 Failed but can retry:1
> On Sun, May 22, 2011 at 1:51 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         The second one looks to me like a coaster problem. Can't say
>         much about
>         the first issue.
>         Can you try with plain pbs if you want to test the pbs
>         provider?
>         Mihael
>         On Sun, 2011-05-22 at 08:39 -0500, ketan wrote:
>         > I can confirm that the trunk is not usable for pbs provider.
>         I am using
>         > trunk for submitting jobs on beagle and I see a few
>         unexpected things:
>         > 1. The stderr is showing inconsistent messages: The results
>         are getting
>         > written to the output even though stderr doesn't report any.
>         > 2. qsub jobs being cancelled inadvertantly: I submitted 40
>         of them
>         > yesterday, however, only 2 survived today. The log is here:
>         http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-0337-pokpgg89.log
>         > In addition, the ssh-pbs provider does not seem to be
>         working for large
>         > runs (it worked for a small number of test runs): Getting
>         unexpected
>         > stdouts. Following is the stdout:
>         > http://www.ci.uchicago.edu/~ketan/files/ssh-pbs.stdout
>         > Following is the log file for the above run:
>         http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-1750-b0cot9sa.log
>         > Ketan
>         > On 5/21/11 5:12 PM, Michael Wilde wrote:
>         > > ----- Original Message -----
>         > >> On Sat, 2011-05-21 at 17:06 -0400, Glen Hocky wrote:
>         > >>> as I mentioned, I've been running with Mike's swift
>         which was
>         > >>> patched
>         > >>> for beagle. are all the things that make running on
>         beagle work in
>         > >>> trunk?
>         > >> No idea.
>         > >> Mike?
>         > > Justin, working with Ketan, just applied changes to trunk
>         which should make it work now on Beagle (or any Cray XT5+ or
>         XE).  This uses a different set of sites.xml tags than the
>         prototype in the current Beagle swift 0.92.1 module. Justin
>         has a note on this at:
>         > >    https://sites.google.com/site/swiftdevel/sites/pbs/cray
>         > > It was working before for one-node worker jobs; now it
>         should work for multi-node worker jobs as well.
>         > > Justin and Ketan should comment on the state of testing
>         and readiness of this trunk feature.  Don't try trunk on
>         Beagle till they give the go-ahead.
>         > > - Mike
>         > >>>   If so i'll update to the latest and test. I don't
>         think I'm
>         > >>> using stable...
>         > >> Ok
>         > >> Mihael
>         > _______________________________________________
>         > Swift-devel mailing list
>         > Swift-devel at ci.uchicago.edu
>         > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
