[Swift-devel] DataNode.toString()
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed May 25 15:53:21 CDT 2011
Fix in trunk r4530.
On Wed, 2011-05-25 at 15:36 -0500, Justin M Wozniak wrote:
> I think we do want the old behavior for trace().  I can update tracef().
> On Wed, 25 May 2011, Mihael Hategan wrote:
> > data.toString() had this hack that if there was a value, it would return
> > that value (which was assumed useable in fuctional code), otherwise it
> > would return the cryptic stuff.
> > So depending on whether we want the old behavior or not is trace and
> > tracef, I can add a .getValue() where needed.
> > So do we?
> > Mihael
> > On Wed, 2011-05-25 at 14:53 -0500, Justin M Wozniak wrote:
> >> Ok, just so we're all on the same page:
> >> trace("hi", "all");
> >> used to say:
> >> SwiftScript trace: hi, all
> >> now says:
> >> SwiftScript trace: ?:string = hi - Closed, ?:string = all - Closed
> >>> On Wed, 2011-05-25 at 13:20 -0500, Justin M Wozniak wrote:
> >>>> This also affects the behavior of trace().
> >>> Yes. That was the intent. Removing the noise from swiftData.toString().
> >>>>   Might it impact other Swift
> >>>> functionality like mappers?
> >>> I don't think so, but if you can think of a specific scenario, I'm
> >>> listening.
> >>>> On Tue, 17 May 2011, Mihael Hategan wrote:
> >>>>> Indeed. I committed a fix to unwrap swift data when passing values to
> >>>>> execute() (stdin, out, err, and the arguments in particular).
> >>>>> I don't think toString() should be "overloaded" like it was.
> >>>>> On Tue, 2011-05-17 at 16:56 -0500, Justin M Wozniak wrote:
> >>>>>> I think this change affects arguments to apps:
> >>>>>> type file;
> >>>>>> (file f) echo (int i) {
> >>>>>> app { echo i stdout=@f; }
> >>>>>> int greetings = 2;
> >>>>>> file hw = echo(greetings);
> >>>>>> DEBUG vdl:execute2 JOB_START jobid=echo-tnyfi9ak tr=echo
> >>>>>> arguments=[greetings:int = 2.0 - Closed]
> >>>>>> On Fri, 13 May 2011, Mihael Hategan wrote:
> >>>>>>> I changed that in trunk. It used to be:
> >>>>>>> org.griphyn.vdl.mapping.RootDataNode identifier
> >>>>>>> dataset:20110512-2343-5rl3b7x5:720000000072 type Sgt with no value at
> >>>>>>> dataset=sgt_var (not closed)
> >>>>>>> That was annoying, noisy, and I had no idea what's what.
> >>>>>>> It is now:
> >>>>>>> name:type = value - [Open/Closed]
> >>>>>>> The provenance data should still be the same, but it may not. So please
> >>>>>>> let me know if anything breaks.
> >>>>>>> _______________________________________________
> >>>>>>> Swift-devel mailing list
> >>>>>>> Swift-devel at ci.uchicago.edu
> >>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
