[Swift-devel] duplicated job submission in swift-0.92?
Allan Espinosa aespinosa at cs.uchicago.edu
Wed Mar 30 20:06:10 CDT 2011
Wow, I didn't know we can do that!  I treat the docs too canonically :P
2011/3/30 Michael Wilde <wilde at mcs.anl.gov>:
> login1$ cat zz2.swift
> foreach a in [0:3] {
>  trace("for", a);
> login1$ swift zz2.swift
> Swift svn swift-r4157 cog-r3056
> RunID: 20110331-0057-huo8jei0
> Progress:
> SwiftScript trace: for, 1
> SwiftScript trace: for, 3
> SwiftScript trace: for, 2
> SwiftScript trace: for, 0
> Final status:
> login1$
> I suspect we need to make this more clear in the user guide and tutorials :)
I agree.
> - Mike
>> Or just use the concurrent mapper to let swift handle the output
>> naming itself. The resume files can't persist through multiple
>> sessions though.
>> > The most common case for this error occurs when two iterations
>> > within a foreach loop map an output file to the same physical file
>> > name. When swift runs and tries to put the output object into its
>> > site cache, it sees that a file of the name name is already in the
>> > cache, and its semantics do not allow that.
>> > I have not yet stared at this code long enough to see if this
>> > explains what is happening here.
>> > I also dont know why it might work under one version and fail under
>> > 0.92. If the above situation is occurring, perhaps there is some
>> > randomness involved: loop iteration ordering; filename generation
>> > randomness or difference, etc.
>> > But I would debug with that in mind: make sure that all *output* fie
>> > names mapped by the script are unique. Ideally, one should be able
>> > to find the culprit by grepping the swift log for all the mapped
>> > file names and look for duplicates.
>> > - Mike
>> >> Or maybe local variables are static? Maybe they mapped to different
>> >> files but to the same cache object? But I have been doing local
>> >> variables in my own workflows though.
>> >> 2011/3/30 Jonathan Monette <jon.monette at gmail.com>:
>> >> > Ok. I understand this error better. But shouldn't that be a
>> >> > different
>> >> > error then? Like a and b are mapped to the same file? I don't
>> >> > know
>> >> > if Swift
>> >> > can know this but looking at the explanation and error it should
>> >> > unless this
>> >> > cache message has a deeper meaning.
>> >> > On Wed, Mar 30, 2011 at 6:21 PM, Allan Espinosa
>> >> > <aespinosa at cs.uchicago.edu>
>> >> > wrote:
>> >> >> I had this error before when two output mapper objects mapped to
>> >> >> the same
>> >> >> file.
>> >> >> $ swift bug_same.swift
>> >> >> Swift svn swift-r4208 cog-r3073
>> >> >> RunID: 20110330-1818-ygec7ppa
>> >> >> Progress: time:0
>> >> >> The cache already contains
>> >> >> localhost:bug_same-20110330-1818-ygec7ppa/shared/foo.
>> >> >> Progress: time:1960 Stage in:1 Finished successfully:1
>> >> >> [aespinosa at communicado testing]$
>> >> >> [aespinosa at communicado testing]$ cat bug_same.swift
>> >> >> type file;
>> >> >> app (file out) echo(string input) {
>> >> >>  echo input stdout=@filename(out);
>> >> >> file a <"foo">;
>> >> >> file b <"foo">;
>> >> >> a = echo("hello world");
>> >> >> b = echo("foo bar");
>> >> >> But i think you should be using other Swift mappers that does
>> >> >> auto-numbering of files by default.
>> >> >> -Allan
>> >> >> 2011/3/30 Zhao Zhang <zhaozhang at uchicago.edu>:
>> >> >> > Hi guys,
>> >> >> > I am seeing something weird in swfit-0.92. Any idea about
>> >> >> > this?
>> >> >> > The swift script is very simple:
>> >> >> > zzhang at sandbox:~/workplace/Andrey> cat movies.swift
>> >> >> > type Pickle {}
>> >> >> > type History {}
>> >> >> > type Image {}
>> >> >> > app (History historyout) movie_graph (int rerun, int epochs,
>> >> >> > Pickle
>> >> >> > picklefile)
>> >> >> >   movie_graph rerun epochs;
>> >> >> > int arr[];
>> >> >> > iterate i
>> >> >> >  arr[i] = i+1;
>> >> >> > }until(i == 1);
>> >> >> > int epochs;
>> >> >> > epochs = 3;
>> >> >> > Pickle picklefile <single_file_mapper;
>> >> >> > file="for_movies.pickled">;
>> >> >> > foreach a in arr{
>> >> >> >  History historyout <single_file_mapper;
>> >> >> >  file=@strcat("output/rerun", a,
>> >> >> > "/histories.pickled-", a)>;
>> >> >> >  historyout = movie_graph(a, epochs, picklefile);
>> >> >> > I ran the script with the latest 0.92 version, which is loaded
>> >> >> > as
>> >> >> > a
>> >> >> > module
>> >> >> > on beagle. The I saw this:
>> >> >> > zzhang at sandbox:~/workplace/Andrey> swift -tc.file ./tc.data
>> >> >> > movies.swift
>> >> >> > Variable epochs defined in scope 99878388 shadows variable of
>> >> >> > same name
>> >> >> > in
>> >> >> > scope 1813605401
>> >> >> > Variable picklefile defined in scope 99878388 shadows variable
>> >> >> > of
>> >> >> > same
>> >> >> > name
>> >> >> > in scope 1813605401
>> >> >> > RunID: 20110330-1636-ev8vm8gb
>> >> >> > Progress:
>> >> >> > Progress: Selecting site:3 Active:1
>> >> >> > Progress: Selecting site:3 Checking status:1
>> >> >> > Progress: Selecting site:2 Stage in:1 Finished successfully:1
>> >> >> > Progress: Selecting site:2 Active:1 Finished successfully:1
>> >> >> > Progress: Selecting site:1 Stage in:1 Finished successfully:2
>> >> >> > Progress: Selecting site:1 Active:1 Finished successfully:2
>> >> >> > Progress: Selecting site:1 Checking status:1 Finished
>> >> >> > successfully:2
>> >> >> > localhost:movies-20110330-1636-ev8vm8gb/shared/output/rerun1/histories.pickled-1.
>> >> >> > Execution failed:
>> >> >> > Then I switched to an older version, it worked well.
>> >> >> > movies.swift
>> >> >> > Variable epochs defined in scope 212602028 shadows variable of
>> >> >> > same name
>> >> >> > in
>> >> >> > scope 1538939834
>> >> >> > Variable picklefile defined in scope 212602028 shadows
>> >> >> > variable
>> >> >> > of same
>> >> >> > name
>> >> >> > in scope 1538939834
>> >> >> > Swift svn swift-r3291 (swift modified locally) cog-r2750 (cog
>> >> >> > modified
>> >> >> > locally)
>> >> >> > RunID: 20110330-1639-gmbyz1qa
>> >> >> > Progress:
>> >> >> > Progress: Active:2
>> >> >> > Progress: Active:1 Checking status:1
>> >> >> > Final status: Finished successfully:2
>> >> >> _______________________________________________
