[Swift-devel] duplicated job submission in swift-0.92?
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Mar 30 19:58:23 CDT 2011
I wouldn't do that quite yet. This is very curious, but I think its the likely cause of what you are seeing.  The foreach() loop in this case seems to be having double vision :)  Its either some Swift subtlety or a bug:
login1$ cat zz1.swift
int arr[];
iterate i
   arr[i] = i+1;
   trace(i, arr[i]);
}until(i == 1);
foreach a in arr {
  trace("for", a);
login1$ swift zz1.swift
Swift svn swift-r4157 cog-r3056
RunID: 20110331-0053-tkh8yla5
Progress:
SwiftScript trace: 0, 1
SwiftScript trace: for, 1
SwiftScript trace: 1, 2
SwiftScript trace: for, 2
Final status:
login1$
But, Zhao, you could in the meantime use much simpler code like so:
login1$ cat zz2.swift
foreach a in [0:3] {
  trace("for", a);
login1$ swift zz2.swift
RunID: 20110331-0057-huo8jei0
Progress:
SwiftScript trace: for, 3
SwiftScript trace: for, 0
Final status:
login1$
I suspect we need to make this more clear in the user guide and tutorials :)
- Mike
----- Original Message -----
> Or just use the concurrent mapper to let swift handle the output
> naming itself. The resume files can't persist through multiple
> sessions though.
> 2011/3/30 Michael Wilde <wilde at mcs.anl.gov>:
> > The most common case for this error occurs when two iterations
> > within a foreach loop map an output file to the same physical file
> > name. When swift runs and tries to put the output object into its
> > site cache, it sees that a file of the name name is already in the
> > cache, and its semantics do not allow that.
> > I have not yet stared at this code long enough to see if this
> > explains what is happening here.
> > I also dont know why it might work under one version and fail under
> > 0.92. If the above situation is occurring, perhaps there is some
> > randomness involved: loop iteration ordering; filename generation
> > randomness or difference, etc.
> > But I would debug with that in mind: make sure that all *output* fie
> > names mapped by the script are unique. Ideally, one should be able
> > to find the culprit by grepping the swift log for all the mapped
> > file names and look for duplicates.
> > - Mike
> >> Or maybe local variables are static? Maybe they mapped to different
> >> files but to the same cache object? But I have been doing local
> >> variables in my own workflows though.
> >> 2011/3/30 Jonathan Monette <jon.monette at gmail.com>:
> >> > Ok. I understand this error better. But shouldn't that be a
> >> > different
> >> > error then? Like a and b are mapped to the same file? I don't
> >> > know
> >> > if Swift
> >> > can know this but looking at the explanation and error it should
> >> > unless this
> >> > cache message has a deeper meaning.
> >> > On Wed, Mar 30, 2011 at 6:21 PM, Allan Espinosa
> >> > <aespinosa at cs.uchicago.edu>
> >> > wrote:
> >> >> I had this error before when two output mapper objects mapped to
> >> >> the same
> >> >> file.
> >> >> $ swift bug_same.swift
> >> >> Swift svn swift-r4208 cog-r3073
> >> >> RunID: 20110330-1818-ygec7ppa
> >> >> Progress: time:0
> >> >> The cache already contains
> >> >> localhost:bug_same-20110330-1818-ygec7ppa/shared/foo.
> >> >> Progress: time:1960 Stage in:1 Finished successfully:1
> >> >> [aespinosa at communicado testing]$
> >> >> [aespinosa at communicado testing]$ cat bug_same.swift
> >> >> type file;
> >> >> app (file out) echo(string input) {
> >> >>  echo input stdout=@filename(out);
> >> >> file a <"foo">;
> >> >> file b <"foo">;
> >> >> a = echo("hello world");
> >> >> b = echo("foo bar");
> >> >> But i think you should be using other Swift mappers that does
> >> >> auto-numbering of files by default.
> >> >> -Allan
> >> >> 2011/3/30 Zhao Zhang <zhaozhang at uchicago.edu>:
> >> >> > Hi guys,
> >> >> > I am seeing something weird in swfit-0.92. Any idea about
> >> >> > this?
> >> >> > The swift script is very simple:
> >> >> > zzhang at sandbox:~/workplace/Andrey> cat movies.swift
> >> >> > type Pickle {}
> >> >> > type History {}
> >> >> > type Image {}
> >> >> > app (History historyout) movie_graph (int rerun, int epochs,
> >> >> > Pickle
> >> >> > picklefile)
> >> >> >   movie_graph rerun epochs;
> >> >> > int arr[];
> >> >> > iterate i
> >> >> >  arr[i] = i+1;
> >> >> > }until(i == 1);
> >> >> > int epochs;
> >> >> > epochs = 3;
> >> >> > Pickle picklefile <single_file_mapper;
> >> >> > file="for_movies.pickled">;
> >> >> > foreach a in arr{
> >> >> >  History historyout <single_file_mapper;
> >> >> >  file=@strcat("output/rerun", a,
> >> >> > "/histories.pickled-", a)>;
> >> >> >  historyout = movie_graph(a, epochs, picklefile);
> >> >> > I ran the script with the latest 0.92 version, which is loaded
> >> >> > as
> >> >> > a
> >> >> > module
> >> >> > on beagle. The I saw this:
> >> >> > zzhang at sandbox:~/workplace/Andrey> swift -tc.file ./tc.data
> >> >> > movies.swift
> >> >> > Variable epochs defined in scope 99878388 shadows variable of
> >> >> > same name
> >> >> > in
> >> >> > scope 1813605401
> >> >> > Variable picklefile defined in scope 99878388 shadows variable
> >> >> > of
> >> >> > same
> >> >> > name
> >> >> > in scope 1813605401
> >> >> > RunID: 20110330-1636-ev8vm8gb
> >> >> > Progress:
> >> >> > Progress: Selecting site:3 Active:1
> >> >> > Progress: Selecting site:3 Checking status:1
> >> >> > Progress: Selecting site:2 Stage in:1 Finished successfully:1
> >> >> > Progress: Selecting site:2 Active:1 Finished successfully:1
> >> >> > Progress: Selecting site:1 Stage in:1 Finished successfully:2
> >> >> > Progress: Selecting site:1 Active:1 Finished successfully:2
> >> >> > Progress: Selecting site:1 Checking status:1 Finished
> >> >> > successfully:2
> >> >> > localhost:movies-20110330-1636-ev8vm8gb/shared/output/rerun1/histories.pickled-1.
> >> >> > Execution failed:
> >> >> > Then I switched to an older version, it worked well.
> >> >> > movies.swift
> >> >> > Variable epochs defined in scope 212602028 shadows variable of
> >> >> > same name
> >> >> > in
> >> >> > scope 1538939834
> >> >> > Variable picklefile defined in scope 212602028 shadows
> >> >> > variable
> >> >> > of same
> >> >> > name
> >> >> > in scope 1538939834
> >> >> > Swift svn swift-r3291 (swift modified locally) cog-r2750 (cog
> >> >> > modified
> >> >> > locally)
> >> >> > RunID: 20110330-1639-gmbyz1qa
> >> >> > Progress:
> >> >> > Progress: Active:2
> >> >> > Progress: Active:1 Checking status:1
> >> >> > Final status: Finished successfully:2
> >> >> _______________________________________________
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
