[Swift-devel] duplicated job submission in swift-0.92?
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Wed Mar 30 17:59:37 CDT 2011
Hi Zhao,
[Quick spontaneous answer:]
I just tried to run a very simple script (attached relevant files zipped)
and it worked without any errors for me.
May be you can try that and I will try yours to see what we can reproduce.
Sorry gmail doesnt like to attach so here is the link:
http://www.mcs.anl.gov/~ketan/files/tmp.tgz
Ketan
On Wed, Mar 30, 2011 at 5:47 PM, Zhao Zhang <zhaozhang at uchicago.edu> wrote:
> Hi guys,
> I am seeing something weird in swfit-0.92. Any idea about this?
> The swift script is very simple:
> zzhang at sandbox:~/workplace/Andrey> cat movies.swift
> type Pickle {}
> type History {}
> type Image {}
> app (History historyout) movie_graph (int rerun, int epochs, Pickle
> picklefile)
>   movie_graph rerun epochs;
> int arr[];
> iterate i
>  arr[i] = i+1;
> }until(i == 1);
> int epochs;
> epochs = 3;
> Pickle picklefile <single_file_mapper; file="for_movies.pickled">;
> foreach a in arr{
>  History historyout <single_file_mapper; file=@strcat("output/rerun", a,
> "/histories.pickled-", a)>;
>  historyout = movie_graph(a, epochs, picklefile);
> I ran the script with the latest 0.92 version, which is loaded as a module
> on beagle. The I saw this:
> zzhang at sandbox:~/workplace/Andrey> swift -tc.file ./tc.data movies.swift
> Variable epochs defined in scope 99878388 shadows variable of same name in
> scope 1813605401
> Variable picklefile defined in scope 99878388 shadows variable of same name
> in scope 1813605401
> Swift svn swift-r4157 cog-r3056
> RunID: 20110330-1636-ev8vm8gb
> Progress:
> Progress:  Selecting site:3  Active:1
> Progress:  Selecting site:3  Checking status:1
> Progress:  Selecting site:2  Stage in:1  Finished successfully:1
> Progress:  Selecting site:2  Active:1  Finished successfully:1
> Progress:  Selecting site:1  Stage in:1  Finished successfully:2
> Progress:  Selecting site:1  Active:1  Finished successfully:2
> Progress:  Selecting site:1  Checking status:1  Finished successfully:2
> The cache already contains
> localhost:movies-20110330-1636-ev8vm8gb/shared/output/rerun1/histories.pickled-1.
> Execution failed:
> Then I switched to an older version, it worked well.
> Variable epochs defined in scope 212602028 shadows variable of same name in
> scope 1538939834
> Variable picklefile defined in scope 212602028 shadows variable of same
> name in scope 1538939834
> Swift svn swift-r3291 (swift modified locally) cog-r2750 (cog modified
> locally)
> RunID: 20110330-1639-gmbyz1qa
> Progress:
> Progress:  Active:2
> Progress:  Active:1  Checking status:1
> Final status:  Finished successfully:2
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110330/2154e232/attachment.html>
