[Swift-devel] hang checker fun
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Mon Mar 28 11:35:41 CDT 2011
on pads/ ci, the scripts and config files are in ~aespinosa/workflows/cybershake
2011/3/27 Mihael Hategan <hategan at mcs.anl.gov>:
> That would be the maybe not. The hang checker already checks if jobs are
> running.
> It seems that the submission fails in execute2 for unknown reasons and
> is retried 3 times. Then it hangs quietly instead of logging
> "END_FAILURE". Which is very odd. Can you point me to your exact
> installation of swift and configuration files?
> Mihael
> On Sun, 2011-03-27 at 16:54 -0700, Mihael Hategan wrote:
>> Maybe. Maybe not. It may be that the job itself doesn't get queued.
>> On Sun, 2011-03-27 at 16:41 -0700, Mihael Hategan wrote:
>> > Ok. The fact that the hang checker kicks in doesn't mean that there is
>> > necessarily a hang. What I see from the log is that extract is trying to
>> > run and is probably just queued.
>> > I will try to change the hang checker to not kick in if there is at
>> > least one job running.
>> > Mihael
>> > On Sun, 2011-03-27 at 18:29 -0500, Allan Espinosa wrote:
>> > > Here you go. (see attached)
>> > > -Allan
>> > > > May I also see the log? It looks like there's something weird around
>> > > > line 186.
>> > > > Mihael
>> > > > On Sun, 2011-03-27 at 17:56 -0500, Allan Espinosa wrote:
>> > > >> oops. trimmed the first part.
>> > > >> Thanks
>> > > >> type SgtDim;
>> > > >> type Variation;
>> > > >> type Seismogram;
>> > > >> type PeakValue;
>> > > >> type Station {
>> > > >>   string name;
>> > > >>   float lat;
>> > > >>   float lon;
>> > > >>   int erf;
>> > > >>   int variation_scenario;
>> > > >> type Sgt {
>> > > >>   SgtDim x;
>> > > >>   SgtDim y;
>> > > >> type Rupture {
>> > > >>   int source;
>> > > >>   int index;
>> > > >>   int size;
>> > > >> /* some constants used by the apps*/
>> > > >> global int num_time_steps = 3000;
>> > > >> global string spectra_period1 = "all";
>> > > >> global float filter_highhz = 5.0;
>> > > >> global float simulation_timeskip = 0.1;
>> > > >> app (Sgt _ext) extract(Sgt _sgt, Station _stat, Variation _var) {
>> > > >>   extract @strcat("stat=", _stat.name) "extract_sgt=1"
>> > > >>       @strcat("slon=", _stat.lon) @strcat("slat=", _stat.lat)
>> > > >>       @strcat("rupmodfile=", @filename(_var))
>> > > >>       @strcat("sgt_xfile=", @filename(_sgt.x))
>> > > >>       @strcat("sgt_yfile=", @filename(_sgt.y))
>> > > >>       @strcat("extract_sgt_xfile=", @filename(_ext.x))
>> > > >>       @strcat("extract_sgt_yfile=", @filename(_ext.y));
>> > > >> app (Seismogram _seis, PeakValue _peak)
>> > > >>     seispeak(Sgt _sgt, Variation _var, Station _stat) {
>> > > >>   seispeak
>> > > >>       /* Args of seismogram synthesis     */
>> > > >>       @strcat("stat=", _stat.name) "extract_sgt=0"
>> > > >>       "outputBinary=1" "mergeOutput=1" @strcat("ntout=", num_time_steps)
>> > > >>       @strcat("seis_file=", @filename(_seis))
>> > > >>       /* Args of peak ground acceleration */
>> > > >>       "simulation_out_pointsX=2" "simulation_out_pointsY=1"
>> > > >>       "surfseis_rspectra_seismogram_units=cmpersec"
>> > > >>       "surfseis_rspectra_output_units=cmpersec2"
>> > > >>       "surfseis_rspectra_output_type=aa"
>> > > >>       "surfseis_rspectra_apply_byteswap=no"
>> > > >>       @strcat("simulation_out_timesamples=", num_time_steps)
>> > > >>       @strcat("simulation_out_timeskip=", simulation_timeskip)
>> > > >>       @strcat("surfseis_rspectra_period=", spectra_period1)
>> > > >>       @strcat(" surfseis_rspectra_apply_filter_highHZ=", filter_highhz)
>> > > >>       @strcat("in=", @filename(_seis))
>> > > >>       @strcat("out=", @filename(_peak));
>> > > >>     seispeak_local(Sgt _sgt, Variation _var, Station _stat) {
>> > > >>   seispeak_local
>> > > >> app (Seismogram _seis[], PeakValue _peak[])
>> > > >>     seispeak_agg(Sgt _sgt, Variation _var[], Station _stat, int n) {
>> > > >>   seispeak_agg
>> > > >>       /* System args */
>> > > >>       _stat.name _stat.lon _stat.lat num_time_steps
>> > > >>       num_time_steps simulation_timeskip spectra_period1 filter_highhz
>> > > >>       @filename(_sgt.x) @filename(_sgt.y)
>> > > >>       n @filenames(_var) @filenames(_seis) @filenames(_peak);
>> > > >> // Auxillary functions for the mappers
>> > > >> type StationFile;
>> > > >> app (StationFile _stat) getsite_file(int _run_id) {
>> > > >>   getsite _run_id stdout=@filename(_stat);
>> > > >> (Station _stat) get_site(int _run_id) {
>> > > >>   StationFile file<"/var/tmp/site_tmp">;
>> > > >>   /*file = getsite_file(_run_id);*/
>> > > >>   _stat = readData(file);
>> > > >> type RuptureFile;
>> > > >> app (RuptureFile _rup) getrupture_file(int _run_id) {
>> > > >>   getrupture _run_id stdout=@filename(_rup);
>> > > >> (Rupture _rup[]) get_ruptures(int _run_id, Station _site) {
>> > > >>   /*RuptureFile file<single_file_mapper; file=@strcat(_site.name,
>> > > >> "/rup_tmp")>;*/
>> > > >>   RuptureFile file<"LGU/rup_tmp">;
>> > > >>   /*file = getrupture_file(_run_id);*/
>> > > >>   _rup = readData(file);
>> > > >> type VariationFile;
>> > > >> app (VariationFile _var) getvariation_file(Station _site, Rupture _rup,
>> > > >>     string _loc) {
>> > > >>   variation_mapper "-e" _site.erf "-v" _site.variation_scenario
>> > > >>       "-l" _loc "-s" _rup.source "-r" _rup.index stdout=@_var;
>> > > >> (string _vars[]) get_variations(Station _site, Rupture _rup, string _loc){
>> > > >>   string fname = @strcat(_rup.source, "_", _rup.index);
>> > > >>   VariationFile file<single_file_mapper;
>> > > >>       file=@strcat(_site.name, "/varlist/", _rup.source, "/", fname, ".txt")>;
>> > > >>   /*file = getvariation_file(_site, _rup, _loc);*/
>> > > >>   _vars = readData(file);
>> > > >> type offset {
>> > > >>   int off;
>> > > >>   int size;
>> > > >> type offset_file;
>> > > >> (offset _off[]) mkoffset(int _size, int _group_size) {
>> > > >>    offset_file file <single_file_mapper; file=@strcat("LGU/offset-",_size)>;
>> > > >>    file = mkoffset_file(_size, _group_size);
>> > > >>    _off = readData(file);
>> > > >> app (offset_file _off) mkoffset_file(int _size, int _group_size) {
>> > > >>   mkoffset _size _group_size;
>> > > >> /* TODO: data management zip jobs */
>> > > >> /* Main program */
>> > > >> int run_id = 664;
>> > > >> int agg_size = 80;
>> > > >> int loc_size = 20;
>> > > >> string datadir =
>> > > >>   "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results";
>> > > >> Station site = get_site(run_id);
>> > > >> Sgt sgt_var <ext; exec="getsgtvar.rb", r=run_id, s=site.name,
>> > > >>   l="gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/SgtFiles">;
>> > > >> Rupture rups[] = get_ruptures(run_id, site);
>> > > >> foreach rup in rups {
>> > > >>   string loc_sub = @strcat(datadir, "/", site.name, "/", rup.source,
>> > > >> "/", rup.index);
>> > > >>   Sgt sub <ext; exec="getsub.rb", l=loc_sub, n=site.name, s=rup.source,
>> > > >>       r=rup.index>;
>> > > >>   string var_str[] = get_variations( site, rup,
>> > > >>       "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations"
>> > > >>   Variation vars[] <array_mapper; files=var_str>;
>> > > >>   sub = extract(sgt_var,  site, vars[rup.size-1]);
>> > > >>   string seis_str[];
>> > > >>   string peak_str[];
>> > > >>   foreach var,i in vars {
>> > > >>     seis_str[i] = @strcat(loc_sub, "/Seismogram_", site.name, "_", rup.source,
>> > > >>                           "_", rup.index, "_", i, ".grm");
>> > > >>     peak_str[i] = @strcat(loc_sub, "/PeakVals_", site.name, "_", rup.source,
>> > > >>                           "_", rup.index, "_", i, ".bsa");
>> > > >>   Seismogram seis[] <array_mapper; files=seis_str>;
>> > > >>   PeakValue  peak[] <array_mapper; files=peak_str>;
>> > > >>   if(rup.size <= loc_size) {
>> > > >>      * Not worth to transfer the data. Execute on TeraGrid instead.
>> > > >>      * Also execute on localhost.
>> > > >>       (seis[i], peak[i]) = seispeak_local(sub, var, site);
>> > > >>   } else {if(rup.size <= agg_size) {
>> > > >>     /* Execute on a single resource */
>> > > >>     (seis, peak) = seispeak_agg(sub, vars, site, rup.size);
>> > > >>   } else {
>> > > >>     /*offset offs[] = mkoffset(rup.size, agg_size);*/
>> > > >>     /*for i in offs {*/
>> > > >>       /*(seis, peak) = seispeak_agg(sub, vars[i.off:i.off+off.size],*/
>> > > >>                                   /*off.size);*/
>> > > >> > I don't believe you. There is no SgtDim data type in that script.
>> > > >> > Mihael
>> > > >> > On Sun, 2011-03-27 at 16:55 -0500, Allan Espinosa wrote:
>> > > >> >> Here it is.  The get_app() calls are simple wrappers to readData()
>> > > >> >> type offset {
>> > > >> >>   int off;
>> > > >> >>   int size;
>> > > >> >> type offset_file;
>> > > >> >> /* Main program */
>> > > >> >> int run_id = 664;
>> > > >> >> int agg_size = 80;
>> > > >> >> int loc_size = 20;
>> > > >> >> string datadir =
>> > > >> >> "/", rup.index);
>> > > >> >>       r=rup.index>;
>> > > >> >>   string seis_str[];
>> > > >> >>   string peak_str[];
>> > > >> >>   } else {
>> > > >> >>     /*for i in offs {*/
>> > > >> >>                                   /*off.size);*/
>> > > >> >> > May I see the script?
>> > > >> >> > On Fri, 2011-03-25 at 19:42 -0500, Allan Espinosa wrote:
>> > > >> >> >> this has been occurring for 70 times already.  What i expect is for
>> > > >> >> >> the app with SgtDim sub to run and close the future.
>> > > >> >> >> 2011-03-25 19:40:12,217-0500 WARN  HangChecker No events in 10s.
>> > > >> >> >> Registered futures:
>> > > >> >> >> Rupture[] rups  Closed, 1 elements, 0 listeners
>> > > >> >> >> Variation vars - Closed, no listeners
>> > > >> >> >> SgtDim sub - Open, 1 listeners
>> > > >> >> >> string site  Closed, no listeners
>> > > >> >> >> Variation[] vars  Closed, 72 elements, 0 listeners
>> > > >> >> >> Waiting threads:
>> > > >> >> >> 0-13
>> > > >> >> >> 0-13-0-7
>> > > >> >> >> 0-13-0-8-1-1
